Results 1 to 12 of 12
    Established Member Two Rings SweetinsanityTT's Avatar
    Oct 09 2010
    2007 Audi RS4, 2010 Volkswagen Jetta TDI (Sold), 2001 Audi TT Quattro Big Turbo (Sold/RIP)
    Other Side of the Pacific
    Random/Sporadic EPC Light - Intake Manifold
    So I have been getting a random EPC light on the car over the last few days. Doesnt seem to effect thw driveability and the car runs fine .
    Scanned the codes and it came back with the following:
    Any idea what would cause this? I am assuming it may have something to do with those connections to the sensors as the whole manifold was replaced 20k miles ago. I am going to pull the connections off an clean them over the next few days. Any insight or advice would be greatly appreciated.
    Oct 09 2010
    Random as in it comes on on my drive into work but that is the only time i will see it that day. Drive home or drives during the day the light wont come on.
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    I think I had the same codes and replaced the sensor and it went away.
    Established Member Two Rings S42RS4's Avatar
    Mar 16 2015
    Tacoma, Wa
    Replace both of the sensors and the code won't come back. I had the same problem
    2008 What can I say, I had to get another RS. Jackal Tune, Gruppe M Intake, Escort IXc, Euro Seats, Euro Steering Wheel, JHM Intake Spacers, Custom 2.5 exhaust w/x-pipe, JHM SS Lines & more to come
    2007 (Lacy)The Trouble Maker Traded in.
    2006 Traded In
    Oct 09 2010
    Update: Car threw a CEL on the way home. Codes were as follows:
    P2020: Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Bank 2A
    P2015: Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Bank 1A
    Still the same diagnosis or could I have some thing else going on like a vacuum leak, etc?
    Sucks that these sensors could go out in just under 20K if that is ultimately what they end up being. Thanks for all the insight so far. It is greatly appreciated.
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Since it's both banks, I'd say it's more likely that the vacuum lines connected to the flap arm solenoids are messed up. Or the solenoid controller is done.
    Jun 25 2009
    SC
    Run this test if you've got VCDS: http://forum.rs246.com/viewtopic.php?t=77235
    Oct 09 2010
    Komseh, thanks for the link.
    Unfortunately, I dont have access to VCDS. I have an appointment for Friday morning at a local euro shop. Ill update this thread after they figure out what it is. Sadly, troubleshooting this is beyond my access to tools at the moment. Hopefully, its just a vaccuum issue.
    Oct 09 2010
    So long story short. I no longer own the RS4.
    Took it to the first shop and they could not diagnose the issue but noted several issues with values on the engine harness itself (Several sensors began to get a sporadic reading/Car was acting weird electrically). Took it to Audi and they stated it needed a new manifold. Additionally, I developed on oil leak on the back right timing chain cover. Oddly enough after going back through the old service records I had for the car I found out it was no the first time it has had electrical issues and in fact had the cluster replaced at one point.
    Audi offered me a decent number on the trade with the issues the way the car sat and I took it. Quiet frankly I was done putting money into the car, did some simple math, and found out that based on the associated costs with the new maintenance I would be money ahead in the long run. It was a fun while it lasted but the car simply became un-affordable rather quickly.
    On another note I do have a few parts for sale that I was planning on putting on the car but I seeing as how I no longer have it they are up for grabs. See list below:
    Schwaben Professional Scan Tool (For Audi/Volkswagen)
    Axle Seals (OEM)/Axle (Duralast)
    All bolts/hardware for doing axle seal change
    M14x1.5 lug to stud conversion kit with conical lugs (fits 10mm spacers in the front 20mm in rear) - Brand new
    I may have a few other things but I will have to look. If anyone is interested in any of that let me know. For now I am stepping away from Audis for a bit and went with a cheap daily driver. Luckily, still a six speed manual and a turbo .
    Feb 24 2010
    And have never been happier
    Quote Originally Posted by SweetinsanityTT View Post
    Sorry the RS4 is gone, but happy that money pit is gone at the same time. Good luck with your new ride. Tech and safety in newer cars is just insane these days as well. I have had to sell a few cars in the past that became money pit fast and German cars without warranty are no exception to making you a religious person overnight :)
    Good luck! Also highly appreciate the follow up to the issue.
    Switched to Tesla and have never been happier. No more shady mechanic bills and excuses - oil top off before an oil change is normal or dealing with outdated forums that have image size limitations. And no more dealing with vendors that do not provide horsepower numbers but sell you random things by labeling them as performance parts. No more dealing with the Audi dealership and having to buy custom Audi specific tools. Wow. I can't believe I lived through all of this. Money pit.
    Established Member Two Rings c615586's Avatar
    Aug 10 2009
    2007 RS4, 2016 Volvo XC90 T8 Inscription Hybrid, 2013 Carrera 4S Cabrio
    Upper Arlington, OH
    How much for the scanner?
    Senior Member Two Rings Bigjuice's Avatar
    Dec 31 2005
    Atl
    I have the same problem with my car..
    Hopefully should have it back next week, since i'm having the intake removed going to do the carbon clean, intake spacers, and metal linkage arms done.
