Results 1 to 28 of 28
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    Thumbs up Group Purchase - Revo S5 B8.5 3.0t Charge Cooler Package
    Description:
    The Revo charge cooler package is a direct replacement kit that offers enhanced cooling capabilities to maximize the performance of your S5 B8.5 3.0t. The supercharger on the 3.0t engine shares the coolant system with the rest of the engine, this causes temperatures to rapidly climb when driven at high speed for long periods or in hotter climates and these high temperatures cause the car to reduce power resulting in loss of performance. The package enhances the engines cooling capabilities giving access to more power for a longer period of time. The direct-fit standalone system has unique features that optimize the entire cooling system, a larger heat exchanger, the addition of a dedicated coolant reservoir and custom silicone hoses and fixing brackets. This offers more consistent and lower intake temperatures especially at the top end of the rev range and when in high temperature usage.
    Heat Exchanger:
    To achieve more effective cooling, the heat exchanger has a much larger surface area than the OEM part and has over 50% more volume. The increased amount of coolant within the system means it has more to work with, effectively slowing down how quickly the OEM pump needs to move the coolant around and giving it more time to cool in the heat exchanger. The Revo engineers did not want to only increase the size of the cooler, but to ensure that it operated more proficiently than the stock part. Each end tank has been designed with specifically placed bars that evenly distribute coolant throughout the cooler, allowing more time for it to dissipate heat while in the core.
    Divorced Cooling System:
    As a standalone system with a dedicated reservoir, the Revo charge cooler system operates far more efficiently, introducing more coolant to the system and reducing pressure on the OEM coolant pump. Dedicated to cooling the supercharger alone, the Revo system also allows the rest of the engine to cool itself more efficiently. The system has been designed with subtlety in mind and will fit directly in to the engine bay without any need for modifying.
    Fitting Equipment:
    As well as the brackets and fixings, the Charge Cooler Kit also comes with Cad designed silicone hoses to re-route the coolant. Manufactured using automotive grade silicone and the highest quality polyester fabric, the hoses are built with four plies to ensure optimum strength and reliability.
    Performance:
    Temperature testing was carried out to ensure that the new Revo system was doing its job. Carrying out consecutive high-speed runs of 0-160mph, the team were able to mimic the extreme scenarios that result in high intake temperatures and subsequently a loss of power. This was done at a private test track rather than on a dyno to ensure airflow was realistic. It was also noted that when at normal driving speeds there was a reduction in intake temperatures of between 3-6°C with the Revo charge cooler fitted, compared to the same run with the OE cooler. The graph shows the 1st and 5th of 5 back to back runs with both the stock heat exchanger and the Revo Charge Cooling System. Each run was 0-160mph and air temperatures ranged from 17 - 20°C, with the Revo charge cooler system remaining 12° C cooler than the Stock system after the 1st Run.
    • - 50% Larger Surface Area over Stock Cooler
    • - Optimized Charge Cooler End Tanks
    • - Divorced Cooling System with Separate Reservoir
    • - Dramatically Lowered Intake Charge Temperatures
    • - More Consistent and Increased Performance
    • - Direct Replacement Package
    • - Laser Cut Steel Brackets for a Seamless Installation
    • - High Strength Thick Walled Silicone Hoses
    • - Worry Free Fitment without Modification
    • - Designed and Developed in the UK
    • - Fitment is only for the B8.5 models
    (Retail) - Revo S4 B8.5 3.0t Charge Cooler Package - $1199.00 each
    10+ Pricing is Live!
    Order Here - Charge Cooler | Revo S5 3.0t
    These are in stock with Revo and ready to ship. Once we hit the 10+ mark they will begin shipping immediately!
    Questions:
    If you have any questions or other needs please post here, PM or email: [email protected]
    Thank you,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Aug 07 2008
    Dallas, TX
    Still looking for some more folks for that 10+ pricing.
    This package is a great value compared to options that are similar which cost quite a bit more.
    Cheers,
    www.europrice.us
    [email protected]
    Dec 30 2012
    2018 S5 Sportback, 2019 A3 S-line.
    Beaverton, Oregon
    I'm in, email sent.
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by oldzmann View Post
    I'm in, email sent.
    Thank you for joining!
    www.europrice.us
    [email protected]
    Senior Member Three Rings BuffDavid's Avatar
    Aug 15 2016
    2015 Jeep Grand Cherokee Limited 2012 Hyundai Genesis Sedan 5.0
    Jacksonville, Florida
    Im interested in this...when's the cut off date for the deal?
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by BuffDavid View Post
    Currently looking at however long it takes to get 10+ and then the website goes live with the group purchase pricing which lasts 1 week for anyone interested. However I do need interested buyers to send a PM or email with their info. This allows me to get a headcount and unlock that pricing ASAP vs. people waiting for 10 other people to show up. If we don't get to 10 the group can decide on 5-9x pricing or continue to look for a few more buyers.
    These are ready to ship, zero waiting like with other purchases or sales, plus it's the best bang for your buck at this pricing!
    www.europrice.us
    [email protected]
    Aug 07 2008
    Dallas, TX
    5-9x pricing is locked in, but 10+ is definitely do-able.
    I have received a large number of PM's and emails asking when the 10+ pricing will happen. If just even a few of you who are asking about the 10+ pricing would confirm you'd like to buy at the 10+ pricing I could open this up right away!
    So if you are seriously interested at the 10+ pricing please send over this info via PM or email and the 10+ pricing can go up on the site for a week for everyone to buy at: [email protected]
    Full Name
    Shipping Address
    Audizine Name
    Email Address
    Current Year, Model
    You don't have to send money, you don't have to sign in blood, just send that info over and the second we hit the 10+ mark you can purchase on the site!
    Kits will ship 1-2 business days after you order depending on the time of order, no waiting!
    Cheers,
    www.europrice.us
    [email protected]
    Aug 15 2016
    I'm interested in the idea of a better cooling system for my car,but I can't find any good reviews, videos or comparisons to the other available products. I'm on the fence right now...
    Aug 07 2008
    Dallas, TX
    It's a new product so you won't have a larger number of users, just like with any newer items, so there won't be a ton of independent data. The concept itself is very simple and multiple other tuners are working with the same simple concept, replace the small charge cooler with a much larger and more efficient heat exchanger and separate out the cooling loops so that the coolant running in the newer, larger, more efficient heat exchanger is primarily for cooling the intake charge versus also cooling the engine. Also with increased coolant volume you have more heat holding and shedding capacity.
    The biggest benefits are made with the much larger heat exchanger which has more frontal service area to shed heat in the coolant that is used to cool the intake charge. Then add in the divorced system and you help to alleviate extra heat having to be dealt with in the charge cooling loop, it can be used specifically for cooling the intake charge versus the engine. Add in more coolant volume and this helps as well. Each step incrementally helps a bit more, however the size of the benefit becomes less with each additional component.
    This is why Revo did not see the cost-benefit of adding an expensive pump. The small benefit of an upgraded pump does not outweigh the cost and makes this kit the best bang-for-the-buck option available. Even better when you knock off 20% off the retail!
    You can read more here: http://www.revotechnik.com/product-d...i&engineid=146
    Also for anyone interested, installation instructions: http://www.revotechnik.com/useruploa...rge_cooler.pdf
    If you or anyone else has more questions don't hesitate to ask.
    Cheers,
    www.europrice.us
    [email protected]
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by adamkb26 View Post
    I'm interested at the 10+ pricing as well.
    If you or anyone else is interested at the 10+ pricing please confirm via PM or email with the following information:
    Full Name
    Shipping Address
    Audizine Name
    Email Address
    Current Year, Model
    One we hit the 10+ mark kits will ship 1-2 business days after you order depending on the time of order, no waiting!
    We are very close, but lost one buyer over the weekend due to other financial obligations. I'd love to get this 10+ pricing set on the website, but instead of folks confirming I keep getting emails/PM's about interest and if we hit the 10+ mark. If everyone that is seriously interested confirmed we'd hit the 10+ mark pricing so easily...
    www.europrice.us
    [email protected]
    Established Member Two Rings Siopao's Avatar
    Aug 22 2016
    2019 A7 2021 Q7 (wifey)
    Houston, TX
    Quote Originally Posted by Alex@Europrice View Post
    Full Name
    Shipping Address
    Audizine Name
    Email Address
    Current Year, Model
    With this cooling system would it matter that I have an apr tune or do you need a revo tune to get optimal usage of this cooling system?
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by Siopao View Post
    You can use with any software, stock, stage 1 or 2 from any tuner to take full advantage of this charge cooler setup. All the software types will respond accordingly to lower IAT and especially with stage 1 and 2 software the cooler intake charge will keep power more consistent and at the higher achievable end of the tuner's power claims.
    Cheers,
    www.europrice.us
    [email protected]
    Aug 07 2008
    Dallas, TX
    How many more do we need?
    3x more confirmed participants and this pricing goes live on the site for a week for anyone and all to buy at!
    www.europrice.us
    [email protected]
    Sep 30 2009
    b
    with the delta being larger with this aftermarket kit, doesn't that indicate that something is bottlenecking the performance?
    Aug 07 2008
    Dallas, TX
    Which delta are you referring to?
    www.europrice.us
    [email protected]
    Aug 22 2016
    Houston, TX
    Im in email sent
    Aug 15 2016
    Guess I'm going to have to sign up for this as well...
    Sending email in a bit.
    2013 S5 Prestige APR Stage 2 ECU Tune | APR TCU Tune | APR Supercharger Pulley | RS5 Black Grille | H&R Sport Springs | AWE Tuning S-Flo Carbon Intake | 034Motorsports X-Brace + Transmission Mounts and Rear Differential Mounts + Rear Sway Bar | CR-15 Front Tower Brace Bar | Carbon Fiber Vinyl Wrap Straight Down the Middle plus Window Trim and Windshield Trim.
    Aug 07 2008
    Dallas, TX
    Im in email sent
    Thank you!
    Getting very close now! I suspect after this week the 10+ pricing will be good to go!
    www.europrice.us
    [email protected]
    Aug 22 2016
    Houston, TX
    Hey alex,
    With the Revo system did they design away to ensure the system remains air free? *Does it have some kind of plug so you can bleed the system?
    Aug 07 2008
    Dallas, TX
    Hey alex,
    There is an additional bleed screw on the charge cooler top which is kept open when the new separate Revo reservoir is filled. With that being said it is always recommended to use a pressurized coolant system to 100% ensure the entire cooling system in the car is air free. The factory bleed screws do work as well and Audi suggests also to pull back the coolant hose for the heater core as well until coolant leaks out as that is the highest point in the cooling system.
    Cheers,
    www.europrice.us
    [email protected]
    Aug 07 2008
    Dallas, TX
    This pricing will be available through 9/27 only!
    Thank you for your orders!
    www.europrice.us
    [email protected]
    Aug 07 2008
    Dallas, TX
    Keep the orders coming and make some more power!
    Only 2 more days to get 20% off!
    Thanks again,
    www.europrice.us
    [email protected]
    Aug 07 2008
    Dallas, TX
    Couple of stragglers missing out on the 20% discount for a great bang for your buck system.
    For those last minute folks, held until 10/1. Pricing goes back to retail 10/1...
    www.europrice.us
    [email protected]
    Aug 22 2016
    Houston, TX
    Cant wait to get it slapped on with my revo stage1+. #neatlyshipped!!!
    Sent from my SM-G935T using Audizine mobile app
    Aug 07 2008
    Dallas, TX
    Looks great! Can't wait to see the install and hear about the consistent performance gains!
    Thanks again,
    www.europrice.us
    [email protected]
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Thanks again,
    Do you have an installation manual?
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by yjypm View Post
    www.europrice.us
    [email protected]
    Oct 08 2015
    Thanks. Looks exactly like how awe's coldfront installation.
    Current: '18 M3 ZCP
