Results 1 to 31 of 31
    Jun 04 2016
    A
    a bit of a silly question regarding installation of S-Line side skirts (rocker mouldi
    Hi guys,
    I have a quick question regarding installation of the Audi S-Line rocker mouldings/side skirts; part number 8K0854931AGRU (Left hand) & 8K0854932AGRU (right Hand).
    When identifying or determining which is 'left' or 'right' is it by sitting inside the car (e.g LHD car, the LH is the drivers side) or looking at the car as if standing in front and looking at it, (that would mean the LH would be a LHD car's passenger side).
    can anyone shed some light?
    also, there are directional arrows next to the 'R' or 'L' ' --->' the arrow should point to the front of the vehicle when installing?
    thanks in advance and apologies for the inexperience.
    regards,
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    When identifying or determining which is 'left' or 'right' its by sitting inside the car! Or look car from the back.
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jun 04 2016
    A
    Quote Originally Posted by Gunnark100 View Post
    Thanks, and the directional arrows marked on the part, means it should point to the front?
    cheers
    Senior Member Three Rings burg3ngold's Avatar
    Apr 13 2016
    Washington DC Area
    Can you pm me before and after pics when your done?
    Sent from my ONE A2005 using Tapatalk
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / B7 S4 Avant 6MT / Subaru Outback Limited
    Quote Originally Posted by burg3ngold View Post
    +1
    Or if you could kindly post pics on this thread - planning on doing this next spring. TIA
    Cheers,
    Ry-man
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Are you installing with 3M tape only, or also bolting the studs into the body panel as well?
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by adamazing View Post
    No studs.. or drilling!!!!!... My dealership when car was new ,used the special automotive adhesive that's super strong.. I haven't had problems in a few years.
    I had the already painted alu optik side blade put on on which is pretty much a perfect identical match to my silver car... But I am considering wrapping them a satin black in the future......
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    I mounted mine a little lower on the side, I like the look more.
    My 2009 A4 Prem+ Build thread
    Apr 13 2016
    Washington DC Area
    Picturreeeasss
    Jun 04 2016
    A
    Quote Originally Posted by Lambda13 View Post
    Quote Originally Posted by hyperunion View Post
    I definitely wont be drilling the body of the vehicle. Yes I can see the clip in slots on the skirt (which Im guess is a different part/ part number, as it wasn't supplied anyways). I will be using specific 3M tape.
    Since you both had installed it, do you recall which way the arrow points to?
    Because from what I can see, the arrow should point to the back of the car. When I hold the skirt up against the car. If the arrow points forward, the front and rear of the skirt sags downwards. I think it should have a slight upwards curve, following the feint contours of the front and rear guards.
    Jun 04 2016
    A
    Picturreeeasss
    if your looking for finishing product pics, there are threads on this forum.
    It should look no different to an S-Line
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by doublespeeded View Post
    There should be an "L" and an "R" on each. The letter should be face up when installed. I think the arrow points towards the back? If you google image search 2011 audi rock guards you should get a pretty good indication of the direction to install them.
    Jun 04 2016
    A
    Heya, I had another look.
    From what I can see, the L & R needs to be upside down and by doing that the arrow does point backwards.
    Did anyone install the skirt with the clip on mounts? It didn't come supplied but it might be easier using it with doublesided tape/rather than drilling.
    It appears that the tape supplied with the moulding on its own is inadequate... either I need to source those clips or purchase more double sided tape and double-it up.
    Sep 03 2012
    Lehigh Valley, PA
    Body shop adhesive is only way to go... And then a few days cure...
    Sep 09 2010
    Destin, FL
    I did double sided 3M auto body tape and adhesive, they aren't going anywhere.
    Apr 01 2013
    chicago
    Logic is thrown out the door when installing these. I installed them a few weeks ago and decided it's only logical for the arrows to face towards the front. Well I ended up installing them upside down. They don't look too bad this way, just not as aggressive as it should look. Used the 3m tape and polyurethane glue. Once I realized the mistake,it was too late to take it off and redo them. The glue +tape is more than enough
    Jun 04 2016
    A
    Quote Originally Posted by joelp8835 View Post
    what do you mean by upside down?
    Its hard to upload pics, but the tip/point of the skirt, the bottom should have more of a belly shape than the top, kinda like a steak knife... where the top side is more narrow and the borrow has a larger belly shape, if that makes sense.
    Apr 01 2013
    chicago
    Yup. So the belly shape is what shows. It doesn't look too bad. Each stop has a narrow end and a wider end. The wider end should be in the front,mine is towards the back. Hard to describe and hard to tell from pictures as well
    Jun 04 2016
    A
    are you able to upload any pics? im interested to see what went wrong.
    Apr 01 2013
    chicago
    I'll upload Sunday after a wash😁
    Veteran Member Three Rings endy1's Avatar
    May 04 2014
    Sweden
    I feel you bro. I had to look at another car before i installed mine. Even asked people at work that install these "everyday." Even after that i was scared i would put them wrong.
    Apr 01 2013
    chicago
    Upside side skirts... Thoughts? Suggestions?
    2013 Audi A5 Premium Plus Phantom Black 6MT
    Nav, B/O, Adv Key, Sports Package
    Apr 13 2016
    Washington DC Area
    Yikes
    Jun 04 2016
    A
    Heya,
    Thanks for providing us with pictures.
    Nice colour and rims. I originally never liked the way Audi a5's looked but its growing on me and I love the way they have a wide stance compared to the a4.
    I think the colour (color in USA) hides it a bit... and doesn't look all too bad.
    Look, obviously you know whats wrong, but others may not... the main question is, are you happy with it?...
    You cant really tell unless you scrutinize it.
    if you ever wanted to remove it by using floss or fishing line, its quite easy and you'll know which way it should go.
    Yikes
    I don't think its that bad at all for a 'Yikes'
    Jul 07 2012
    Boston, MA
    I would definitely pull them off and flip em over. I don't think it's quite yikes, but it definitely looks off to me.
    Apr 01 2013
    chicago
    the color does hide the mistake well..I do agree, the untrained eye wouldn't quite notice. I'm going to leave it be for the time being
    Jun 04 2016
    A
    What tape did you use to fit yours?
    It looks quite flush without any gaps.
    Apr 01 2013
    chicago
    It came with the 3m adhesive tape on it . I also used polyurethane glue as well for extra hold. Besides that, used painters tape once it was applied for pressure so it's tight. There was a small gap, which I was told is normal. I do worry for the winter and water freezing and making the gaps bigger.
    Jun 04 2016
    A
    Is that the genuine rocker mouldings?
    Yeah I can see that there is only one strip of adhesive tape (possibly 3m).
    But there are slots along the skirt, which I assume to be for individual mounting pieces either glued or drilled into the car and this moulding both slides into and glued down.
    I may try some polyurethane glue also.
    ill post some pictures once complete, it will be a couple weeks from now.
    Veteran Member Four Rings diego_demarco's Avatar
    Feb 13 2014
    Ft Lauderdale
    I used the clips that came with it as well as 3m tape! Hasn't budged!
    2013 Audi A5 Cabrio! Vossen CV7s, ecs tuning carbon fiber intake, Xenonz RS5 front bumper, Apr stage 1!!
    Audis of South Florida car group!
    Follow us on Instagram
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Looks weird man.. id redo them. Knowing its not done right, it would bug the shit oit of me. Sorry this happened but u gotta do it right
    Sent from my HTC One_M8 using Tapatalk
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
