Results 1 to 6 of 6
    Feb 22 2016
    Winchester, MA
    Neeed help to reset mileage of my B5 S4 cluster
    Like to check with fellow members if know or can refer me to someone with a VAG-COM to re-adjust the mileage of a B5-S4 cluster I have just acquired over the weekend.
    My S4 has only 110,600 and this one is over 250K.
    Thanks in advance and much appreciated.
    Best to all
    kj6304
    Veteran Member Four Rings scott1961's Avatar
    Dec 18 2007
    Boston
    Pretty sure it can't be done, I have a vag-com and know it doesn't do that. Also I bought a used cluster because I wanted to change to the white gauges it had, Audi refused to install it and said they can't be changed once they are used since info is burnt into them. So I had to take clusters apart and just change dials and needles
    2021 Turbo Blue RS5 Coupe
    2022 Blue Lamborghini Huracan Evo AWD Coupe
    Gone
    2020 Blue Lamborghini Huracan Evo Spyder
    2019 Blue Ferrari 488
    2015 Blue Lamborghini Huracan LP610 VF-800 Supercharged
    2012 Red R8 V10 6sp manual, VF-750 Supercharged
    2009 Silver R8 V8 6sp manual VF Supercharged
    2008 Black RS4 Cab
    2007 Black S4 Cab
    Feb 22 2016
    Winchester, MA
    Thanks Scott 1961 for your reply. Someone has suggested to just switch the eprom chip will do. Maybe I'll just take a photo with date before I taken out the original cluster to use as proof
    in future or send my old one to do a display replacement. Lol and things we wouldn't do with our toy. Best
    Veteran Member Three Rings Kenrevo's Avatar
    Aug 05 2013
    MA
    If you get the eprom reset you can set the millage in vag com. The mileage has to be below 65 (I think) miles to change it.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    '01.5 S4 F21 on meth -- DD
    '05 Touareg V8, loaded
    '00 A4 1.8t Avant SOLD
    '99.5 A4 2.8l 30v QMS SOLD
    Jul 11 2014
    AMA
    BBA Reman should be able to help you out.
    Feb 22 2016
    Winchester, MA
    Thank you both for the information. Will give it a try. Best
