    Aug 27 2008
    Houston Area
    PSA : "sealing" oil funnels
    So I got one of those funnels that locks into the valve cover and makes a seal to prevent spills as a gift. Seems like it would be really handy...
    However - just found Audi TSB : 2033576
    "Technical Background
    When an unapproved aftermarket speed-filling device is used to add oil to the engine, the increased oil flow rate may force oil into the intake manifold or combustion chamber, creating the potential for engine damage.
    ... <snip>
    Warning:
    Do not use aftermarket speed-filling devices and funnels that have an airtight seal at the filler cap, as they are not approved. Damages caused by speed-filling devices and funnels that have an airtight seal at the filler cap are not warrantable and will not be reimbursed.
    Hmmm....
    2013 6MT S5 - Monsoon/Black
    Prem+ | Sport diff | Adaptive dampers | Nav | B&O
    Res AWE exhaust | USP intake | USS Sways | OEM 19" speedline | AluKreuz | 034 Trans mount | Interior LED | VCDS tweaks | F1 tint | Xpel PPF
    Previous : 2009 6MT A4 | Quartz/Black | Prem+ 2001 5MT A4 | Silver/Black | Premium pkg
    Jun 20 2015
    NC
    I would assume they are referring to the "reel" types. At my dealer we program the amount of oil needed and pump it into the valve cover. 5 quarts happens in under 30 seconds. As long as you are pouring it conservatively, I would think you are okay
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    A funnel isn't going to hurt anything if you pour into it.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    May 17 2012
    Houston, TX
    The issue is that such a large volume of oil is poured in that it actually backs up into places you don't want it. Any non sealing funnel works just fine. There is no need to dumps several quarts in seconds. If you do, then you shouldnt be changing the oil yourself.
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by B8_Jim View Post
    Hmmm....
    this doesn't apply to your gravity fed funnel, this is for something that forcibly pumps oil in.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
