Results 1 to 3 of 3
    Senior Member Two Rings Lanorg's Avatar
    Apr 22 2013
    Floor jacks, torque wrenches, and winter tires
    B5 RS4 oil cooler to thermoswitch gasket
    Where can I get a new one? Cant find on ecs.
    Anyone know if I can get away with a gasket maker instead?
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Black rtv might work. Is it a metal gasket originally?
    Apr 22 2013
    No. This is a black rubber gasket that wedges between the thermoswitch and the oil cooler. The thermoswitch allows oil to flow to the front mounted oil radiator at a certain temp.
    Edit: was thinking of using the RED high temp gasket maker... Found this: 078 115 441 sealing washer 62X5,4 on http://www.vaglinks.com/Docs/Audi/B5...artNumbers.pdf
    Guess I can call the dealer or order from overseas.
