AUDI MK2 TTS COLD AIR INTAKES
Add horsepower, torque, sound, and throttle response to your Audi MK2 TTS with this lightweight and attractive carbon fiber intake kit.
VIDEO OVERVIEW
FEATURES:
INCREASED HORSEPOWER & TORQUE
ENHANCED ENGINE, TURBO, & BLOW-OFF SOUND
HIGH-FLOW BELLMOUTH
MASSIVE OVER-SIZED AIR FILTER
REAL CARBON FIBER
EASY INSTALL USES FACTORY MOUNTING GROMMETS & HARDWARE
HEAT SHIELDING & DIRECTED AIR FLOW
REINFORCED SILICONE HOSES
OPTIONAL NOISE DOORS
CARBON FIBER VELOCITY STACK
Shove your turbo a supply of cold air with a generously-sized inlet pipe that connects to the OE mass air flow (MAF) sensor to our high-velocity 5" velocity stack. This bellmouth design increases the air velocity to the MAF and pulls cold air equally from all directions into the filter. The bellmouth opening allows for a filter with a very large surface area that can support any horsepower goal tested over 500HP on our twin-scroll big turbo kits with huge success.
REMOVABLE NOISE DOORS
This feature delivers all the benefits of both a closed box and open air filter intake designs, giving you control of the intake noise. The gasket sealed "noise doors" can be installed or removed either increasing or reducing the amount of throttle and turbo noise.
CARBON FIBER INTAKE LID
The IE carbon fiber intake lid is designed to create a thermal barrier blocking all of the radiant heat from the engine bay. Only cold air from the front of the vehicle is drawn into the filter from the opening in the radiator support keeping air intake temperatures as cold as possible. This allows factory placement of the intake to be used without placing the filter lower in the vehicle where it can be subjected to engine harming road debris or fluid.
Upgrade the power, sound, and looks of your TTS today HERE.
TAKE A CLOSER LOOK WITH THIS VIDEO UN-BOXING:
