Results 1 to 2 of 2
Thread: Coolant Drain!
    Established Member Two Rings ecjr173's Avatar
    Aug 08 2008
    05 A4 1.8T S-Line
    Coolant Drain!
    Hey guys, so I'm replacing my thermostat and I'm draining my coolant right now. I have the front end on jack stands in order to fit a bucket underneath. Does the car have to be level in order to drain it completely. I just did a coolant flush last week cause a hose busted behind the engine. And I wanted to possibly reuse the coolant. So yea, does it need to be level. Thanks.
    05 A4 1.8T S-Line
    May 20 2010
    It helps, since the lowest point in the system is typically the lower rad hose. But not necessary for what you're doing. Keep on!
