Seeing the below on scan. Can anyone confirm my suspicion that the module on the pump under hood needs to be replaced? Weird issue. Brake lights always on and traction esp and flashing brake on dash. Not brake switch.
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004532
2 Faults Found:
01314 - Engine Control Module
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x4702
Hex Value: 0x0014
Hex Value: 0x21A4
Hex Value: 0x0001
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x4702
Hex Value: 0x0014
Hex Value: 0x12A3
Hex Value: 0x0001
