Results 1 to 6 of 6
Thread: MAF connector
    Active Member Two Rings DeutscheB6's Avatar
    Jul 15 2016
    Germany
    MAF connector
    Quick question on the pin connection. So I cleaned my MAF and while in the process some of the plastic in the connector (harness) broke off. I noticed that there was only 4 metal prongs in the connector and 5 on the sensor. Is this correct?
    Sent from the Beer Cloud
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Yes that is correct. The 1.8T harness connector only has four terminal connections. The fifth connection is used for an intake air temperature sensor. With turbos the IAT is mounted on the throttle body. For non-turbo applications the IAT can be incorporated into the MAF sensor.
    Jul 15 2016
    Germany
    Thanks OG!
    Sep 05 2013
    Ottawa, Ontario
    I do not mean to thread jack but while we're on the subject of MAF's... I was looking for a MAF at the junk yard for my car and stumbled upon a 2.0 golf with a almost brand new MAF, would this MAF work on our 1.8T's??
    Dec 28 2006
    Western Maryland
    Check the part number on the sensor itself (not the housing). If it ends in 049 you should be good to go.
    Sep 05 2013
    Ottawa, Ontario
    Thanks OG! I'll have to go check it out.
