Results 1 to 12 of 12
    Established Member Two Rings 123lilc's Avatar
    Mar 04 2015
    2002 Audi A4 GTX3071R, 2004 Audi S4 Avant 6M/T, 2008 Audi A4 Cabriolet,2018 L5P Duramax
    Champaign, Illinois
    Question What is this ticking sound? Lifter?
    Having a weird ticking sound from the valve cover its almost all the time its not too loud when at temp but when its cold its louder. I do not think it is CCT but what do i know it sound like its comming from the coilpacks but i wouldn't think it would be arcing.
    Established Member Two Rings Rubba's Avatar
    Feb 12 2016
    A6 C7, Passat B7
    Libya
    Could be spark plugs,
    Can you rev? and also let us hear back of the exhaust when idle.
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    I'm having a lifter issue as well, mine will go away when the car warms up, is this video during a cold start? What oil are you using? I ran mobile 1 5w30 synthetic, I switched to Rotella t6 5w40 and it quieted down significantly. Try using the Rotella for a few oil changes for diesel oil has better detergent properties than our standard synthetic motor oil does.
    Edit : spelling ( auto correct )
    Mar 04 2015
    Champaign, Illinois
    Quote Originally Posted by KHARDa4 View Post
    This was warm i am currently using Mobil 1 5w-30. i will try rotella. So the sound im hearing is a lifter correct?
    Mar 04 2015
    Champaign, Illinois
    Quote Originally Posted by Rubba View Post
    How could it be the sparkplug?
    Apr 17 2016
    kc
    Quote Originally Posted by 123lilc View Post
    Maybe it came loose in the hole and its rattling? Haha. That dude cracks me up!
    Dec 30 2014
    South Carolina
    Yes it is a lifter.
    Mar 04 2015
    Champaign, Illinois
    so is it normal and ok for it to sound like this??? i don't wanna hurt my engine as it kinda essential to driving haha
    May 22 2012
    FAIRBANKS/AK/USA
    Have you taken the valve cover off for a peek?
    the 3.0's, including mine had cam shaft issues and sometimes a lobe will wear down. Not sure if the 1.8's had this issue?
    2002 A4 3.0 MT
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    I had that in both of my Audis 1.8t and 2.8.
    Used "Rislone engine cleaner", gradually went away. It slowly remove the sludge.
    Prepare 2 oil filter and oil as it will get dark from the cleaning. (Writing this make me sound like a snake oil sellers, but it worked as intended)
    Step
    1. keep the oil filter, poor complete Rislone container in (dont overfill the engine, remove oil if needed),
    2. After 3000 km, drain oil, replace filter, (use cheap oil)
    3. After 3000 km, drain oil, replace filter, (use cheap oil)
    4. Use quality oil and a new filter, problem should be solved!
    Dec 30 2014
    South Carolina
    You can try this engine flush procedure as stated above, ultimately we have the same goal in mind. I do not know the cost of his suggestion but rotella oil is fairly cheap and will clean the motor just by a few oil changes.
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    +1 for rotella t6 and oil flush method.
