Results 1 to 21 of 21
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Vibrations - prop center shaft?
    Fighting vibrations. Wheels tires balanced twice, additional 3rd time load balanced. Test with winter wheels/tires (still). Front new lower controls arms, wheel bearings, drive shafts.
    Vibrations under load and no load.
    Is there a way to test if the prop shaft might be the cause?
    I have a 2003 A6 shaft here; does it fit (both tiptronic cars)?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    overall vibration in the car or just the steering wheel?
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Feb 20 2010
    Brighton, MI
    After
    - new wheel bearing (needed anyways)
    - new drive axles (while at it)
    - new lower control arms (needed)
    - recent upper control arms
    - recent tie rods
    - new alignment
    - triple (2x standard, 1x load balancing)
    - tire/wheel swap
    then
    - 3M Window Weld treatment of center support bearing (did not look bad, but did anyways)
    I know think what is the cause of my vibrations:
    http://vid1273.photobucket.com/album...pst4bb7iio.mp4
    05 Golf TDI
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    what is that specifically? rear or front? just not tight or something?
    Feb 20 2010
    Brighton, MI
    Front left drive axle, inside joint and transmission (tiptronic 5HP19FLA) output shaft.
    https://www.dropbox.com/s/ivu5mx97ai...0left.wmv?dl=0
    05 Golf TDI
    Sep 16 2010
    Central Wash
    There's a bolt in the middle of that flange right?
    Might try backing it out, loctite, then torque it back how it gotta be. Might do it?
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by rollerton View Post
    I will take drive axle off and check. I only removed that flange on a Golf IV when we had a output shaft leak. Need to read up on the 5HP19 out flange/shaft.
    Anyone have DIY instruction how to (potentially) replace an output shaft, output shaft bearing?
    05 Golf TDI
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Not a DIY but just some advice. I followed this post to help me diag and repair my rear diff flanges
    Jun 04 2013
    SE MI
    Quote Originally Posted by tHatOne guY View Post
    got a link?
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    Wow! that does look a tad wobbly. You may have to go the Bentley route for repairs. That or ship it to Level 10
    Does the other side move as much?
    Just throwing this out there...
    What is the condition of the shocks, rear control arm bushings, rear diff mount bushing?
    http://at-manuals.com/wp-content/upl...3/ZF_5hp19.jpg
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by JayDog747 View Post
    No, other side does not move at all (compared to the observed driver side movement).
    Looking for DIY instructions how to fix the play.
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    B5 same as C5? Auto same as manual?
    Link refers to B5, not sure is auto or manual:
    Remove the exhaust
    Drain trans fluid
    Remove the LH and RH driveshafts at the trans.
    Use wire to tie them up out of the way.
    Get a couple of bolts that are the same size as the DS attachment bolts but about 2" longer.
    Use these bolts as jacking screws to remove the DS flanges.
    Remove the differential cover by removing the bolts and using a screwdriver to pry the cover off. DO NOT PRY ON THE MATING SURFACES!!!!!
    remove the differential. Once you start to move it out, you are able to change the angle and remove it fully from the trans.
    I have done this three separate times on a '01 S4, '97 A4 and a '95?? 90. Its tight, but it can be done.
    05 Golf TDI
    Jun 10 2013
    United States
    Also, you are not draining the transmission fluid with the auto. The diff has its own fluid. It will come out when you remove the flange.
    Feb 20 2010
    Brighton, MI
    Exploded view of the output shaft?
    How to remove the output shaft and the output shaft bearing?
    05 Golf TDI
    Jun 10 2013
    United States
    Not sure, I have never done this. You also should be checking lash which is set with different thickness washers. This may not be an issue, but I don't know.
    Jun 10 2013
    United States
    Maybe get Scotty@AdvancedAutomation in on this.
    Aug 20 2012
    Mesa, Az
    Quote Originally Posted by alien_brain View Post
    got a link?
    Sure, thought it got added last post. I thought my drive shaft was causing the vibes but it was just the rear diff flanges/bearings. Studied this post and the Bentley before I went at it.
    http://forums.quattroworld.com/a8/msgs/69890.phtml
    Feb 20 2010
    Brighton, MI
    Did you get new output shafts? Where did you get them from/find them?
    How bad was the wear, i.e. shaft diameter worn vs new?
    05 Golf TDI
    Aug 20 2012
    Mesa, Az
    I had to find a used diff from a local yard here in town. The diff flanges on the used diff looked pretty good. I measured a difference of .11 to .16 mm with a dial caliper old vs. newish flanges. The give away was the play I had in the rear diff flanges. The front diff had no play, none whatsoever but the rear was about 3-4 millimeters I guess.
    I only had vibes about 65 and up, esp around 80.
    Feb 20 2010
    Brighton, MI
    Thanks for the data.
    Has anyone taken measurements?
    Has anyone else found correlation between output shaft wear and vibrations?
    05 Golf TDI
