My 2009 Audi A4 2.0T drove perfectly to work yesterday then after work I tried to start it up and it sounded sort of weak, so I stopped it and went to start again. After that all my dash lights/radio would start but I just heard a humming noise (no clicking, no cranking, just humming). Tow truck came out and it's not the battery. I figured it's a starter or ignition switch, but the repair shop called today to say there is zero compression in all 4 cylinders and that it needs a whole new (used) engine.
No idea what happened and said it'd be more expensive to have them tear it apart just to find out that 99.9% I need a new engine...something doesn't sound right here though. It didn't make a big bang like the timing chain snapped. What are your thoughts? Any other suggestions that could help save my car? Thanks!
In the case that it DOES need an engine, they said there are two different ID codes for this engine and one is half as much $ as the other. They repair shop called the dealer who said the 2 are not interchangeable. Can someone help confirm why since mine has the more expensive engine in it?
