Results 1 to 12 of 12
    Jan 17 2014
    2015 Honda Odyssey (wife-mobile).
    Port Orange FL
    2004 Auid CPO A4 BT 1.8T 6 spd. 128k Dolphin Gray Metallic
    Here is my 2004 BT B6 6 speed (GJW) with a long list of mods. Long story short. I bought this car with a blown motor (key snapped off end of cam). I tore the motor down completely and had it bored, balanced, and the rods clearanced. The motor has forged Wiseco 82mm 8.5:1 pistons, forged Scat rods, OEM oil pump, OEM bearings, all new seals, etc. The head has been milled and the valves were all replaced with Supertech SS valves. It has a ECS RA4 single mass flywheel with a RS4 LUK clutch kit, Evolution Racewerks sport fmic kit, 034 street density motor mounts, 034 tip, Psi concepts exhaust manifold, Psi concepts 520 turbo, Psi concepts oil/coolant line kit, 60lb Bosch injectors, Motoza tuned, and much more. The car has less than 1k miles on all of the mods and freshly built motor. Basically I sold it to a friend when I moved from NY to FL. He drove it for a bit and noticed a leak at the T-stat housing. He replaced the housing and drove it without bleeding it. The car got hot and he shut it down immediatey. After filling and bleeding it the car burns oil after about a few minutes of running. There isn't a drop of coolant or oil in the combustion chamber. Compression test checks out good. I'm willing to bet the turbo got hot and blew the seal. Now the oil is just blowing through the turbo right into the exhaust. There is no oil in the intercooler or piping. Feel free to contact me with any needs or questions. Thanks, Nick.
    Active Member Two Rings GeneriX's Avatar
    May 21 2014
    06 A4 Avant
    Michigan
    Can you send me pics?
    Jan 17 2014
    Port Orange FL
    Here's a link to the panjo ad. There are a few pics. https://www.panjo.com/buy/2004-auid-...etallic-314882
    Senior Member Two Rings Thelumpya2's Avatar
    Apr 01 2013
    Maine
    Does the car have seat memory function? IF so, may I buy one of your mirror adjuster motors?
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    shame about the car. good price for anybody looking for a project.
    Jan 17 2014
    Port Orange FL
    I will check when I get home Thelumpya2.
    Yeah I was back and forth about fixing it but I just don't have the time. I'm in the middle of a jet ski project.
    Jan 17 2014
    Port Orange FL
    Sorry it does not have memory.
    Active Member Two Rings stvn4u2nv52's Avatar
    Aug 16 2016
    Bellingham WA
    Parting out?
    Jan 17 2014
    Port Orange FL
    Yes but, I have someone interested in the complete car but I should know tonight if he wants it or not.
    Dec 28 2008
    Where's the car located?
    Jan 17 2014
    Port Orange FL
    Port Orange FL
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    lmk if ur still parting this out
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
