Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 123
  1. #41
    Veteran Member Three Rings Fastbke170's Avatar
    May 01 2015
    2003 Silver GSXR1000, Mazda 3S 2006
    Northport
    Quote Originally Posted by AWellman View Post
    What was wrong with the connector? i too am having this fault:
    7213 - Cam Adjustment Actuator A; Cylinder 2
    P11A5 00 [109] - Elec. Malf. or Open Circuit
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 148186 km
    Date: 2017.01.29
    Time: 00:25:16
    Engine speed: 182.00 /min
    Normed load value: 42.4 %
    Vehicle speed: 0 km/h
    Coolant temperature: 8 °C
    Intake air temperature: 8 °C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 10.107 V
    Unlearning counter according OBD: 40
    I bought my car with 33k in 2015. The car had to go back to dealer for various things under warranty. Turbo, valve cover gasket, brake module error. Anyway after that was all sorted, I noticed when I was changing plugs at 35k that one cam actuator connector tip was bent slightly, the plastic portion that goes down into cam actuator. I didn't think anything of it as car was running fine. After changing plug again at 60k I guess the damage was already done and the tip just snapped off😲. Luckily I was able to super glue it on where it still was contacting but the ecm knew the problem.
    Sent from my SM-G925P using Audizine mobile app
    2012 A4 Moonlight Blue Metallic : Premium +: RS6 18" GUNMETAL WHEELS: AEM PRO DRY INTAKE: FRANKENTURBO F23L : TopGear UK HFC : TopGear UK 3"Stainless Steel Turbo Back Full Dual Exhaust: TopGear UK Eurodyne Custom Tune:Eurocode FMIC :3 Spoke S4 Black Steering Wheel w/DSG Paddle shifter : S-Tronic Shifter Knob w/Black Boot : LED White Interior: LED Red Footwell Conversion : Hoen White XEON Match Fog Bulbs :R8 Coil Packs: Puddle Projection Lamps with Audi Rings
  2. #42
    Established Member Two Rings SlvrArrw's Avatar
    Nov 05 2016
    Richmond, Texas, USA
    Hello,
    Have a '08 A4, 2.0T 6MTCar has been reliable over 14 months since purchase @ 53K mi. I now have 100K.
    First saw this type of CEL after driving at high revs for sometime.
    The first message was I think: "Driving with open or loose gas cap, close gas cap"
    This went away after restarting car. This happened 1 more time.
    So, yesterday I left work, everthing normal and "Check engine"light goes on, car still seems mormal but I get concerned. I babied it all the way home (approx 60mi) and checked codes
    I got:
    P0445-001 ML ON Evap System
    Large Leak Detected
    RPM 1834/min. Load 9.4%
    Absolute Pres: 1030.0 mbar
    VOLTS 13.97 Priority 2
    I checked for loose fittings/hoses, pulled and checked PVC.
    I had a loose clamp for my boost gauge hose so I tightened it. Cleared codes.
    Car drove fine to work next day but on the way home the same CEL came back. The car ran fine home.
    Any ideas. Anyone?
    Do I just need a new gas cap?
    Any help will be appreciated.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  3. #43
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    P2099 Underboost.
    Been dealing with this error for 6 months or so. Just replaced the DV with Rev. D
    Clearing codes on a weekly basis, and can't figure out what the deal is. I have had an APR tune for almost 5 years with no issues like this.
    Wondering if anyone has any ideas? Turbo going bad? Time for a K04?
  4. #44
    Senior Member Two Rings snolvr's Avatar
    Nov 11 2013
    2000 S4 Stage 3, '11 A4 Avant Prestige, titanium, sport, '87 4ktq 20v turbo, '07 997 turbo
    Broomfield, CO
    Quote Originally Posted by A4 Centaur View Post
    P2099 Underboost.
    Not sure if '12 models received the updated "clip" for the turbo wastegate, I don't think so. Have you noticed any decrease in performance at all, specifically a lack of boost? Apparently that's how these IHI turbo's fail, the wastegates fail open which leads to poor performance. If I had to venture a guess I'd say you're probably on the right path with a failing turbo based on your tune and where you and I drive
    (I-70 and mountain passes) Hoping it's something simple for you though. Run it by Apikol and have Troy take a look.
  5. #45
    Jun 05 2009
    Scottsdale Arizona
    ^Thanks man! It's time and would appear based on laggy action at low RPM's and fluttering feeling in general the IHI K03 is dying slowly. I'm just going to pull her out an replace with the K04. I appreciate your input, and the boys at Apikol are awesome!
    However, I'll have a better Avant overall if I just get going with what should have been done several years ago. I was holding out for a bit of a hybrid or other offering but looks like it will be K04 and WM moving forward.
    You are right, I-70 is hard on engines, transmissions and other vehicle systems!
  6. #46
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    07663? Part # relates to ECU... anyone seen this code before?
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
  7. #47
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    Quote Originally Posted by Olde_English View Post
    Anyone know what 02615: Locking fuel tank cap or 02616: unlocking fuel tank cap codes mean? I have a new gas cap on, not sure if these affect anything though.
    There is a locking mechanism that locks the gas cap from inside the car. You can access this locking mechanism from inside the trunk when you pull back the trunk lining behind the gas cap. It's an easy fix and a known problem. Tight quarters though...
    My current rides...
    Audi
    Jetta
  8. #48
    Veteran Member Three Rings Olde_English's Avatar
    Dec 07 2016
    Singlespeed S-Works Epic Hardtail and Specialized Epic Evo
    Prescott, AZ
    Quote Originally Posted by Jacon View Post
    Thanks for the response. Do you know the link for the fix by chance?
    Sent from my SM-G930T using Audizine mobile app
    2016 Sepang Blue B8.5 SQ5 | 034 Stage 1 | CTS Turbo Intake
  9. #49
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    no but it seems like an easy fix.
    My current rides...
    Audi
    Jetta
  10. #50
    Dec 07 2016
    Prescott, AZ
    Ok, thanks again
  11. #51
    Veteran Member Four Rings Cloudg8's Avatar
    Oct 10 2012
    Jeep
    Chicago/IL/USA
    Quote Originally Posted by SleeperCar View Post
    Got this code too. Did you figure out what it was?
    B8 Drivers group on FB and IG
  12. #52
    Jan 03 2012
    Wilmington NC
    Quote Originally Posted by Cloudg8 View Post
    Yea I had a Ross tech scan and it turns out it's the diverted valve, it's a soft code though. Very common with GFB DV+ since it allows for additional pressure and ECU sees that as a malfunction when it's not.
    2019 S4 Build
    IG: @steves_s4
  13. #53
    Oct 10 2012
    Jeep
    Chicago/IL/USA
    Ok. I got the DV+
    It just seems like my car is running weak. Also pulled the Carista 07900 code. No clue what that is. Can't find info anywhere
  14. #54
    Jan 03 2012
    Wilmington NC
    Ok. I got the DV+
    That's the problem with carista, those codes don't actually mean anything... Ross tech actually tells you the Pcode value which is true to the manufacturer info so you can track down the exact issue.
    I suggest you get a scan with Ross tech
    2019 S4 Build
    IG: @steves_s4
  15. #55
    Oct 10 2012
    Jeep
    Chicago/IL/USA
    Yah true that. I gotta get that cable.
  16. #56
    Aug 19 2016
    Calgary/AB/CA
    Hello,
    Have a 2009 A4 2.0 6AT with 71k miles.
    Started driving in the morning, after around 1/2 mile car lost power and engine began to shake. CEL and ESP light came on as well. Turned around and limped back home. Ran the RossTech tool to see what codes are coming up:
    5646 - Leak in Air Intake System
    P2279 00 [096] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    7018 - Oxygen (Lambda) Sensor B1 S2
    P0139 00 [096] - Response too Slow
    2811 - Fuel Trim; Bank 1
    P0171 00 [096] - System Too Lean
    5671 - Boost Pressure Regulation
    P0299 00 [104] - Control Range Not Reached
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Mileage: 114306 km
    Date: 2017.05.03
    Time: 16:53:29
    Engine speed: 2928.50 /min
    Normed load value: 58.4 %
    Vehicle speed: 65 km/h
    Coolant temperature: 95 °C
    Intake air temperature: 36 °C
    Ambient air pressure: 880 mbar
    Voltage terminal 30: 13.994 V
    Unlearning counter according OBD: 39
    4060 - Cylinder 3
    P0303 00 [101] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 114616 km
    Date: 2017.05.10
    Time: 05:21:14
    Engine speed: 2890.50 /min
    Vehicle speed: 59 km/h
    Coolant temperature: 47 °C
    Intake air temperature: 13 °C
    Voltage terminal 30: 14.065 V
    Unlearning counter according OBD: 80
    7960 - Cylinder Disabling
    P130A 00 [036] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 114616 km
    Date: 2017.05.10
    Time: 05:21:24
    Engine speed: 1955.00 /min
    Normed load value: 40.0 %
    Vehicle speed: 67 km/h
    Coolant temperature: 50 °C
    Intake air temperature: 12 °C
    Voltage terminal 30: 13.923 V
    4051 - Random/Multiple Cylinder Misfire Detected
    P0300 00 [101] - -
    Readiness: 0000 0000
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0094
    Revision: 4GB20042 Serial number: 4200G08A060195
    Coding: 000303
    Shop #: WSC 02391 823 56573
    VCID: 468322A6F1B8D872DA-8012
    Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
    Component: J367-BDM H04 0150
    Serial number: 1804B752260908
    1 Fault Found:
    03041 - Energy Management Active
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 160
    Reset counter: 6
    Mileage: 108824 km
    Time Indication: 0
    Date: 2016.12.16
    Time: 15:02:00
    Haven't started the car after. Anyone experience anything similar or has any ideas?
    Thanks in advance!
  17. #57
    Dec 14 2016
    Long Island NY
    2009 Audi A4 Quattro 90k miles
    Fault code B200FF0 PCU Bandgap Error Passive/Abiogenesis. I can't find anything on this. Thanks in advance.
  18. #58
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    P2099 Underboost.
    Same problem on my 2010 a few months ago. CEL came back not long after I replaced the DV with the new version. Took it to Audi and they replaced my turbo under warranty (Audi extended the turbo warranty to 75,000 miles).
  19. #59
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    VZEE - I'd start by replacing your ignition coils for the misfires. Not expensive and easy to do to.
    I had same symptons on my car a few days ago and got P0301misfire in cylinder 1. Replaced the ignition coil and it's running great again.
  20. #60
    Dec 14 2016
    Long Island NY
    I should have been more specific. This is the reading from the Ross-Tech VAG tool:
  21. #61
    Sep 09 2010
    Destin, FL
    Yaaaaay, I love fault codes... Took the senor out like last time on page one and it was dirty again but not too bad.
    Address 01: Engine Labels: 06H-907-115-CAB.clb
    Control Module Part Number: 8K2 907 115 AL HW: 8K2 907 115 D
    Component and/or Version: 2.0l R4/4V TF H16 0001
    Software Coding: 0104010A190F0160
    Work Shop Code: WSC 27637 002 1048576
    ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 (AU48)
    ROD: EV_ECM20TFS0118K2907115AL.rod
    VCID: 79F3C6F0F8302E89AE-802C
    3 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00 [039] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Mileage: 74300 km
    Date: 2017.06.17
    Time: 13:08:15
    Engine speed: 3924.00 /min
    Normed load value: 34.1 %
    Vehicle speed: 57 km/h
    Coolant temperature: 98 °C
    Intake air temperature: 42 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 13.947 V
    2999 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 00 [101] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 74300 km
    Date: 2017.06.17
    Time: 13:08:15
    Engine speed: 3661.50 /min
    Normed load value: 61.6 %
    Vehicle speed: 53 km/h
    Voltage terminal 30: 13.829 V
    4173 - Manifold Pressure / Boost Sensor (G31)
    P0236 00 [039] - Implausible Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 74300 km
    Date: 2017.06.17
    Time: 13:06:50
    Engine speed: 758.00 /min
    Normed load value: 14.1 %
    Coolant temperature: 97 °C
    Intake air temperature: 48 °C
  22. #62
    Sep 25 2016
    Philadelphia
    Address 08: Auto HVAC Labels: Redir Fail!
    Control Module Part Number: 8T1 820 043 AQ HW: 8T1 820 043 AQ
    Component and/or Version: KLIMA 3 ZONEN H08 0171
    Software Coding: 64102000
    Work Shop Code: WSC 02391 823 56573
    VCID: 00085B4293984341E9-8054
    1 Fault Found:
    01314 - Engine Control Module
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 65
    Mileage: 91418 km
    Time Indication: 0
    Date: 2017.06.26
    Time: 17:58:21
    Address 09: Cent. Elect. Labels: 8K0-907-063.clb
    Control Module Part Number: 8K0 907 063 P HW: 8K0 907 063 P
    Component and/or Version: BCM1 1.0 H25 0380
    Software Coding: 26001091063CAF010000080300003D0D0F1C12080001016100 0000
    VCID: 3C70EFB2BFF0E7A1F5-8068
    1 Fault Found:
    02258 - Door Opener Transmitter
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 65
    Mileage: 91418 km
    Time Indication: 0
    Date: 2017.06.26
    Time: 17:58:00
    Address 19: CAN Gateway Labels: 8T0-907-468.clb
    Control Module Part Number: 8T0 907 468 T HW: 8T0 907 468 K
    Component and/or Version: GW-BEM 4CAN-M H09 0105
    Software Coding: 00C303
    VCID: 52ACA10A0D7401D10F-8006
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    Reset counter: 65
    Mileage: 91418 km
    Time Indication: 0
    Date: 2017.06.26
    Time: 18:01:25
    Freeze Frame:
    Bin. Bits: 10111
    Voltage: 11.10 V
    Count: 6
    Mode 03: Emission related fault codes
    Address 7E8: 2 Faults Found:
    P0300 - Random/Multiple Cylinder Misfire Detected
    P0301 - Cylinder 1: Misfire Detected
    Any help would be appreciated
  23. #63
    Sep 07 2017
    South Africa
    I also got this fault code when I first scanned my car with VCDS and did some research. You probably found the solution already but for those in future it is related to the solenoid keeping the fuel cap closed when the car is locked. Here's the link to the DIY that I used http://www.audizine.com/forum/showth...solenoid-motor
    2009 AUDI A4 1.8T (CURRENT)
    2004 AUDI A4 1.9TDI (PREVIOUS)
  24. #64
    Active Member Two Rings Krogers's Avatar
    Jan 28 2016
    01 jetta
    Blacksburg,Virginia
    Why would my epc light come on only sometimes and say do not exceed 4K rpm when I really get into it. When I turn the car off then back on it is off? Has anyone else had this happen or know what maybe the problem?
    2010 A4 Prestige / Tinted Windows / LED Interior / H&R Sport Springs / ECS 10mm & 17.5mm Spacers / ECS Turbo Inlet Pipe / more coming
  25. #65
    Aug 17 2017
    Saugatuck, MI
    I'm hoping to get some help with my 2009 A4. Replaced the timing chain and all is well until I push the pedal enough for the turbo to kick in. Then I occasionally will get codes: P0016 and P2237 otherwise unless I get on it some, the engine light does not come on and doesn't always come on when I do get on it. I've tried changing the o2 sensor but haven't done the camshaft sensor. Both seem to me unlikely because it is intermittent and only when the turbo would be engaging? It does run a liitle oddly (like a bit of a stutter) when idling and in drive and just starting to move or coming to a stop. While in park it idles well.
  26. #66
    Senior Member Two Rings unmarkedA4's Avatar
    Jun 11 2017
    Bonney Lake/ Wa
    Quote Originally Posted by VZee View Post
    Hello,
    P2279 00 [096] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Mileage: 114306 km
    Date: 2017.05.03
    Time: 16:53:29
    4060 - Cylinder 3
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 114616 km
    Date: 2017.05.10
    Time: 05:21:14
    P130A 00 [036] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 114616 km
    Date: 2017.05.10
    Time: 05:21:24
    P0300 00 [101] - -
    Coding: 000303
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Reset counter: 6
    Mileage: 108824 km
    Time Indication: 0
    Date: 2016.12.16
    Time: 15:02:00
    Thanks in advance!
    Have you figured this out
  27. #67
    Senior Member Two Rings Dcferolino's Avatar
    Jan 10 2015
    2009 audi Q5
    Mountlake Terrace/ Wa
    P0141 anyone has this issue and how to resolve it
  28. #68
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by Dcferolino View Post
    P0141 or O2 Sensor Heater Circuit Bank 1, Sensor 2 is referring to your downstream O2 sensor (the one after the cat, or the second one). I have been receiving this on and off since its been really cold here lately, but from the research I have done, the code is basically saying that the O2 sensor isn't hitting the correct operating temperature, or its taking too long for the O2 sensor to start working once it hits the required operating temperature, and is often related to the electrical impedance being outside of the specified range. I have since been clearing this with carista, but have gathered that a new O2 sensor should resolve the issue. The next question is the debate between an OEM & an OEM equivalent for the replacement, since the price difference is considerable.
    https://www.ecstuning.com/Audi-B8_A4...Rear_Position/
    https://www.obd-codes.com/p0141
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
  29. #69
    Jan 10 2015
    2009 audi Q5
    Quote Originally Posted by bakedziti View Post
    Thnk you
  30. #70
    Jan 10 2015
    2009 audi Q5
    Thnk you
    Installed it now i get an error code of p013a? Any ideas
  31. #71
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    General causes!
    Potential causes for this code to set are:
    Defective O2 sensor(s)
    Burnt, broken, or disconnected wiring and/or connectors
    Defective catalytic converter
    Engine exhaust leaks
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
  32. #72
    Account Terminated Two Rings
    Dec 26 2017
    magimmeMVE
    Usa
    Hi. I got error about A/C pressure/temp but my a/c still works.
    I need to change that temp sensor or i can drive like that and have 0 problems?
    And maybe someone can explain what that sensor is doing, why a/c needs outside temp
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AH HW: 8T1 820 043 AH
    Component: KLIMA 1 ZONE H08 0180
    Revision: A1000000 Serial number: 01140920100750
    Coding: 34300000
    Shop #: WSC 06335 000 00000
    VCID: 77FA73F3C6DEE3866C-8022
    2 Faults Found:
    00457 - Control Module for Network (J519)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 240
    Mileage: 270994 km
    Time Indication: 0
    Date: 2017.12.28
    Time: 16:14:34
    00256 - A/C Pressure/Temperature Sensor (G395)
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 240
    Mileage: 270994 km
    Time Indication: 0
    Date: 2017.12.28
    Time: 16:14:34
    Freeze Frame:
    Temperature: 15.0°C
  33. #73
    Jan 10 2015
    2009 audi Q5
    Quote Originally Posted by Gunnark100 View Post
    General causes!
    Just changed the o2 sensors worked ok for now and now i get an engine fault codw of 04270 any ideas?
  34. #74
    Oct 21 2012
    Earth...
    Quote Originally Posted by anoance View Post
    Replace a sensor, around 40euro and 5 min job. You dont need cooling anyway in winter, so you can drive like this, but up to you. It measures refrigerant pressure and temp(not outside temp)!
  35. #75
    Dec 26 2017
    magimmeMVE
    Usa
    Problem with front parking sensors! 3 of 4 front parking sensors beep all time, sometimes 2 of 4. Connected vcds and no errors. In mass block 3 of 4 shows 0cm, but that who works 255cm (when they are on). When they are off, all 4 show 255cm (i think its not right value, but it shows that and one of them work properly :D) + rear works great all time with same value and didn't saw any way to change it.
    Tried to wash them more times, but still 0 changes. They are broke and asks for change or its some other problem?
    + If need to change them, how about painting? on sides they are in car color, but after painting they still work? No need for special paint?
  36. #76
    Dec 26 2017
    magimmeMVE
    Usa
    Last 2 days all sensors work perfectly :D First time they all work! Hope it will stay like that
  37. #77
    Oct 06 2017
    Bethesda, MD
    2015 A4 Quattro 2.0T Tiptronic
    Threw up a CEL this morning along with a random EPC warning in the DIS.
    Diagnosed via Carista:
    P0456 (OBD2 confirmed/pending/permanent): Evaporative Emission System Leak Detected (very small leak) - 3 codes, ranging from confirmed to pending to permanent.
    10530 - Engine. I can't get any info on this so I'm worried. Anyone ever have this code before?
    I dropped it off at the dealer this morning, so hoping it's nothing serious. The P0456 code hopefully is just a faulty gas cap or something, but I'm really worried about the engine code. The service advisor says the EPC warning might be a misfire.
    Any thoughts?
  38. #78
    Oct 06 2017
    Bethesda, MD
    So, dealer says they replaced NVLD Pressure Sensor.
    This cleared the engine code, etc., but I STILL have a P0456 (tank ventilation system: A small leak) PERMANENT code being thrown up. Previously there was a P0456 Pending and P0456 Confirmed code as well.
    Any thoughts?
  39. #79
    Nov 05 2016
    Quote Originally Posted by SaigonDesign View Post
    Any thoughts?
    Replace your gas cap and get a PVC replacement kit.
  40. #80
    Mar 28 2018
    Upstate New York
    I just got my 2012 a4 about a month ago and I'm getting the P2015 code for intake manifold runner position sensor. I've been doing a lot of research on it in the past few days because I just registered it and have to get it inspected within 10 days (Cant pass NY inspection with a CEL). The limited info i can find on this problem is on older (maybe B7) models or TDI's that are not quite the same. The 'common' problem that shows up is the lever/ vacuum connection that actually moves the flaps actually pops out of place making a big air leak. However in my case that piece only pops out a few mm and I cant hear any major air leak. After all the research I've done theres really no straight forward answer except to replace the whole intake manifold. Is there something Im missing or is replacement the only option? Im taking it to a local seller/mechanic to do other troubleshooting before I have to break down and buy the intake, seals, ect.
