Results 1 to 6 of 6
    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    How the hell do I pull out a relay , help
    Trying to pull the fuel pump relay. But It wont move, I see to clips, tried to releasthem with flat screwdrivers, but no success
    Mar 30 2016
    S4
    Oranjestd
    Never mind, just needed to pull harder, was scared I broke something and thougt the clips had a purpose, im an idiot
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by Velox View Post
    The clips most likely are what hold the relay together. You can disassemble it to see the windings inside. Even a single blade terminal can be a little tough to pull apart, so having 5 or 6 of them on the same object makes for a tight fit.
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    i recently replaced my FP relay and it was a biiiiitch! i really did think i was going to break the socket, and was even looking at how to disassemble the harness to work on it outside the car. in the end, i used little screwdrivers and hooks to work it out of the socket and then put dielectric grease on the blades to help it out next time.
    - emilio
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    why did you remove it ?
    is this related to your compression test ?
    Mar 30 2016
    S4
    Oranjestd
    Quote Originally Posted by jakeoboy67 View Post
    Yes , I Thought I needed to remove this for the compression test
