i have not been here too long but i have met a number of you that are local. those people who have seen the car will vouch for its stellar condition. also, it may have been seen recently at waterfest and vag fair (second place in class woohoo).
price is $22,000. considering 2 (a b6 and b7) avants sold within the last 6 months on bringatrailer for $26,000+ i think im reasonable, especially since i have WAY WAY WAY more recent maintenance done their either of those cars. also, id like to point out that is is ONE OF SIX nogaro blue avant manuals and i have the documentation from audi to prove it :) . please dont tell me how there are 10 s4's in your hood for 5k each and i should lower my price. i will gladly work numbers with you if you can find a comparable s4 in comparable condition.
100k ok the clock.
body: SUPER CLEAN
never been wrecked or even in a fender bender. side skirts, door blades and front bumper repainted do to rock chips (im ocd). not a rust bucket.
interior: SUPER CLEAN
even better than the exterior. no soft touch peel, not even SOFT soft touch. headlight switch and climate control look and feel like new. leather in FANTASTIC shape. headliner is starting to droop a little in the back.
suspension: FIRM AND TIGHT
new bilstein sport shocks and h&r springs with new mounts and adjustable upper control arms, oem lower control arms, pin bolt hardware, and all working camber/toe adjustment front and rear. PERFECT alignment at local audi dealer.
engine: VROOM? VROOOOOOOOOOOOM :)
engine starts with no chain rattle, no smoke, and no check engine lights.
recent maintenance when engine was out:
~all covers and gaskets replaced DOWN TO THE BARE LONG BLOCK. no seal or gasket was left unchanged!
~full chain kit (oem) with upgraded rs4 main guide, hydraulic cam adjuster guides, and jhm mechanical cam adjusters
~new plugs, oem coolant, oem oil filter, k&n air filter, oem hydraulic fluid etc.
~new oem clutch kit
~new oem motor mounts with sensors
~new compressor, alternator, power steering pump and pressure line, and new starter
~all new ac seals, water pump and thermostat
~new oem accessory belt and tensioner
~new o2 sensors front and rear
~new cam sensors
~new clutch slave
upgrades:
jhm intake spacers
jhm 91-93 tune
jhm solid shifter linkage
jhm stabilizer shifter bushing
apikol snub and diff mount
lightened flywheel
awe exhaust (resonated and h-pipe)
oem ttrs wheels with NEW tire and with spacers (10mm/15mm), oem wheels available as well.
upgraded front engine and rear diff mount
peggy pipes with new flex pipes
powdercoated intake and valve covers (oem look)
sai blockoff plates (all hardware still here in case you want to go back) sai pump works fine.
hotchkis front and rear sway bars
spc adjustable front upper control arms
im sure im forgetting more... a lot of time and money was spent. i enjoyed the build.
more pics to come later.
