Results 1 to 17 of 17
    Senior Member Three Rings kdf8454's Avatar
    Apr 21 2014
    Akron OH
    Late Shifter Linkage on Early Trans
    I bought a used 01E (early) to replace my current (late) trans and didn't think about the linkage until afterwards.
    From what I've found, the only difference between the two is the cross rod and how it bolts to the shift selector cover, but I haven't found much about any other differences.
    So, my question is, are these compatible if I swap the selector shaft cover from my late trans on to the early trans and use my existing late style linkage and cross rod? Or do I need to find a set of early style linkage and shifter?
    01.5 Stage 3 Seafoam S4
    @fizznizzy
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Try it and let us know.
    Apr 21 2014
    Akron OH
    that's the next step in the process... engine is about ready to go in tonight
    @fizznizzy
    Apr 21 2014
    Akron OH
    well if anyone is curious, I swapped the shift selector cover (to the late version) and hooked it up to the late linkage. Engine is in the car and goes into all gears trouble free.
    Hopefully driving it this weekend/early next week to confirm full functionality
    @fizznizzy
    Sep 30 2015
    You the man, hope it workd
    Apr 21 2014
    Akron OH
    Well I tried it. No problems. Hopefully this will help someone swapping an early trans into a late car.
    @fizznizzy
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    it works but the problem is your shifting is diagonal instead of straight. instead of I I I you have / / /
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    The only thing different on the trans is that cover you swapped so wont be an issue. Some covers have both mounting points.
    I cant remember which combo it is that doesnt work offhand, but you will know because the crossrod will bind on one of the detents.
    If you use the wrong shifter you will get what Dave mentioned above.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Apr 21 2014
    Akron OH
    For this scenario, it didn't change the pattern at all. Must be because I changed the selector cover to the one that has the early and late tapped holes. I just wanted to make sure because there is a small casting feature on the inside of that cover on the early version that was eliminated on the late.
    So, early trans with early/late selector cover and late linkage = G2G
    @fizznizzy
    Jul 07 2009
    Alberta, Canada
    Ya, the covers are what need to match the linkage... and obviously linkage to the correct shifter.
    Established Member Two Rings seitter19's Avatar
    Oct 02 2011
    Traverse City, MI
    Quote Originally Posted by DxC View Post
    Quote Originally Posted by kdf8454 View Post
    I just did this. Car came stock with late trans, late linkage, late cross rod, etc. I put in an early trans and swapped my selector cover from my stock late trans to the rebuilt early and used the correct late hole. But I am getting what DxC mentioned. My shifts are angled /// instead of |||. I also put in the late JHM cross rod, JHM delrin bushing, JHM solid short shifter, and rebuilt the linkage socket on driver side with oem kit. For the cross rod on the passenger side I used one supplied washer below the bushing, and one supplied washer above the bushing, is this correct? Anyone know of what could be going on? Is this angled shifts only present if you use the wrong hole?
    Another question. With my JHM short shifter and full setup, a few of my gears have very little to zero play (2nd and 5th gear particularly), whereas the other gears still have some play. What could be causing this? How can I make all of my gears have no play?
    Thanks in advance,
    Ryan
    2016 Glacier White APR Stage 2 DP B8.5 SQ5 ~ 2001.5 Brilliant Black EPL Stage 3 K04 B5 S4 Avant ~ 1995.5 Brilliant Black MTM Stage 1+ UrS6 Avant (Sold) ~ 2002 Brilliant Black B6 A4 1.8t (Sold) ~ 2002 Casablanca VAST Stage 3 K04 B5 S4 (Sold) ~ 2001 Santorin B5 A4 2.8 (Sold)
    Nov 16 2010
    WetSide, WA
    Having the wrong shifter does that. Maybe just the foot flipped over and kicked off the wrong way?
    Early has a straight foot and straight linkage, late has angled foot with angled linkage.
    If you mix them up, it rotates the ankle? and your shifter doesnt go straight forward and backward.
    Oct 02 2011
    Traverse City, MI
    Quote Originally Posted by zillarob View Post
    Hmmm, the car came stock with everything late and all the components that I replaced are late. Only mix is the replacement trans is early so I put the late cap on it. So I feel like my setup should all work. Could you explain what you mean by the foot flipping over and kicking off and the ankle rotating? Do you mean the black piece on the bottom of the shifter that you bolt the shift linkage to?
    Nov 16 2010
    WetSide, WA
    Ya, Id be taking a real good look at the black thing on the bottom.
    Oct 02 2011
    Traverse City, MI
    Thanks zillarob! Ended up being that JHM sent it with the incorrect metal foot (the straight one). JHM sent me the correct piece (angled) and now she's shifting happy!
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    hmmm i think i might be in the same boat. i have a late shifter box, with early trans and lincage. Would i have the angled shifting ?(car is apart now)
    GIAC-X, STASIS TS,VAST,034 MS
    Nov 16 2010
    WetSide, WA
    It goes by the linkage.
    Early wants the straight foot
    Late wants the angled foot
