Results 1 to 34 of 34
    Dec 16 2014
    Irvine, CA
    Stock Pistons Ugraded Rods Shortblock
    Any shops sell 2.7T shortblocks with stock pistons and just upgraded rods?
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    No? You'll need to source the parts yourself.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    Yes IE does that.
    Dec 30 2009
    Didn't see any 2.7t short blocks on IEs site.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Sep 07 2012
    Tucson, AZ
    Quote Originally Posted by Timtheguru View Post
    Did you call them and ask?
    Most people just do it all themselves with this platform. It's a little time consuming, but much cheaper if you have the time and know how.
    Dec 30 2009
    Quote Originally Posted by LightningLou View Post
    Why would I call them? Should I call all of the shops in the US to find out if they have shortblocks with only upgraded rods for some random forum question that wasn't asked by me?
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Sep 07 2012
    Tucson, AZ
    I thought you were the OP dude, my bad... I've never heard of IE building shortblocks either, but I'm sure they'll have an answer over the phone if it isn't listed on their site. If there's enough demand for it I'm sure they'd list it on their site, but there likely isn't for various reasons.
    Dec 30 2009
    No worries. :) I only ask questions you could easily have googled an answer for me.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Apr 07 2011
    Home of the mighty beaver
    VAG offerered me a complete assembled longblock with upgraded rods
    for 5000$
    i assume it was made out of gold.
    Sep 11 2009
    NE
    Do it yourself or pay through the nose....
    http://www.eurospecsport.com/products/engines/v6-5v.htm
    Apr 07 2011
    lol... im just getting a local machine shop to measure and refresh where needed. Its not rocket science, i dont know why people charge a fortune
    Dec 16 2014
    Irvine, CA
    Quote Originally Posted by aysix View Post
    Yes IE does that.
    I emailed them, they said they don't offer any 2.7T shortblocks at all, just parts.
    Feb 06 2012
    Las Vegas
    Quote Originally Posted by Kaane View Post
    I must have mistaken them for eurospec
    Feb 21 2012
    MB S55 - (607hp/671tq), Suzuki GSXR 1000
    Chico/CA
    Plenty of resources to do it by yourself, otherwise expect to pay out the ass. I got my BEL block for $400, disassembled, flex honed, added bearings (main/rod) and new rings. Total to this point is about $1200, which I would expect to pay 3x that at a machine shop or knowledgeable garage if I wasn't doing it myself.
    2000 Laser Red Stage III+
    Senior Member Two Rings joeSfour's Avatar
    Nov 09 2011
    South Bay, CA
    Quote Originally Posted by julex View Post
    Please do not go this route....I've only had bad experiences myself, and have not heard of many successful scenarios.
    Current - 2001 B5 S4 Imola Avant
    2009 VW GTI
    Past - 2002 B5 S4 - 034 STK 5858 PT fully built 3.0L
    Dec 16 2014
    Irvine, CA
    I will probably do it myself, was just wondering if there are any vendors offering such a combination.
    I still want the machine shop to at least clean the block and hone it. I can get new rings and bearings and the rods.
    I was checking elsa for motor specs and it only shows a range. What piston ring gap should I be shooting for? Bearing clearance? Plastigauge good enough or should I invest in a bore gauge?
    Sep 07 2012
    Tucson, AZ
    Whatever you do, just make sure you find a good machine shop that can balance your crankshaft with new rods. I swear my engine has much less vibration than it did stock after installing rpm i-beams and getting crankshaft re-balanced to new rotating weight. Well worth the $150 or so for the peace of mind that your new engine will run like a top. ;)
    Feb 21 2012
    Chico/CA
    You will need a bore gauge (if you get a snap bore gauge you will also need an outside micrometer) and plastigage. I have recorded all specifications as I go along building my motor. I personally did my rings as follows - 1st Ring .45mm 2nd Ring .60mm 3rd Ring .48mm , I have a build thread on AR under the B5 section, which I copy and pasted from there so some of the illustrations that I made aren't lining up here very well. Hope it helps.
    Axial Clearance -> When New Wear Limit
    .090-.251 mm .28 mm
    *Do not interchange used bearings
    -Attach dial gauge with universal dial gauge bracket VW 387 to oil pump and bring it into contact with crank web.
    -Press crankshaft against dial gauge by hand and set gauge to -0-.
    -Press crankshaft away from dial gauge.
    Radial Clearance -> When New Wear Limit
    .018-.045 mm .10 mm
    *Measure radial clearance with Plastigage
    Crank Shaft Bearing Caps
    -Bearing #1 is Toothed Belt End (oil pump)
    Tightening Sequence (Arp Main Stud Kit and Factory Stretch Bolts)
    -| |- Toothed Belt End
    A | 14 6 5 13 | A
    | 10 2 1 7 |
    | 12 4 3 11 |
    A | 16 8 7 15 | A
    Flywheel End
    Stage 1 -> 30 nm
    Stage 2 -> 60 nm
    Stage 3 -> *Arp = 100 ft/lb or Stock bolts = 90 degrees further (30 nm, 60 nm then 90 degrees)
    A= 25 nm
    Cylinder Bore - use a Snap Bore Gauge and Outside Micrometer or a Cylinder Bore Gauge
    _________________
    | | Measure for cylinder roundness @ 3 points (1,2,3)
    (1) | | (1) 10 mm down from top of cylinder
    | | (2) ~in the middle of 1 & 3
    | | (3) 10 mm up from bottom of cylinder
    (2) | |
    | | Honing Dimensions:
    | | Cylinder Bore Diameter 81.01 mm (nominal)
    (3) | | Service limit = Nominal - Actual must be less than .08 mm
    Piston Diameter and Ring Measurement
    Measure 10 mm from skirt bottom, 90 degrees to piston pin axis.
    Piston Diameter = 80.95 mm (nominal)
    Nominal - Actual must be less than .04 mm
    Piston - Ring to Grove Clearance
    when new wear limit
    .02 - .08 mm .10 mm
    Piston Ring Gap
    *Push ring in squarely to a position approx. 15 mm from bottom end of cylinder
    when new wear limit
    Ring 1 .35 - .50 mm 1.0 mm
    Ring 2 .50 - .70 mm 1.4 mm
    Ring 3 .25 - .50 mm .8 mm
    I used Weisco Piston Ring installation instructions for Ring placement and Ring Gap theory. If you cannot locate it on the web, pm me and I will email a PDF version.
    Connecting Rods
    *Only replace complete sets of connecting rods
    *Do Not interchange connecting rod bearings
    Radial Clearance:
    - If reusing bearings, mark with a felt pen first. (personally, I recommend new bearings, especially if flex honing)
    - Remove connecting rod bearing cap. Clean bearing cap and bearing journal.
    - Place a length of Plastigage corresponding to width of bearing on bearing journal or bearing shell.
    - Install connecting rod bearing cap and tighten to 20 nm (use old bolts). Do not rotate crankshaft.
    - Remove connecting rod bearing cap again.
    - Compare width of Plastigage with calibrated scale.
    Clearance when new Wear Limit
    .015 - .062 mm .12 mm
    Installation and Torque (arp)
    *Bearing Tangs face exhaust side of motor (per IE directions)
    -With new connecting rods bolts, install and tighten hand tight.
    Tightening Torque:
    Stage 1 = 30 nm
    Stage 2 = 30 ft/lb
    Upper Oil Pan
    -There is no gasket between the block and upper section of pan. Only use silicone sealant D 454 300 A2 or equivalent (I used Victor Reinz - Reinzosil). Thickness of sealant bead should not exceed 2-3 mm, any larger puts a risk of sealant getting into oil strainer/lines.
    -Tighten all securing bolts to 5 nm initially, then
    -Tighten bolts securing oil pan to cylinder block in diagonal sequence to 10 nm
    -Tighten M10 bolts securing oil pan to cylinder block to 45 nm
    Front Sealing Flange (Install this prior to the Oil Pump and supply lines)
    -Attach chain to Oil Pump Drive gear on crankshaft.
    -Apply Sealant to oil pan, but DO NOT put sealant on sealing surface of the cylinder block.
    -After installing gasket on sealing surface of the cylinder block, apply a small amount of sealant to the joints between oil pan and front sealing flange.
    -Tighten Torque: M6 = 10 nm, M8 = 20 nm,(4) bolts in oil pan = 10 nm
    *I put a new crankshaft oil seal before installing Front Sealing Flange
    Oil Pump and Oil Pump Drive Chain
    -Before bolting down Oil Pump, install short oil line into pump and upper section of oil pan with new O-Rings
    -Tighten (3) Hex bolts to 25 nm to secure Oil Pump in place.
    -Push longer Oil Supply line into Front Sealing Flange with new O-ring
    -Attach chain to Oil Pump Sprocket and fit on Oil Pump shaft (there is a specific orientation)
    -Tighten T45 bolt to 25 nm
    Lower Oil Pan
    -Install new gasket on lower section of oil pan and install on upper section of oil pan with two diagonally opposite bolts (I have conflicting info here, most say a sealant gasket while Elsa says to not use any adhesive or sealant, I elected to purchase the gasket for the 2.8l 30(v).
    -Tighten all securing bolts hand-tight.
    -Tighten bolts to 10 nm, working from center outward.
    Crankcase Breather Housing (Valley Pan Gasket)
    -Always replace Gasket
    -Tighten to 10nm
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Great info HighPSI
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    If you want to spend $5k call eurospec!
    If you want to spend $1k + your time
    do it yourself. Or just pull the motor your
    self and find a competent machine shop
    to build your motor. For just a hone, checking
    bearing clearances, and reassembly should
    run you under $1k for labor.
    Nov 14 2013
    For engine internal specs all-data
    provides all of them as does the bentley
    manual.
    Nov 14 2013
    Also for those doing a big build
    a flex hone is garbage. The way
    to get a good hone is on the machine.
    No way around that.
    Feb 21 2012
    Chico/CA
    A flex hone should only be used to break the glaze and create cross hatching on the cylinder wall(s) before installing new rings, that is its intended purpose and works perfectly fine for that.
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    If you're just planning to do rods, you can just do rods (and new rod bearings/gaskets). Rod bearings are only $60 for the set.
    You can reuse your piston rings if they are in good condition. They are made by Mahle and are of very good quality. So are the pistons. By reusing rings you can avoid getting a hone and not touch the cylinder walls at all. You can verify them, but these engines are very robust and should be in good condition inside. Just make sure to mark each piston/ring and which respective cylinder each one of them goes to. You can clean the pistons using the scotchbrite purple pads and some brake cleaner.
    IE is a great choice, although the RPM rods have been used with much success and cost around $400-500. I bought my H-beams brand new for $375 shipped. They come with ARP 2000 bolts as well.
    I avoided touching my crankshaft after seeing how it was in great shape (no play or wear) and how I've heard many people run into problems after messing with the crank. I'm not saying that you shouldn't, but in my case, I decided to keep things as simple as possible for the build.
    So far, my build (engine wise) has only cost me rods, rod bearings, and gaskets. You can view my build thread--it is linked in my signature. So far, I have completed the assembly of my bottom end.
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Apr 07 2011
    Great guide. Totally going to use this.
    Sep 11 2009
    NE
    Quote Originally Posted by Wagonholic View Post
    Stuff
    I did exactly this as well. I haven't touched crank after measuring run out and play. Only took out pistons, swapped a few questionable rings, new rod bearings and done.
    However, if you notice that you have old APB block in your engine, it might be a good idea to get BEL block and start fresh.
    May 27 2016
    Westchester, NY
    I thought the APB blocks were good just not as beefy as the BEL units.
    Mar 01 2014
    Los Angeles, CA
    I have a later APB/BF block. I should be okay. Lol.
    I had one questionable ring that I decided to replace. I didn't hone, since it was only one ring, and these cars have an IRON block and moly rings. It all spec'd out nicely.
    At 137,XXX miles, my internals were flawless, and the factory hone/cross-hatching was still existing.
    Last edited by Wagonholic; 08-11-2016 at 01:53 PM. Reason: Mistyped aluminum block instead of iron block
    Justin
    #YEengineering
    Dec 10 2013
    Borden, Ontario, Canada
    Might wanna re-check your wording. These blocks are Iron, not Aluminum
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Mar 01 2014
    Los Angeles, CA
    Quote Originally Posted by Bordom View Post
    Yes, my bad. Thanks for catching that lol. I meant iron; got confused with the heads, which aluminum.
    Anyway, my point was a hone is not completely necessary if you are just replacing a single ring here and there. The new ring will also wear to the cylinder wall and create a seal.
    Justin
    #YEengineering
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    A hone no, but a deglazing of the walls should be done so it has something to bite into
    Feb 21 2012
    Chico/CA
    As VR said, a deglaze is 100% necessary, especially if you are putting new rings in (I personally don't see the point of pulling pistons to reuse old rings when it is like an hour extra and maybe $80 additional, but I also don't see the point of pulling the motor and not doing crank bearings/arp stud kit).
    Nov 12 2013
    '01 S4 Tip '91 200 20VTQA, '01 A6 2.7TA, VW Rabbit GTI truck.
    SanHo, CA
    Quote Originally Posted by HighPsi(NorCal) View Post
    Exactly. Why spend eleventy-million bucks on your build and not do a complete bottom end freshen-up. Especially if you're doing rods. Cost another 400 clam at the most and you've got a block ready for anything up to 600hp and another 100k plus.
    Nov 14 2013
    ^^^This!
