Are these modules interconnected to the point that, if one decided to shit the bed, so go the other 2?..
Any/all help would be much appreciated.
Perry
2023 S4 Prestige Mythos Black. Brembo GT BBK, APR FMIC, 034 Stg 12012 B8 A4 Avant, Phantom Black S-Line Prestige, 2014 CPMB Engine, 8 speed, JHM K04-R, Eurocode HFC, APR FMIC, 034 Alu Kreuz, Vogtland Coilovers, Stoptech 380mm BB Kit, H&R Swaybar, ECU with IE K04 Tune, Rev. "d" DV, R8 Coils, Folding Mirrors, S5 Rear Brakes, 034/Apikol mounts, OEM Facelift LED Brake lights ]
---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
---------------------2014 A4 - 6 Speed - Phantom Black Pearl -------------- Peep the Build ---------------------
"What you do in life, echoes in eternity."
Friday,21,February,2020,15:37:44:22537 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 19.6.2.2 (x64) Data version: 20200210 DS308.0 www.Ross-Tech.com VIN: WA1UFAFL5EA125319 License Plate: Mileage: 139240km-86519mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FL-AU48 (8R0) Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F 62 6C 6D 72 VIN: WA1UFAFL5EA125319 Mileage: 139240km-86519miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (DET-CPMB) Labels:. 06H-907-115-CDN.clb Part No SW: 8K5 907 115 N HW: 8K2 907 115 L Component: 2.0l R4/4V TF H09 0005 Revision: ECH09--- Coding: 722A0013242600062000 Shop #: WSC 26058 003 1048576 ASAM Dataset: EV_ECM20TFS0118K5907115N 001006 ROD: EV_ECM20TFS0118K5907115N.rod VCID: 3D718271AC29A7A78E-8068 1 Fault Found: 12620 - Sensor for Fuel Composition / Quality (G446) P0177 00 [040] - Implausible Signal Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 4 Mileage: 138219 km Date: 2020.02.12 Time: 10:53:16 Engine speed: 1082.50 /min Normed load value: 53.7 % Vehicle speed: 0 km/h Coolant temperature: 6 °C Intake air temperature: 7 °C Ambient air pressure: 990 mbar Voltage terminal 30: 12.887 V Unlearning counter according OBD: 40 Engine status: COENG_RUNNING Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3 Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 8K1 927 158 HW: 0BK 927 156 AL Component: 0BK 20TFSIUSA H16 1005 Revision: --H16--- Coding: 000002 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMAL551211 002022 ROD: EV_TCMAL551211_002_AU48.rod VCID: 74E76755DFE326EFB1-8020 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb Part No SW: 8K9 907 379 P HW: 8K9 907 379 P Component: ESP8 quattro H09 0020 Revision: -------- Serial number: -------------- Coding: 0E1D1801 Shop #: WSC 06335 000 00000 VCID: 4FADC8B91E8525376C-801A No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 JP HW: 8K0 907 064 JP Component: BCM2 2.0 H14 0650 Revision: 00002001 Coding: 0D824040000000000000 Shop #: WSC 06335 000 00000 VCID: 071D2099B6753D77E4-8052 Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E Component: J764 ELV MLB H40 0046 Serial number: 0214000026335011 1 Fault Found: 00956 - Key 2 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 136 Mileage: 132337 km Time Indication: 0 Date: 2019.11.29 Time: 14:12:29 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8K1 820 043 T HW: 8K1 820 043 T Component: KLIMA 3 ZONEN H04 0123 Revision: C1000000 Serial number: 01210220141853 Coding: 6480208000 Shop #: WSC 06335 000 00000 VCID: 39799661B0019B87A2-806C No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH Component: BCM1 1.0 H16 0103 Revision: 08016001 Serial number: 00000063628901 Coding: 26000091863CAFC00000480300003D0D0F1C4708A2090221000008004000030100000030000000 Shop #: WSC 06335 000 00000 VCID: 78FF5365CB8B428F9D-802C Subsystem 1 - Part No SW: 8K1 955 119 B HW: 8K1 955 119 B Labels: 1KX-955-119.CLB Component: MITSUBA130214 H18 0461 Serial number: 1402120701305 Coding: 004577 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 22294752 Coding: 02005D Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 Serial number: 00000000002102140608 Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0030 Serial number: 0000002274555RA1QX03 Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 Serial number: 6D280217000000000001 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8K0-959-655.clb Part No SW: 8K0 959 655 M HW: 8K0 959 655 M Component: AirbagVW-AU10 H47 0610 Serial number: 003KEDB033R8 Coding: 303844354A32303030304A55304C384B3053 Shop #: WSC 11868 002 1048576 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 479DE099FEF5FD7724-8012 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C Component: BF-Gewichtss. H02 0040 Serial number: 5810000R140000HAR3 Crash sensor for side airbag: driver side: Serial number: 6334MSME435A530EH Crash sensor for side airbag: front passenger side: Serial number: 6344MSME433D1A56J Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME533E0166F Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME343E5352H Crash sensor for front airbag: driver side: Serial number: 63732SME133F374E6 Crash sensor for front airbag: front passenger side: Serial number: 63832SME0C3F56604 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q Component: Lenks.Modul H03 0003 Revision: C0062331 Serial number: 90862NBO001I5 Coding: 000037 Shop #: WSC 06335 000 00000 VCID: 489FE3A5FBEBF20F2D-801C Component: E221 - MFL H03 0004 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 983 F HW: 8K0 920 983 F Component: KOMBIINSTR. H35 0564 Revision: 00100000 Serial number: ZAA54YM2F Coding: 8BB629020301D705020000 Shop #: WSC 06335 000 00000 VCID: 387F93658B0B828F5D-806C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8R0 907 468 P HW: 8R0 907 468 D Component: GW-BEM 5CAN-M H11 0060 Revision: 1Z120030 Serial number: 3041Z142110ADB Coding: 80C303FF00 Shop #: WSC 06335 000 00000 VCID: 4C97DFB5EF931E2F09-8018 Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181 Component: J367-BDMHella H03 8041 Serial number: 3226902503 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8K0 959 760 D HW: 8K0 959 760 D Component: MEM-FS H06 0077 Revision: AA000000 Serial number: 00000091708054 Coding: 00581B00000000000000 Shop #: WSC 06335 000 00000 VCID: 3B758C69BA3DA997B0-806E No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb Part No SW: 8T0 907 566 B HW: 8T0 907 566 B Component: SWA Master H05 0071 Serial number: 0327637721 Coding: 010211 Shop #: WSC 06334 000 00000 ASAM Dataset: EV_LaneChangAssis 001020 ROD: EV_LaneChangAssis_AU21.rod VCID: 3F8DF879A625B5B79C-806A Lane Change Assistant 2: Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B Component: SWA Slave H05 0071 Serial number: 0326903177 Coding: 010211 2 Faults Found: 733440 - Control Module for Lane-Change Assist C1114 F3 [008] - Limited Visibility Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 60 Mileage: 137640 km Date: 2020.02.06 Time: 12:19:13 733696 - Control Module 2 for Lane-Change Assist C1115 F5 [008] - Limited Visibility Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 4 Reset counter: 60 Mileage: 137650 km Date: 2020.02.06 Time: 12:27:14 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 R HW: 8K0 959 793 P Component: TSG FA H02 0510 Revision: Serial number: 0000092310458 Coding: 011C13205E00410001 Shop #: WSC 06335 000 00000 VCID: 4FADC8B91E8525376C-801A No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb Part No SW: 8K0 909 144 G HW: 8K0 909 144 B Component: RCEPS H40 0508 Revision: 00001000 Serial number: 0011300696 Coding: 100000000001 Shop #: WSC 06334 000 00000 ASAM Dataset: EV_RCEPSAU48X 008015 ROD: EV_RCEPSAU48X_008.rod VCID: 35619A5194197FE746-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 JP HW: 8K0 907 064 JP Component: BCM2 2.0 H14 0650 Revision: 00002001 Serial number: 0327822326 Coding: 0126023A20BA709580B0023200000000 Shop #: WSC 06334 000 00000 VCID: 071D2099B6753D77E4-8052 Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719 Component: GTO BF H01 0080 Serial number: 00000000000000800707 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 8K0 959 591 C HW: 8K0 959 591 Component: J245 PS151 H08 0043 Subsystem 4 - Part No SW: 8K0 959 591 C HW: 8K0 959 591 Component: J394 PS240 H08 0043 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T1 035 223 A HW: 8T1 035 223 A Component: DSP Prem H05 0030 Revision: 00005001 Serial number: 94813026269704 VCID: 2D51B231744937273E-8078 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 R HW: 8K0 959 792 P Component: TSG BF H02 0510 Revision: Serial number: 0000091201945 Coding: 011C13205E00410001 Shop #: WSC 06335 000 00000 VCID: 4E93D5BD198F2C3F67-801A No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb Part No SW: 8K0 907 801 N HW: 8K0 907 801 J Component: EPB-4 H01 0005 Revision: -------- Serial number: 30000000174289 ASAM Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_AU48.rod VCID: 3A7B896DBD07909FAB-806E No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 G HW: 4G0 035 082 Component: Radio U SIRIU H60 0133 Revision: AB001007 Serial number: 156B.0E7972224 Coding: 020007010000000001 Shop #: WSC 06335 000 00000 VCID: 244757152783F66FE1-8070 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8R1 035 746 E HW: 8R1 035 746 D Component: H-BNT-NA H41 0756 Revision: -------- Serial number: 204B.0E7642938 Coding: 010200050006A1EF51028B5E00000403140000000000000000 Shop #: WSC 06335 000 00000 VCID: 39799661B0019B87A2-806C Subsystem 1 - Part No: 8R0 060 884 BL Component: NAR 2014 0902 Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A Component: DU7 High H42 0104 Serial number: A130BV0E2952566 Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C Component: E0380 Bedient H02 0030 Serial number: 00000001767578 Subsystem 4 - Part No: 8R0 060 961 F Component: CD-Database 5571 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 G HW: 8K0 959 795 D Component: TSG HL H01 0510 Revision: Serial number: 0000092481165 Coding: 010C13204000210001 Shop #: WSC 06335 000 00000 VCID: 4683ED9DF1FFE47FDF-8012 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 C HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H09--- Serial number: 525PA8-J3Z91BG Coding: 1000007 Shop #: WSC 06335 000 00000 VCID: 387F93654B0B828F5D-806C No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels: Redir Fail! Part No SW: 8K9 827 851 C HW: 8K9 827 851 C Component: J605 Master H53 0330 Revision: -------- Serial number: 8K9827851C VCID: 3E73857DA92FBCBF97-806A Subsystem 1 - Part No SW: 8K9 827 852 C HW: 8K9 827 852 C Component: J756 Slave H53 0330 Serial number: 8K9827852C No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 G HW: 8K0 959 795 D Component: TSG HR H01 0510 Revision: Serial number: 0000092497058 Coding: 010C13204000210001 Shop #: WSC 06335 000 00000 VCID: 4683ED9DF1FFE47FDF-8012 No fault code found. End-------------------------(Elapsed Time: 04:10)--------------------------
