Results 1 to 17 of 17
    Veteran Member Four Rings 1dopea4's Avatar
    Aug 03 2010
    joliet IL
    DeAutoLED reverse lights review
    Hey guys, well I was lucky enough to test these out. Installation wasn't hard at all..
    pop this cover off from the top.
    and remove this Phillips ( + ) screw, tail light then slides out and replace the bulb.
    Leds look much higher quality than the knock off Chinese versions.
    Some pictures of them in daylight..ish in the garage. I'll follow up with a night time pic.
    they work great as being able to see out the rear view camera better. Crisp white, as I hate the yellow look of stock bulbs. No problems yet.
    Update: output was more important and I think it gives me better light when reversing.
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    Agree 100%.
    I installed mine last night.
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    So we all agree these match the license plate lights well then?! I'm ready to pull the trigger...HATE the stock reverse lights. Sounds like the cheaper Phillips ones aren't as bright as these.
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Aug 03 2010
    joliet IL
    I'll snap a pic but now my plate lights aren't as bright..
    Stage 2 Banner Advertiser Four Rings deAutoLED.com's Avatar
    Feb 13 2015
    US
    Thanks for the great review - we really appreciate it - we will share photos also.
    BG SQ5 - Yes the color temperature should both be a clean white - our reverse are of course going to be a lot brighter though - but this will honestly be a lot better than the dull NOT bright yellow stock ones.
    We have nothing against Philips, we use their product (not LEDs), we feel their LEDs are lacking from testing we have done and some reviews we have from our customers, and the Philips reverse LEDs are nowhere near the brightness we offer on our LEDs.
    On top of this they are 100% error free which is very difficult to do, we have seen many LEDs on amazon and ebay that look just like ours that are not error free - the resistors and setup we use are unique to our LEDs.
    Below is a review of ours vs Philips - this is the brightest x-treme model they offer that was tested against our LEDs:
    Quote Originally Posted by derekjl View Post
    So awhile back I purchased Philips reverse bulbs from Amazon for my GTI. I was looking for something that was an LED, pure white, and had a bit more light output (I park in a very lowly-lit area). I got them, installed them, and quite frankly was not all that impressed. Yes the light was white, they lit up instantly and looked pretty cool. The light output was the same, if not slightly less than the stock incandescent bulbs. I left them in for a few months and then decided to look for something else. I didn't want to go the eBay route, so I turned to deAutoKey. I know they've been around for a bit and cater to the VW/Audi community. I was one of the first to get their front turn signal LEDs and still rave about them and get compliments. I'm really glad I went with their reverse bulbs. I would estimate at LEAST 25% more light output than the Philips versions, great quality, got them in 2 days. These are way more than adequate if you want a pure white LED with more light output for your car. Here is a comparison:
    Philips Reverse LEDs:
    deAutoKey LEDs:
    A couple more things to point out, notice that the deAuto bulbs are whiter. The Philips bulbs definitely have a yellowish "tint" to them (sort of similar to a 4300k HID bulb). Also, the lighting in the garage was similar, but not exact. There is more light in the deAuto picture but they are still brighter. I was going to take a picture of them in total darkness but in all honesty picture would be washed out with the light output. I wanted to give the most realistic depiction of the light output of both bulbs. These are obviously super easy to install. But check your housings, my bulb holders just pull right out whereas some need to be twisted out. Really loving these so far. Now I need the LED tail bulbs!
    deAutoLED.com
    Facebook.com/deAutoKey
    Instagram.com/deAutoLED
    Lifetime Warranty & Support | Free Shipping within the US | LEDs Tested to work and look good in your car | Customer Service is our #1 Priority - We care what you install in your car!
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Looks great. Do they make LED rear fogs also?
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Feb 13 2015
    US
    Quote Originally Posted by q5 dave View Post
    Yes we should have what you need - what is the bulb style you need, we can help you out.
    You can check out the s3 model:
    http://deautokey.com/product/bright-...2015-s3-models
    review:
    Audi s3 rear fog
    deAutoLED.com
    Apr 24 2015
    Bay Area
    here is a stupid question.. for the life of me .. I can not figure out how to remove the other side without that cover.
    Please help.
    Aug 03 2010
    joliet IL
    I'm confused on the question.. You mean after you remove the cover? There's a screw you need to take out then you can slide the housing out
    Mar 14 2012
    Ona, WV
    https://www.carcarekiosk.com/video/2.../reverse_light
    Watch these videos. That's what I did before I did mine.
    Super easy to do.
    Current Stable:
    Past Whips:
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by deAutoLED.com View Post
    Awesome I emailed you back for the quote.
    Feb 13 2015
    US
    q5 dave - thank you - they sent the invoice today, sorry for the delay, they missed your reply.
    deAutoLED.com
    Feb 13 2015
    US
    Just an update, these are brighter and will work with every single Audi model except the Q7 right now.
    -fits all 194/921 LEDs:
    http://deautokey.com/product/audi-19...-rs3-many-more
    Thank you
    deAutoLED.com
    Mar 22 2016
    Put these on a month ago and high recommend it. Super bright.
    Feb 13 2015
    US
    Quote Originally Posted by SQBoost View Post
    Thanks for the feedback, we feel our repetitive "these are bright reverse LEDs, you have to see it to believe it" loses its meaning after awhile, but we don't know how else to advertise these blinding reverse LEDs. Thanks again for taking the time to share your feedback, we appreciate it.
    deAutoLED.com
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    just purchased these and the front turn signals- can't wait to install them!
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Feb 13 2015
    US
    Quote Originally Posted by staticuxo View Post
    Thank you - we appreciate the support, keep us updated once installed.
    Don't forget the interior kits, our kits are complete, red door warning LEDs - white puddle - stage 2 trunk LEDs with hatch LED - blue red or white footwells which many other kits do not add - even with all of these LEDs included our cost is still less then competitors! We feel you should have all LEDs installed at once. We mention it because many contact us for the missing LEDs after installing other interior Kits and normally it won't work because if you install our LEDs next to other diodes it won't always be a 100% match in color temperature.
    http://deautokey.com/category/shop-b...ll-years-trims
    interior:
    http://deautokey.com/product/audi-q5...ite-error-free
    Thanks again.
    deAutoLED.com
