Results 1 to 15 of 15
Thread: Many issues.
    Aug 10 2016
    New Orleans, La
    Many issues.
    I'm very new to the page so please refrain from flaming me about anything. To begin, I am a mechanic and can do absolutely any labor nessecisary, with that being said this is my first Audi, my first German vehicle, and my first awd vehicle. I live in South Louisiana and emissions is no issue for me.
    I have a 1998 A4 Quattro 1.8t
    I purchased it about 7 months ago for $400
    I recently installed a boost gauge to start diagnosing some wierd hesitations.
    At part throttle right as I build boost the car will slightly here back and forth, with the boost gauge I can see it cycling from ~3-6 psi back and forth. This only happens from about 2k-5k rpm. 5k+ it sits steady at 8psi.
    What I find really strange is that at WOT I get a max of 5psi and no jerking through my entire rpm range.
    I think that will be my first problem to try and solve. Thanks for any input!
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    Check for boost leaks.
    Veteran Member Three Rings b5a4erik's Avatar
    Apr 22 2014
    Aptos, CA
    Good luck, man. Welcome.
    1999 A4 FWD AEB 1.8T ~ Atlas
    Aug 10 2016
    New Orleans, La
    Quote Originally Posted by Davdraco1 View Post
    Would a smoke machine be a good was to test for boost leaks? I removed about 3/4 of the vacuum system already because it was falling apart and leaking everywhere. I know I don't have any leaks after the throttle plate. Can I just smoke everything before the throttle plate too?
    Oct 10 2013
    State College PA
    http://www.audizine.com/forum/showth...st-Leak-Tester
    I did something like this but with a 90 degree so it's easier to use. I attached mine into the TIP and then you just get some kinda spray soap from under your sink and start spraying where you hear a hissing sound come from. If it start to bubble there is your leak. A smoke a machin would work but that is easy and under 10$ altogether.
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    ^^^^^^^ soap and water, windex and soap, you can even use that hvac leak detector stuff calgon blue or whatever.
    soap and water works for me. spray everywhere you suspect a leak. if you dont have a boost leak tester or dont feel like making your own, get a buddy to hold the rpms at around 2,000. works for me
    Aug 10 2016
    New Orleans, La
    I did a boost leak test and found one more leak. I fixed it. But I still have the same problem. The hesitation and jerking seems to be more intermittent now, but I still only get 5 psi at WOT and 9 or 10 at half throttle.
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by 98QuattroAFour View Post
    how does it idle? I had weak coils and it caused some surging/ violent jerking because it would missfire under load but not enough to set an engine light, I pinpointed the poor coils by having the scanner open on individual cylinder missfire counters and replaced the coil that that would set the one or 2 random missfires. It would also cause it to chug at idle every now and then.
    Aug 10 2016
    New Orleans, La
    It idles great. And since I have means of checking misfires with a scanner I'll do it in just a few minutes.
    Aug 10 2016
    New Orleans, La
    OK so this weekend was my weekend to finally do my timing belt, water pump, and power steering pump. I gother side tracked and forgot to check the misfires but when I tore my car down I found that the timing was a tooth off. That was probably some of my sluggishness.
    Aug 10 2016
    New Orleans, La
    OK so I got all my work done. New timing belt, water pump, and power steering pump.
    I drove the car for a bit with the scanner hooked up and did get a few misfires from 2 and 3 which are my 2 cylinders with original coils. I also noticed the maf sensor reading some wierd numbers.
    I know I should replace my coils.
    Does anyone know what the MAF should read on these cars?
    - - - Updated - - -
    Here is a link to a short 2nd gear pull. You can see that my boost spike and then goes down to 4 or 5 psi.
    Aug 10 2016
    New Orleans, La
    Feb 27 2011
    Winnipeg
    - - - Updated - - -
    if you have new plugs in there and its getting a few misses on 2 and 3 yes definitely change the 2 coils.
    Aug 10 2016
    New Orleans, La
    The plugs have about 10k on them. I just purchased 2 coils. I'll be putting them on around 430/5:00. Central time.
    Aug 10 2016
    New Orleans, La
    OK so I changed the two other coils and now it doesn't hesitate as much but the boost still does the exact same thing.
