Hi guys.
Patient:
Audi A4 B5 2.8 1999, tiptronic quattro
Current symptoms (no PC erros regarding ABS):
1. While braking from higher speeds (long braking distance) at about 20-40 km/h the ABS starts to "work". By work I mean a weird brake pedal feeling (scraping?). Then it starts to be softer and I push a little harder. In the end the ABS (?) activates and brakes the car by some kind of automatic brake punch. Probably it tries to compensate wheel speeds?
2. After letting go of a brake pedal on a stop with drive gear on, the ABS starts to buzz for a second and lights, etc dimms. Nothing else happens. The car rolls normally, no brake intervention.
Changed parts (by 4 or 5 mechanics):
1. 3 (!) ABS pumps changed - no improvement
2. ESP pump changed (the one underneath the ABS pump) - no improvement
3. ABS driver changed (under the rear seat) - no improvement
4. All 4 ABS sensors changed (the rear ones are different - they use some kind of screws) - no improvement
The last mechanic says that while braking the wheels speed read by the PC is not entirely correct. The speeds are not smooth. Unfortunately the car can only read wheel speeds under ~24km/h.
Does anyone know what to do? I'm hopeless. Should I buy a Yaris instead? :( Thanks for any help!
