Results 1 to 18 of 18
    Deactivated Two Rings
    Aug 30 2013
    Dealer says motor mounts are broken
    Hi all,
    My A7 is in for service to replace the fuel pump but as they were diagnosing it they found that the left and right motor mounts were torn. I was quoted $2,500 to get the motor mounts replaced. Could I possibly order the mount parts online and get this done elsewhere?
    Thanks,
    Joel
    Senior Member Three Rings 2wookies's Avatar
    Jun 03 2016
    Omaha NE
    Of course, just get the part numbers.
    Mar 29 2014
    Hampshire, UK
    Are you not still under warranty?
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Aug 30 2013
    No I'm not under warranty anymore, it's at 60k right now.
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    LMAO! Effin' stealerships! What a crock. I'd definitely go somewhere else with the OEM parts to be installed. Alternatively, there may be a nice upgrade out there that is more durable. I haven't looked personally.
    I don't know what the process is on the C7 but I've done plenty of other mounts on my own and none were all day affairs. They probably have to support the motor, drop the subframe, swap them and then re-align the subframe. They have all the fancy tools and the jig at the dealer too. They should be more fair about this but their not because they can be.
    What a joke. Sorry to hear. It really isn't uncommon to snap stock mounts in cars producing much more Tq than stock. Especially if you do any launches or are heavy with the right foot in general.
    Do it right, or don't bother.
    Dec 01 2011
    that's definitely way too high just for mounts.
    you can find your parts here: https://www.ecstuning.com/Audi-A7-C7...Engine_Mounts/
    left: 4G0199381LE
    right: 4G0199381LF
    look up the part #s on diff sites if you want as well may find it a bit cheaper. and labor is maybe like 2-3 hrs for a decent shop, shouldn't be more than like $1k total for parts & labor.
    also before you do anything i'd maybe just get the mounts looked at again by a good independent shop, they can at least confirm for you if you do need to replace them, stealership may just be talkin BS, seems a bit early for mounts to go bad like that but who knows. do you feel vibrations or anything weird or have you not noticed any issues? if not you can prob just hold off on them unless they are diagnosed to be bad. also i'd probably stick to OEM because you could maybe find some stiffer aftermarket ones but they are more performance oriented and from what i've read the stiffer mounts can get a bit uncomfortable and too rigid for a daily driver so you may end up not liking the harder feel after that.
    IG @theshawon
    Aug 30 2013
    The car does vibrate quite a bit when it's parked which was one of my concerns when I dropped it off. I'll have a shop look at it sometime this week. Thanks for the part numbers/info btw.
    Mar 07 2004
    2025 Q7, 2018 TTRS, 2022 Q5
    Charleston, W.V.
    Check with 034 Motorsports to see if they have motor mounts for your car.
    Aug 30 2013
    Will do, also got a quote for $350 installation from a trusted shop. With the left and right mounts from ECS it brings it down to a much better price.
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    I recently had both motor mounts replaced at the dealership and my cost was $1152 which includes $178 discount. Your dealership price quote is outlandish to the say the least. The labor hours, according to Audi, for r&r both mounts is 6 hours plus parts. My dealership charged me $436 total for both mounts.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Established Member Two Rings Winterk80's Avatar
    Feb 16 2016
    Oklahoma City
    Quote Originally Posted by JKnetz View Post
    Hi all,
    Thanks,
    Joel
    Wonder if you can add an extended warranty? ;)
    Established Member Two Rings AntonioS6's Avatar
    Jun 14 2016
    Connecticut
    shouldn't the extended warranty cost less than that?
    2018 BMW M5 Black Sapphire Metallic
    GONE - 2013 Audi S6 Phantom Black Pearl
    Dec 01 2011
    yea i think the warranty will be somewhere in that range, the longer you wait the higher it will go though, but could be worth getting the basic powertrain or silver level warranty. although now that this dealer knows about the mounts you can prob take it to another one and have them fix there under the extended warranty.
    IG @theshawon
    Aug 30 2013
    That's actually a better idea. I asked around for extended warranty quotes and was quoted $3600 for an extra 100k miles or 5 years. I think I'll go with an extended warranty and take it from there. Thanks everyone!
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    The bad motor mounts could be listed in your service history and if so, a new warranty would not cover them.
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    what are the signs or symptoms of bad motor mounts?
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Feb 16 2016
    Oklahoma City
    Glad we could help
    Junior Member One Ring ini's Avatar
    Nov 10 2008
    So Cal
    stealer ship $3601.06 for both motor mounts replacement
