Results 1 to 4 of 4
    Registered User Four Rings CTS Turbo's Avatar
    Nov 12 2008
    01 S4, 04 A4, 15 GTI, 15 S3
    Vancouver
    CTS Turbo Audi A4 B6 Product List - From coil pack adaptors to engine internals!
    CTS Turbo Product Listing - Check out the amazing Audi A4 B6 products we manufacture and products from other great companies!
    CTS TURBO 1.8T DIVERTER VALVE 1"
    Stock diverter valves are a common item to fail, especially on a modified car. CTS Turbo billet diverter valve is the solution!
    This valve has a faster response time and a light weight aluminum piston. This valve will make your car handle more boost, increase airflow for better turbo response
    Price: $149.99 - CLICK HERE to place an order & for more product information.
    CTS CEL Eliminator / O2 Sensor spacer
    OFF ROAD USE ONLY
    Price: $39.99 - CLICK HERE to place an order & for more product information.
    CTS Turbo Coilpack Adapter Set for 1.8T
    The CTS Turbo Coilpack Adapter Set for 1.8T allow for the installation of the FSI or TSI coilpacks onto your 1.8T. Installing the FSI or TSI coilpacks will allow you to run a larger spark plug gap, which will improve idle, gas mileage, throttle response, improve improve combustion and look great.
    We all know of the recalls on 1.8T coilpacks, upgrade your failure prone 1.8T coilpacks to FSI or TSI coilpacks with the CTS Turbo Coilpack Adapter set today. Each set includes four 6061 CNC machined Coilpack Adapters, and stainless steel bolts. Please note that our CTS Turbo Coilpack Adapter Set will work on all 1.8T engines. We also sell the red top R8 coil packs! PM for more information!
    Price: $69.99 - set of 4 - CLICK HERE to place an order & for more product information.
    CTS Coilpack Adapter Set For Bolt Down 1.8T Engines With FSI/TSI Coilpacks
    Price: $79.99 - set of 4 - CLICK HERE to place an order & for more product information.
    CTS Turbo 1.8T Throttle Body Spacer
    CTS Turbo is now offering throttle body spacers for the 1.8T engine. These spacers offer a injection point for water/meth systems as well as increasing the plenum volume. This increase will aid in boosting the mid-range torque of the vehicle. Included in the kit is the spacer, 2 OEM gaskets and 4 extra long machine bolts.
    Price: $49.99 - CLICK HERE to place an order & for more product information. Sound clips can also be found on our site!.
    CTS Turbo B6 Audi A4 Test Pipe
    The CTS B6 test pipe is the premier test pipe for your B6 Audi A4 1.8T. Our test pipe is designed to seamlessly fit in place of your restrictive stock catalytic converter, which is situated immediately after the turbocharger. Our test pipe features 3" stainless steel piping, smooth mandrel bends, two 02 sensor bungs with an option for a third. Substantial power gains, improved exhaust flow and a more throaty sound are the main benefits from installing our test pipe. Upon inspection you will notice smooth mandrel bent piping with seamless transitions from the turbocharger to the exhaust system. In addition to being one of the best bang for the buck performance upgrades for A4 owners our test pipe is also very attractive piece. Each 3" test pipe is mandrel bent, hand tig welded. Do you need an additional 02 bung for data logging? Well that's no problem! Tig welding additional 02 bungs can be done for an additional charge.
    Product Details:
    T304 stainless steel construction
    Mandrel bent stainless steel
    Fully tig welded design
    Optional third 02 bung
    Install hardware included
    Throaty sound
    Great power upgrade
    To remove the CEL that will occur, proper tuning software must be used. Off road Use Only
    CTS Turbo 1.8T 20V Billet Fuel Rail
    CTS is proud to present our new 1.8T 20V fuel rail for Audi and VW applications.
    Machined in-house from solid T6061 aluminum, this fuel rail is a must for anyone who is after serious power.
    Features:
    Designed and made in Canada.
    Machined from billet T6061 aluminum.
    -8ORB ports for easy installation.
    Uses factory injector clips.
    Mounting bolts and spacers are included.
    BorgWarner K04-00 Turbocharger
    Great bolt on performance upgrade, can be used with or without specific programming (only on stock ECU without stage 1, etc).
    The K04 is a straight bolt on turbo that can be used for multiple different reasons. Flows more volume than the standard K03. Can sustain higher boost pressures than the K03. Great replacement turbo if your K03 has gone bad. Can be used without any special programming although specific K04 programming is recommended to extract all potential power from the K04
    Email us for the BEST PRICE! - CLICK HERE to place an order & for more product information.
    CTS TURBO B6 A4 1.8T FMIC KIT (rated to 600HP)
    The CTS Turbo B6 A4 FMIC (rated for 600HP) will enhance the performance and power of your vehicle by reducing charged air temperatures. To keep charged air temperatures in check CTS uses a 20"x11.25"x3" High Density bar and plate intercooler core. This kit is available for use with the factory K03 turbocharger, or upgraded turbochargers like the K04-015. For those of you looking to compliment our B6 A4 Big Turbo kits with the best FMIC on the market we have just what you need. Please chose your turbo setup from the drop down menu.
    The CTS B6 A4 FMIC kit allows maximum airflow to the FMIC reducing heat soak conditions, the stock SMIC can become heat soaked very fast when boost pressures are increased over stock levels.
    Price: $849.99 - CLICK HERE to place an order & for more product information.
    B6 A4 1.8T Big Turbo Kit
    Turbo Hardware Kit for the B6 Audi A4 1.8T
    Kit Features:
    - Garrett 50trim T3/T4E Turbocharger or choose in dropdown menu
    - 1.8T Turbo manifold T3 flanged (Longitudinal)
    - CTS 3" turbo inlet pipe with DV and PCV/Evap provisions
    - CTS 3" Stainless Steel Downpipe
    - CTS oil feed and drain line kits
    - Coolant relocation kit or water fittings for GT turbos
    - Precision 39mm external wastegate with all springs
    - Gaskets, Studs, Nuts, Clamps
    NOTE:
    - Due to the amount of tuning options and different requirements for MAF housings, the MAF housing is not supplied with this kit.
    - Factory PCV hoses and PCV system must be removed or relocated.
    - Exhaust must be fabricated from downpipe
    - This kit is not compatible with factory intercooler (custom intercooler connection required). If you have CTS FMIC kit for B6 A4, please contact us.
    - Diverter valve not included
    Pictures are for reference ONLY.
    Starting Price: $2499.99 - CLICK HERE to place an order & for more product information.
    CTS Turbo Manifolds - K04
    We offer turbo manifolds for your custom turbo builds or as a standard upgrade with your K03 or K04
    Starting at $299.99 - CLICK HERE to place an order & for more product information.
    CTS Turbo Blankets - K04, T3, T4
    CTS Turbo Blankets isolate the heat produced by your turbocharger with the purpose of reducing turbo lag, cooler air intake temperatures, protecting and prolonging engine components, and giving a boost in horsepower. In keeping the heat of the exhaust gases contained within the hot side of the turbocharger and away from the cool side of the turbocharger and the intake path, more oxygen per unit volume reaches the engine, and thus, more power.
    Starting at $99.99 - CLICK HERE to place an order & for more product information.
    ARP Head Bolt Kits, Head stud kits & More
    These are high quality, American made main stud kit for VW engines, brought to you by ARP out of California. This is absolutely the highest quality main stud kit you can find. We are genuine ARP distributors so buying from us guarantees you a valid warranty. Completely reusable, great for race engines.
    Price: Visit website for pricing and options - CLICK HERE to place an order & for more product information.
    JE Pistons -B6 A4
    -Dome/Dish requires no deburring or preparation
    -2618 T6 high tensile forged aluminum
    -JE designs are specifically engineered for extreme applications up to, and including, professional competition. In this environment, the higher compression ratios, highest boost or heavy nitrous usage necessitate the higher tensile strength 2618 aluminum alloy.
    -Wrist pins included
    -Pin fitting and wire locks included
    -Rings Now Included
    Price: Contact us or visit our website - CLICK HERE to place an order & for more product information.
    Integrated Engineering 4 & 6 cyl. connecting rods
    High quality rods, a must for your engine build!
    Price: Contact Us - CLICK HERE to place an order & for more product information.
    Ferrea, Supertech & Integrated Engineering Valve Spring Kits
    A must for high revving engines!
    Ferrea A4 - 4 & 6 cyl Valves
    Ferrea is one of the most known names when it comes to valvetrain. That is because they make the finest quality valvetrain available! Ferrea valvetrain is trusted by the top racing teams around the world. Formula 1, Nascar, indy, drag racing, and road racing teams all utilize Ferrea valvetrain in the world's highest performing engines. It is definitely a notch above the rest.
    Apikol AUDI REAR DIFF MOUNT (B)
    This performance rear differential mount will provide a precise and direct feel to dramatically enhance your overall driving experience.
    Helps to alleviate drive train movement (clunks) when shifting and transitioning on and off the throttle
    Eliminating drive train movement restores your vehicles crisp, tight feel.
    PRODUCT CONSTRUCTION:
    Fabricated from high-strength aluminum alloy and finished with a durable, clear, corrosion-resistant anodize coating.
    Application specific, custom urethane support bushings.
    Stern Differential Bushings, Snub Mount, Motor Mounts
    A unique engineered design allows this new mount to offer a progressive feel, eliminating vibrations at idle, but offering great control when needed. Medium durometer polyurethane provides a long lasting wear medium encased in a durable aircraft aluminum housing.
    Features:
    Factory fitment
    Heavy duty durable design
    Progressive damping
    Completely serviceable
    Starting at $29.99 - CLICK HERE to place an order & for more product information.
    Solo-Werks S1 Coilovers - A4 B6/B7 Quattro
    Premium entry level height adjustable coilovers
    Price: $499.00 - CLICK HERE to place an order & for more product information.
    Solo-Werks S1 Coilovers - A4 B6/B7 FWD
    If there are any questions, comments or to place an order you can PM or email me at [email protected] or call us at 604-530-3092
    Nov 12 2008
    Vancouver
    Bosch 36lb (380cc) High-Impedance Fuel Injector
    Genuine Bosch 36lb/hour Fuel Injectors
    These injectors flow 36 lbs/hr at 43.5 PSI ( 3 BAR ) and much more at higher PSI! In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths. This allows you to use a larger injector than normally possible without hurting idle and low speed drivability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector. These injectors represent the most current Bosch engineering and are used on many high power turbo oem applications.
    These injectors are able to function at high fuel pressures and don’t exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures and in fact, that is exactly what they were designed for!
    Engine performance and running quality are enhanced through the optimized spray pattern. Unlike competitors “pencil stream” high flow injectors; these High Flow injectors utilize a split / wide cone spray pattern for improved mixture preparation and atomization. This results in lower BSFC and better idle quality than many injectors with less flow.
    Features:
    Genuine, reliable Bosch Injectors
    Excellent response characteristics
    Robust Design
    High Impedance
    Low Impedance performance characteristics with High Impedance Compatibility
    Specifications:
    Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
    Spray Pattern: Dual Spray Wide Cone / Split Cone
    Electrical Connector: EV1
    Fitted with Viton upper and lower o-rings.
    Static Flow Rate @ 43.5PSI (300kPa): 36 lb/hr
    Applications:
    Domestic & Import Applications
    Made for high pressure, harsh environment turbo & supercharged applications!
    Cross Reference:
    Bosch 0 280 155 868 ( 0280155868 )
    Price: $49.99 USD Each - CLICK HERE TO ORDER
    Nov 12 2008
    Vancouver
    CTS Turbo B6 Audi A4 1.8T High Flow Cat Pipe
    CLICK HERE TO ORDER: $249.99 SHIPPED
    The CTS B6 A4 1.8T High Flow Cat Pipe is the premier cat pipe for your Audi.
    Our test pipe is designed to seamlessly fit in place of your restrictive stock catalytic converter, which is situated immediately after the turbocharger. Our test pipe features 3" stainless steel piping, smooth mandrel bends, two 02 sensor bungs with an option for a third. Substantial power gains, improved exhaust flow and a more throaty sound are the main benefits from installing our test pipe. Upon inspection you will notice a flare which is nearly 4", this flare then tapers to 3" and is designed to allow for optimal flow as the exhaust gas transitions from the turbocharger to the test pipe. In addition to being one of the best bang for the buck performance upgrades for A4 owners our cat pipe is also a very attractive piece. Each 3" test pipe is mandrel bent, hand tig welded. Do you need an additional 02 bung for data logging? Well that's no problem! Tig welding additional 02 bungs can be done for an additional charge.
    Product Details:
    Magnaflow 3" high-flow cat
    Optional third 02 bung (additional $10)
    Great power upgrade
    Nov 12 2008
    Vancouver
    TTT
