Hello Audizine! CTS Turbo is proud to offer a large assortment of products for the MK1 TT
For product information and orders please call us at 604-530-3092 or send us an email to [email protected]
ctsturbo.com is our website, We have a massive online store to take care of all your shopping needs.
MKI TT225HP 1.8T FMIC KIT (450HP) $799.99
Click here for ordering
The CTS Turbo FMIC Kit for the MK1 Audi TT225Q is an excellent upgrade for any stock or modified cars. This kit provides significant cooling improvement compared to the competition, and substantial cooling benefits over the factory setup. Improvements can be attributed to the high density intercooler core, and cast aluminum end tanks. Each pipe in this kit has been "bead rolled" so you don't have to worry about your boost tubes blowing off or leaking. If that wasn't enough for you, this kit also uses black powder coated aluminum piping, 4ply silicon couplers and stainless steel T-Bolt clamps. This intercooler uses cast aluminum end tanks and a high density bar-and-plate core. We pressure test the cores before shipping them out! This intercooler is rated at 450 crank HP and measures 25.25"x8"x3". End tank to end tank is 35.5".
NOTE: You will not be able to keep headlight washers with this intercooler kit.
CTS TURBO MKI TT180HP 1.8T FMIC KIT (450HP) $899.99
The CTS Turbo TT180 FMIC kit for MK1 TT's with FWD and Quattro drivetrain is an excellent upgrade for any stock or modified cars. This kit provides significant cooling improvement compared to the competition, and substantial cooling benefits over the factory setup. Improvements can be attributed to the high density intercooler core, and cast aluminum end tanks. Each pipe in this kit has been "bead rolled" so you don't have to worry about your boost tubes blowing off or leaking. If that wasn't enough for you, this kit also uses stainless steel piping, 4ply silicon couplers and stainless steel T-Bolt clamps. This intercooler uses cast aluminum end tanks and a high density pressure tested core. This intercooler is rated at 450 crank HP and measures 25.25"x8"x3". End tank to end tank is 35.5".
Note: If you're interested in maintaining the sleeper look, rest assured the kit can be installed with no modification to the factory rebar and with very minor trimming to the rear of the bumper skin.
CTS Turbo TT225Q Downpipe $549.99
We are proud to release the new CTS Turbo 3.0" Stainless Steel downpipe for the MK1 TT225Q. Unfortunately, the factory downpipe that comes as standard equipment in your car was designed for anything but performance. The factory downpipe severely restricts exhaust flow and therefor has adverse effects on horsepower, especially once your car is "chipped". The CTS Turbo downpipe will allow for your exhaust gases to flow smoothly, freeing up the additional ponies that you want, all while look amazing. Highlights of our downpipe include CNC machined turbine discharge (downpipe) flange, mandrel bent 3" stainless steel tubing, modular design making installation of a catalytic converter simple and straight forward, smooth transitions allowing for optimal exhaust gas flow.
Are you worried about emissions and inspections? Don't worry, our optional catalytic converter from Magnaflow should satisfy prying eyes. Precision fabrication, unparalleled quality and and great price point all make the CTS Turbo MK1 225Q Downpipe a must have for any Audi enthusiast that values performance and their pocketbook.
NOTE: WILL NOT FIT CONVERTIBLE.
Product Details:
-T304 Seamless Stainless Steel tubing
-T304 Stainless Steel flanges
-100% TIG Welded
-T304 Stainless Steel 02 bung
-Stainless Steel Clamps
-Great Sound
CTS TURBO MK1 Audi TT225Q 3" CATBACK $699.99
CTS Turbo has been dedicated to manufacturing performance parts for enthusiasts by enthusiasts since its inception. Our continued development of the MK1 TT225Q platform is not limited to FMIC kits or Turbo kits, our all new 3" cat-back exhaust system is evidence of that. The CTS Turbo TT225Q 3" cat-back exhaust system is hand tig welded using the finest T304 stainless steel. Our exhaust system was designed for both street use and big turbo abuse. The 3" design of the CTS Turbo cat-back is ideal those of us chasing serious horsepower.
Product Details:
- True 3" Stainless steel cat-back exhaust
- Aggressive sound under hard driving, but subtle when cruising
- Water jet cut flanges
- CNC mandrel bent stainless steel piping
- CNC bent exhaust hangers for precise fitment
- Double wall 3.5" tips with CTS logo
- Torca Accual stainless steel clamps
CTS TURBO 1.8T DIVERTER VALVE 1" (1.8T) $149.99
Stock diverter valves are a common item to fail, especially on a modified car. CTS Turbo billet diverter valve is the solution!
This valve has a faster response time and a light weight aluminum piston. This valve will make your car handle more boost, increase airflow for better turbo response and give your car that awesome WHOOSH sound.
Kit Includes:
• Bolt-down cap, viton o-rings.
• All-aluminum billet construction.
• Anodized black for long-lasting finish.
• Limited Lifetime Warranty
CTS-DV-0005 is a direct replacement for any VAG vehicles, 1.8T and 2.7T (requires 2 valves)
Solo Werks Coilovers - TT Quattro
Solo Werks S1 Coilover System - TT - Premium Entry Level Coilover Suspension!
Features:
Heavy Gold Zinc Plated Housings for superb corrosion resistance
New Progressive elastomer bump stops
Silver spring perches - double lock ring design
Platform Specific Spring Rates and Matched Valving
Front 10-40mm (.5-1.5") Lowering Range
Rear 10-45mm (.5-1.5") Lowering Range
3 year Limited Warranty
Each Kit Contains:
2x Front threaded coilover dampers (w/ Dual locking ring spring perches)
2x Front Spring (Linear Rate) + 2x helper spring
2x Front Sway Bar End Links
2x Rear dampers
2x Rear adjustable spring perches
2x Rear springs (Progressive Rate)
2x Spanner wrenches
Step by Step Installation Instructions
1oz. Bottle Boeshield T-9 Lubricant/Protectant
