Results 1 to 30 of 30
    Aug 09 2016
    SF Bay Area
    Help my girlfriend keep the Audi: slow oil leak
    Hey guys. I usually hang out on the BMW E46 forums. I wanted my girlfriend to end up there too, but she fell in love with an Audi and I wanted her to love what she got. Today she left my place and called me when she got home that her car was giving an oil warning. Long story short, I physically checked her oil and she is just below the minimum mark. I am going to Audi tomorrow to buy her oil. She's owned the car since November, and this is the first time (that I know of...) that it has complained. Any idea where there could be a slow leak? She drives her car the way your great great great grandpa would if he was still alive, so it's not from abuse.
    I looked up some common oil leaks, but didn't see anything matching what I saw. There was some wet stuff behind the engine, on top of the transmission. It seems that that's more tied to the coolant flange. I didn't check her coolant level... Other than that: Bottom cover, clean. Bottom of car behind cover, clean. headers, dry. Right side of engine bay, dry.
    Let me know! Also, totally jealous of the wrenching space you guys have. You have to remove like 8 things to do any maitnence on my beemer!
    Oct 24 2015
    Perth, WA
    You're probably just burning it. Also rule #22.
    My respray thread
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Quote Originally Posted by YoitsTmac View Post
    Hey guys... ...I wanted my girlfriend to end up there too, but she fell in love.........and I wanted her to love what she got....
    ....Today she left my place and called me when she got home.....
    ....Long story short, I physically checked her oil and she is just below the minimum mark...
    Your thread title and description is kind of amusing. Makes one think, but anyway congrats on the ride. What year is the car and what kind of miles are we talking about? Keep your eyes around the valve gasket cover and the (lower pcv) turbo inlet tube, and yes, always make sure there is enough oil in the engine because the B7 is known to burn lots of it. 'Top her off' and you shall be fine.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Senior Member Three Rings wriscolf's Avatar
    Jul 10 2016
    1993 Nissan 240sx Convertible with Silvia Front
    As already stated the b7 is known to burn oil but there's rumors of oil type that doesn't burn. I think I read something about mobile 1. But come to think of it I think that's for the b6 1.8t.
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Common B7 oil leaks:
    - Oil filter housing / gasket (You can change the oil filter gasket and oil cooler gasket while you're in there).
    - Vacuum pump (stick your hand behind the pump and feel the hoses back there, most likely oily. Replace pump. Replacing the seal on the vacuum pump does absolutely nothing as that's not where it leaks from.
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Veteran Member Four Rings brandonpham's Avatar
    Dec 07 2014
    Belleville, NJ
    Quote Originally Posted by wriscolf View Post
    Definitely not a oil that doesn't burn. Piston rings, valve seals/guides, turbo, bad valve cover dumping oil into IC pipes, bad PCV, etc.
    Btw I hope that S13 vert has an SR in it.
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    Quote Originally Posted by Okedokey View Post
    Remember when no one would answer anything until that rule was fulfilled.
    2018 A5 S-Line Manual
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Wait. You haven't topped off oil since November and only now you have a low oil light? Wanna sell it to me? Consider you lucky kid.
    PS. Do you like to get dry raped? If so, go to Audi for oil. If you like a smoother interaction go to Walmart or Amazon.
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Feb 16 2015
    What year is the car? The earlier B7s with BPG engines seemed to have less oil issues.
    How many miles since the last oil change? For now, go to Walmart, pick up some Rotella T6 and just keep an eye on the level and top off as needed.
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    Quote Originally Posted by Copen-cisco View Post
    All of this.
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Aug 09 2016
    SF Bay Area
    First of all, thanks for the overwhelming support! She quietly talks about dumping the car during it's first issue. She gets scared because of all the time and labor I've put into my BMW, and I told her the maintenance toll is roughly the same. What she can't understand is that my car was the equivalent of a lemon. That and we paid a "premium" for this car, because we got it from an Audi dealer that I've worked closely with since then (yes, even though I own a BMW. The BMW dealer is rude as sh*t!) Her Audi is a 2006 A4 2.0T FWD. I checked the odometer and she has 54,424 miles as of this morning. Also why we paid a premium (very tip of KBB, so not too bad. It was worth it.).
    I'm happy to hear this car just burns oil! I forgot cars do this since my E46 doesn't take a drop between oil changes. In her defense, her only driving is to her clients and school, all of which are within 15 miles easy.
    I went to my Audi dealer and just got what they recommended. The cars last oil change was there, so might as well get the same oil. I don't know why you guys said Walmart and other places. The "OEM" stuff was under $10. Odd that you guys done have Audi branded oil... (living that BMW life)
    I topped her off this morning. She hates being "inconvenienced" longer than 3 minutes. You wouldn't believe the simple things she'd avoid. Last night she said, "I don't want to do this tomorrow morning." I kept asking her why, re-explaining I just had to pour it in. I basically said I'll be at your car right before you leave and you better not start it until I give it oil. I thought I trained her better than this! She knows all the BMW chassis but not the importance of oil. She unlocked her car from a distance and I had the new oil in by the time she approached the car!
    Aug 09 2016
    SF Bay Area
    Where should I be looking for these leaks? I know nothing about turbos...
    Quote Originally Posted by 80sGuy View Post
    Feb 16 2015
    A lot of people recommend the rotella T6 that you can get at Walmart b/c they have done oil analysis on it after a change and it hold up well for a good price (I have a subscribe and save from amazon for $19 per gallon delivered).
    I didn't see if you noted it, but how many miles since the last oil change?
    Aug 09 2016
    SF Bay Area
    Oh alright. Perhaps for her next oil change we will do T6, if she even wants to DIY. I asked Audi when her oil was changed, but they couldn't tell me without her VIN, so we're going to ask tomorrow. I would assume Audi would change the oil on it's own cars...
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    I switched to Liqui-moly 0w40 synthetic and don't burn a drop for the first 2,500-3,000 km after a change compared to 1/4 liter every 2 tanks on everything else I've tried (Motul, mobil1, rotella t6, and castrol). Maybe give that a shot next oil change.
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    I'll have to give the rotella t6 a shot in this thing as it did wonders on my motorcycle! I almost bought it and threw it in for shts and giggles, maybe I should've! The Kawasaki I had had wicked valve chatter from the hydraulic lifters, after the rotella the clutch grabbed better and you could barely hear the bike run!
    Its more so a weight of oil that supposedly burns less, I read a couple of threads saying when people went to 0w-40 they burned a lot less oil. Audi doesn't explicitly suggest it which is surprising to me as the lower weight causes less of a dry start especially during winter (which you want for turbo life)
    In regards to looking for the oil leaks, the oil filter housing and oil cooler are on right side of engine, it looks like and leaks from the same style plastic housing as the late 90's early 2000's BMWs which had common leaks in the same spot. The vacuum pump is on the back of the head and is like a plastic circle with a vacuum line sticking out heading towards the right side of the car, reach your hand back there (when cold!) and you can't miss it. This leak may explain the oil you saw on top of the transmission, but again. It might not be leaking at all and just burning it (theres even a warning in the oil section about how much the car will burn oil! Dont believe me, take a look!) and this isn't something that Audi figured out later, I have a 2005.5 (first year/model) and my manual warns of the car burning oil lol
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    Opened thread for rule 22, left disappointed
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Rule 22
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Jul 25 2016
    new hampshire
    Quote Originally Posted by Sanjman View Post
    Rule 22
    wut
    Eric
    Jul 25 2016
    new hampshire
    http://www.urbandictionary.com/defin...%2FLaw%20%2322
    Ah, thank you lol
    Eric
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    If shes that fussy...........hmmmmm, maybe an Audi isnt the car for her. They can be a bit temperamental...more so than the BMW--especially the E46 which I have heard is a solid car.
    Mar 01 2016
    San Diego/CA
    Vacuum pump leak can cause oil on transmission. Just try to reach below vacuum pump and check if any oil leaking.
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    Quote Originally Posted by B72011 View Post
    Which is exactly why rule 22 exists. Who can answer these questions without it?
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by onedumslack View Post
    Im not answering shit until 22 is filled.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Oct 24 2015
    Perth, WA
    Ill put this here as a proxy
    My respray thread
    Aug 17 2013
    Rossford, Oh
    hahahahahah
    Aug 09 2016
    SF Bay Area
    Had no idea what rule 22 was until the link. I thought you guys were saying that the A4's burning oil was rule 22! The photos are so not happening sorry guys! I appreciate all the help! :) *queue the mad comments*
    Jul 25 2016
    new hampshire
    HA!
    Thought it was real at first glance
    Eric
    Jul 10 2016
    Quote Originally Posted by brandonpham View Post
    Actually the s13 does not have a SR. I have everything for the swap minus motor and 5-speed swap. My audi is giving me a headache so ima have to get rid of it. Ill sell it to you with everything if you want it. Interior does need some TLC. I was literally like how the hell does he know i have a vert!? I forgot i put that on my profile.
