Tell me this, the low pressure fuel sensor is located on the side of the hpfp and the high pressure fuel sensor is on the fuel rai on the engine correct? Is the low pressure fuel sensor also known as the thrust sensor? Given the codes im getting consistently (P2294 P0089) it leads me to believe that the low pressure fuel sensor (if thats the one on the hpfp) is bad. I went to change it out with the one on my old pump and noticed it was just re-used on the new pump. I bet that happened last time too. Am I on the right track? Also is there something special I need to do to after replacing it? I was reading and it said to run 302 or 301 on vag after replacing or something or do you just put the new one on and go? Ive done a bunch of searching but cant find any clear answers and when I do I cant seem to find the page again. Thanks guys.
