Results 1 to 40 of 48
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    New engine seems hot.
    So finally got car running, fluids are all to spec all to level, oil pressure is good now that I have a good gauge.
    But it just seems hot under the hood. Overly hot. Billet valve cover is new to me I assumed it wud be warm to touch, but it's hot.
    Cam timing housing too. Now it's been almost 2 years since I've driven it. And I just might be super cautious right now. But is this normal??
    Temp sensors work, and it's not going over the usual temp. Should I be this concerned?
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    I just bought my a4 and all I can say is, after im done driving, If I open the hood to check anything I have to leave it open for like 5 minutes and come back to it otherwise its just so hot in there I can barely get in the bay! So I would say yes its normal (mines completely stock) maybe someone with the same valve cover etc can chime it.
    But I'd say under the hood is like crawling in a 400 degree oven
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Feb 10 2012
    parts
    Napanee, ON
    Lol I remember it being hot w the 2863 turbo and the k04. I just seem to feel like this is a 450 degree oven as I'm used to the 400 degree unit. Lol.
    I'll wait for someone to chime in as suggested.
    Thanks for feedback!
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Mine runs pretty warm... then again I did catch on fire the other day :P
    Engines get warm. As long as you don't see anything melting, your oil is a quality oil and your coolant temps are running fine I would assume you're okay. The turbo can get glowing red depending on how hard you push it.
    If you feel something is wrong I would look into it or have someone who would know look but odds are you're being paranoid.
    DISCLAIMER: I can't see or feel your engine bay so these are just my internet opinions :D
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Feb 10 2012
    parts
    Napanee, ON
    Ya paranoid is understatement on how much $$$$ is now under that hood.
    I'm going to bring home infrared scanner from work and keep that around to see how hot it's getting.
    Ok I'm going to go flash for break in and go for a short drive. See how it feels on the road.
    At idle right now NVH is nearly unbearable...... Damn solid motor mounts.
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by canadianA4B7 View Post
    What is NVH?
    I have solid mounts and it vibrates a bit but when I did the 1.8t swap it actually made it smoother.. thought it would be worse without those fancy balance shafts... :P
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Do you have IR thermometer? I can shoot my valve cover and cam cover later today for you to compare temps?
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    If your temp gauge is good, you are good.
    Engines are hot. You couldn't make any sort of accurate judgement after not driving the car for two years, anyway.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by Copen-cisco View Post
    Yes please do I will be grabbing mine from work tonight. Can u scan the timing chain housing too please.
    Sep 06 2013
    Dublin, CA
    Sure thing.
    Kristian
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by yeoj112689 View Post
    What is NVH?
    Noise vibration harshness.
    Mines insane. Literally everything has a good vibration to it. Have yet to drive due to tune though. I think it will be fine above 1000 rpm though.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Valve cover is going to be hot after a drive.
    Dec 23 2011
    I have a Drake's metal valve cover. With the gtx turbo the engine bay gets HOT as hell after a long ride and the billet valve cover will burn your hand if touched. Still, the temp gauge stays in the middle and I haven't noticed any other issues.
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    Welcome to the 1.8T oil pump and BS deletion... My Idle at 800 does have some rattles in the cabin, smooths after 1000RPM but then seems to have a second resonance around 2500-3000.
    As far as heat, yeah, it gets hot, but I would say as long at your coolant temps are normal you are fine. I run an oil temp gauge as well and it gets to 80C normal, had it up to 95C on a hot day. My upper limit is 135 before oil breaks down.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Jun 17 2013
    jersey city nj
    Solid mts + 1.8T oil pump =vibrations.....
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by vce1232000 View Post
    Lmfao! This just made everything more understandable! If only more used the emojis properly the word wud be a better place!! It's insane man. Others post some increase in NVH this is more then a mild increase in NVH.
    Thanks for the input mates I'm clearly being paranoid. And I think I've just been out of this car for a bit too long.
    Flashing break in file. No bumper on yet. No leaks no issues it seems. Maybe a bit of a drive b4 work see how this new thing feels on the road
    Apr 24 2016
    California
    It doesn’t help that the whole engine bay is sealed against the hood, so the heat has nowhere to go before you open the hood.
    2005.5 A4Q 2.0T 6MT JHM 2+, Autotech internals, CTS front mount, GFB DV+, 034 Street Density mounts + snub, H&R coilovers, B7 Recaros, Phil's V4's, maybe a k04 soon?
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    I'll swing by this weekend and you can use the IR gauge on my car after a 40 minute drive. That way we can compare VCs as we have nearly identical ones. I would still suggest a turbo blanket/exhaust thermal wrap. Then I would suggest DEI Reflect a Gold on your intake parts and underside of the hood.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Veteran Member Three Rings deusilan's Avatar
    Aug 17 2012
    '89 E30 325i; 2011 Police Interceptor
    Stinky Island, NY
    Do you have your cat wrapped with exhaust wrap?
    When I swap my turbo out, I plan on wrapping the cat with some. You should consider doing the same. It'll help with those under hood temps.
    Currently: 2005.5 A4 2.0 (Red)TQ 6-spd, WORK IN PROGRESS 2011 Police Interceptor
    Previously: E30 325i, donated for track purposes
    Feb 10 2012
    parts
    Napanee, ON
    No wrap on exhaust mixed reviews on doing so. Maybe on the upper parts that lead into the engine bay or a turbo blanket might help too.
    James I'll have the IR scanner so we can do that test. Interested as I don't remember the plastic one getting this warm. Obviously yes warm but clearly as most know the metal parts seem to hold heat a bit.
    Jun 04 2011
    Clayton, CA
    I personally woul not wrap the exhaust / header.
    For the NVH, motor mounts are making it the worst giving you no isolation. At fist I thought my rear window was dirty, then I realized it was just my rear view mirror vibrating making the defroster lines blur
    Build Thread
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by rongeur View Post
    I know there's been hits and misses on the wrapping. Perhaps just a blanket then?? Good quality one though not anything cheapy cheapy.
    Lol I know what your saying. Mines crazy the hood up looks like it's moving like CN tower (Toronto) it was swaying 2" thought it was gonna close on me. I'll get used to it.....
    Thanks for input guys I'll get it scanner tonight and post finding some time tomorrow. Working nights really kills my time for activities
    Oct 29 2009
    Sold - 06 b7 2.0T a4 avant quattro
    Kitchener, On. Canada
    I used to run an IE billet VC and it got VERY hot. You'd burn yourself if you tried to open the oil cap right after driving the car.
    Sold - 06 B7 A4 2.0T Q6MT avant - BB
    Mods:Uni stg2 HPFP 91oct, KMD HPFP, ER SMIC's w/034 hoses, 034 TIP, 034 HFC, Custom quad-tip, a4 sport suspension, RS4 rear sway, RNS-E, RS4 carbon trim pedals & shifter, S4 Recaros, AWE vent mount boost gauge, Black RS4 look grill, Votex front splitters & side skirts, Ti window trim, S4 mirrors, LLtek LED headlights, DDM HID Fogs, Black 19" O.Z. Ultraleggera
    Oct 24 2015
    Perth, WA
    As said before, if you temp gauge is fine, you're fine. The temperature of the VC may be the same, but the heat transfer higher (making it feel hotter) as it is made of metal (better conductor of heat).
    My respray thread
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by cdn_b7a4 View Post
    This was my concern it's hot as hell I wudnt ever attempt opening that thing after a drive. I'm interested too see the actual temp via IR scanner
    Aug 17 2013
    Rossford, Oh
    Funny... when I did the 1.8t my vibrations went down. Could be that my stock pump was crapping out and causing vibrations but I do not have anyway to really test that. I have the 034 solid mounts and snub mount as well. Smooth as butter compared to before the swap. Very little vibration at idle.
    Feb 10 2012
    parts
    Napanee, ON
    Your not the first to say the same. I've read a number of different reviews. Mine was 100% balanced crankshaft rods Pistons and all from what I was told. I've yet to see a bill though so tuning gruppe might not have had everything done. I don't know. And at this point it seems like I will likely never know since I've recieved the motor and only been promised that I would get the info. Car purrs like a kitten though.
    Veteran Member Four Rings pat_do's Avatar
    Feb 19 2012
    Montreal
    It's an oven in the engine bay. This is my first turbo car; all my other cars were naturally aspirated.
    That said, every component in the engine bay gets so hot.
    Jun 17 2013
    jersey city nj
    Imo its a idea. This will increase the internal temperature of the turbo when the engine is shut down not allowing heat to escape and cooking the oil and coolant. But this is just my opinion on it
    Feb 10 2012
    parts
    Napanee, ON
    Last night I read the exact same description on these turbo blankets. I won't be going this route or wrapping anything. Best plan let it cool down and maybe open hood after some driving.
    Jun 04 2011
    Clayton, CA
    I remember my K03 glowing bright red after a spirited drive home. Turbos get hot period. Your GTX is in stock location which means it was German designed to handle glowing red hot turbo exhaust housings and manifolds. If you were top mount, I would consider insulating the hood to keep the pain from bubbling but that isn't your situation.
    Glad to hear she is purring like a kitten. Mine seems to running smooth as well.
    Build Thread
    Jun 17 2013
    jersey city nj
    Get a remote starter ed. This way you can keep the engine running for a set determined amount of time to cool down without the keys in car and locked up. They have a setting for post run option
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    I would like to send you guys my copy of "Engine Bay Cookbook".
    Get some value out of all that wasted heat!
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by Brillo View Post
    Eggs off of the billet valve cover were delicious. Tasted like exhaust fumes, tiny bit of oil residue, some sweat a lil blood. So good!!!!
    Was joking at work with a few guys here from Ireland they suggested sectioning the hood w a piece of stainless unpainted and a drip edge to it. That way after my spirited drives if my blood sugars a little off I can cook up full meals road side. But then I need to turn something in side into a fridge/freezer............ Time to trade in the sedan and get an avant. Roof top sleeper like most of those avant guys buy (I bet it feels like they're sleeping in a Thule coffin). Oh man this is gonna get expensive again!
    Feb 10 2012
    parts
    Napanee, ON
    Funny u mention this. Bought a "new used" remote starter last Christmas and i think it does have an "ignition off run time" option. Wonder where I put it...... Thanks for that. If I can use it on my 6 speed and it will allow the turbo timer option. It's going in the car soon.
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    I want to louvre my hood.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    As far as I can remember, our engine bay has always been VERY hot. I once wanted to spray the engine clean at one of those coin-op car wash places but decided not to for fearing that the water might end up 'cracking' its block due to being so damn hot!
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Jun 17 2013
    jersey city nj
    I have this ed in my MK1 GTI. Since the turbo is only oil cooled. I have to let to cool down before it shuts off or the oil will coke up after time in
    Mar 24 2013
    Oakdale, CT
    I've got solid motor mounts in my new B7 and the vibrations really aren't that bad. From what I've heard, the trans mount will transfer more NVH to the cabin if upgraded to a stiffer mount.
    -Adam
    Feb 10 2012
    parts
    Napanee, ON
    That's where I'm getting it from. Solid motor mount and upgraded trans mount too. I think it's the stern unit was installed awhile ago. I'm thinking the same that it's the combo that's making mine this rigid or harsh in the cabin. But then again I don't feel like I'll care when shifting it through the gears around town, the highway or the track
