Originally Posted by
LINDW4LL
The fob just needs to be re-paired since you removed the battery.
I actually just purchased my A4 a couple weeks ago and one fob worked and the other (didn't try it till yesterday) doesn't, I tried doing the re-paring as per the manual (which would be the method as when replacing the battery) to no avail, I switched the batteries between the two to make sure it wasn't dead and was able to re-pair the one I had been using without issue and still could not pair the other remote.
The video posted near the top though, I have a feeling will work as it seems to be a method of "assigning" the key to the car.
danbfree
Is that where you just drive it with that key and it will do it automatically or ??? Thanks for the tips.
This doesn't work from my experience, I spent the whole day driving with the key that didn't work and it didn't do anything just as an FYI. Try the method posted above in the youtube video and I bet it will work, I will be trying it with my own key as soon as I get home as well
Unless you cannot drive with the key which would also mean you left the little security bit in the old shell, its like a glass vial with a transponder in it. If you can drive the car with the key that the remote doesn't work on then you should have already transferred everything. I'm almost positive the transponder only deals with the ignition and allowing you to drive the car, it should have nothing to do with the doors
