Hello Audizine! CTS Turbo is proud to offer a large assortment of products for the B8 S4.
For any questions feel free to contact us at 604-530-3092 or send us an email to [email protected]
ctsturbo.com is our website, We have a massive online store to take care of all your shopping needs.
CTS Turbo Audi B8/B8.5 S4, S5, Q5, SQ5 Air Intake System $329.99
Click here for ordering
At CTS Turbo we are proud to announce our new air intake system for the Audi 3.0T and 3.2L FSI engines. The OEM air scoop works in conjunction with our sealed airbox to seamlesly force cold air into our air intake system. Air then flows through our high flow cone air filter, which utilizes an inverted cone design for maximum engine breathing. Our single piece CNC mandrel bent aluminum intake pipe allows for smooth entry of cold air into the the engine providing peak power gains ranging from 5-8HP. All of the components included in the CTS air intake system work flawlessly together to provide increased horsepower and torque throughout the entire power band and an aggressive race inspired sound.
Product Details:
- Mandrel bent aluminum piping with black powder coating
- Reusable air filter with inverted cone design
- 4 Ply silicon connector with stainless steel clamps
- Sealed air box with rubberized trim
- Bracketry to prevent rattling under engine torquing
- Billet SAI breather adapter and Billet bracket with SAI breather filter
- Gains ranging from 5-8HP
CTS Turbo Billet B8 S4 3.0T Boost Tap $34.99
The CTS Turbo is proud to release our Billet B8 S4 3.0T Boost Tap! Our boost tap cleverly replaces the plastic spacer between the supercharger and outlet pipe. This allows for easy installation of such things as boost gauges and testing apparatus. The CTS Turbo Billet B8 S4 3.0T Boost Tap is constructed from aircraft grade T6061 Aluminum and is anodized black for that stealthy OEM+ look!
CTS B-Cool Billet 3.0T Oil Filter Housing - $79.99
CTS Turbo is proud to release our B-Cool Billet 3.0T Oil Filter Housing. The OE plastic filter housing is quite fragile and is know to become brittle and crack over time. Each CTS Turbo B-Cool Billet 3.0T Oil Filter Housing is constructed in house from T6061 Aluminum. Not only does the B-Cool filter look good, but it works great. We have engineered cooling fins into our design to act as a heatsink, which dissipates heat from the engine oil. Installation is very straight forward and only required basic hand tools.
Product Details:
Made in Canada from billet T6061 Aluminum
Hard anodized black for stealth and longevity
Uses OEM O-ring
OE-style threads are precision made to fit just like factory part. Other manufacturers do NOT make this thread.
Installation of CTS-HW-0243 requires removal of center cage from OE housing cap, which snaps into the CTS billet housing
Compatible with OEM Filter
The CTS B-Cool Billet 3.0T Oil Filter Housing fits Audi 3.0T equipped models such as B8 & B8.5 S4, A6 etc.
B8 S4 CATBACK $1,399.99
CTS Turbo has been dedicated to manufacturing performance parts for enthusiasts by enthusiasts since its inception. Our continued development of the B8 platform is not limitted to FMIC kits or Turbo kits, our all new catback exhaust system is evidence of that. The CTS Turbo B8 S4 catback exhaust system is hand tig welded using the finest T304 stainless steel.
Each CTS B8 S4 catback is 100% tig welded, constructed using T304 Seamless Stainless Steel, and includes installation hardware and stainless steel clamps. Lesser products can be had without stainless steel construction, or with seamed stainless steel, which can crack and decay over time. The CTS Turbo B8 S4 catback increases throttle response, and peak power.
Product Details:
- True Stainless steel catback exhaust
- Aggressive sound under hard driving, but subtle when cruising
- CNC mandrel bent stainless steel piping
- Polished stainless steel exhaust tubing
- 3" stainless steel exhaust tips
- Fits manual and DSG transmission
- Aftermarket cross/underbraces may require spacers for clearance
CTS Turbo B8 3.0T Supercharger Pulley Upgrade Kit $159.99
CTS Turbo is proud to release our B8 3.0T Supercharger Pulley Upgrade Kit. By using a smaller than stock pulley we have been able to increase the speed at which the pulley spins thus increasing the boost pressure output from the Eaton supercharger. Increased boost pressure in conjunction with upgraded ECU software results in a dramatic increase in horsepower and torque throughout the entire power band.
Please note that our B8 3.0T Supercharger Pulley Upgrade Kit must be used in conjunction with the appropriate "stage 2" performance software. Stage 2 performance software, which is not included in this kit, will allow you to harness maximum boost and power from your 3.0T while optimizing air fuel ratios, timing and boost pressure bleed off. Please consult your preferred software tuner for pricing and availability.
Product Details
- Billet precision CNC machined and honed ASI303 stainless steel supercharger pulley
- Black Coating (optional)
- OEM spec honing
- Replacement supercharger drive belt
Optional Equipment
- CTS B8 3.0T Supercharger Pulley Installation Kit (Removes OEM Pulley or CTS Pulley)
