Originally Posted by
scottay5150
I don't want it lowered anymore. Sport springs 10MM is good enough for me. Adjustable = more drop?
Here's the link to what is under the car:
http://goo.gl/RziSVj
Sent from the UnderWorld via Nexus 6P 😜
thats typically whats considered a cup kit. if its as bad as you say it is, chances are the struts are probably on there way out or already done if the spring is sagging that low. or you have other issues. throwing an unmatched spring on those struts will only have you replacing everything again a few thousand miles down the road. Id suggest doing it right the first time. if i had to guess most cup kits probably dont lower the car much more than sport suspension, adjustable coilovers would allow you to set it where you want, again, if you had them on the highest setting they probably wouldnt be much lower than sport suspension. if youre looking to get this done on the cheap and just get the car driving, id look into trying to find someone who is selling a sport suspension setup.
