Results 1 to 4 of 4
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Driveshaft fixes
    I've done a ton of research and still cannot decide exactly what I want to do.
    I was experiencing vibrations in 1st gear under full throttle. I tried the windo weld fix the first time, but the rubber in the center support was shot so the weight of the driveshaft kept it out of alignment and the windo weld cured the center support out of place and I experience worse vibrations.
    So I ripped that stuff out and tried aligning the shaft better and supported it with a 2x4. The second time around it was much smoother most of the time, but got worse vibrations at certain speeds. So, I removed the unit yesterday and had a friend give me some advice, who is a diesel mechanic. He noted that the center u joint was fairly stiff.
    So, I have arrived at the conclusion that I have three options: cut up the stock unit and have a shop weld in a tube for a one piece design, have a shop make an entire custom shaft with u joints at each end and a slip yoke in the middle, or buy a aftermarket unit. I have contacted a few local shops and a couple are willing to give it a try. However, I really do not want to deal with vibrations. I have come across some individuals that have great success with custom one piece units, while others have had a tough go. An aftermarket unit is a decent option, but aligning it could be a pain.
    What would you do and why?
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Feb 27 2011
    Winnipeg
    I had a custom 1 piece unit made with my old cv splined ends welded onto a tube, properly balanced you should have no issues. 3 weeks ago I drove down to Minneapolis from Winnipeg for Eurowerks and speeds ranged from 60-95mph and no vibrations at all.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Scotty (advanced automotion)!makes a one piece
    for the b5 as does (dss) the drivshaft shop. Both
    work fine as I've owned both.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by landfill View Post
    I am fully aware, however not prepared to pay that type of premium when I can get one made locally for half the cost.
    2000 S4- Working?
