Results 1 to 6 of 6
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Allroad suspension level module - how to 'reactivate' (aside from full VAGcom)
    For some (still) unknown reason, the suspension of my friends 2003 Allroad locks out.
    Once in that mode, it won't come up.
    I normally use full VAGcom, erase code, run output test (often several times) to bring suspension back to life.
    Temporarily, I would like to set him up that he can 'reactivate' the suspension himself (he is 2 hours away, and planning a weekend trip up north) until problem is found that sends the module into lock out.
    Is there a way to run output test with a lesser version of VAGcom?
    Is there a way to 'manually' run the output test? 2 hours battery disconnect does NOT work (tried already). OBD2 bluetooth adapter AFAIK only erases codes, but won't activate suspension.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    does it need to be re-adapted?
    that happened to mine when i had catastrophic sensor faliure
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by PaperToast View Post
    I don't think so. It runs fine for a while; last time I cleaned the contacts at the compressor, valve block etc and run the output test to get it 'up'. then fine for a few weeks.
    No 'out' again (and down). Friend cleaned contacts (just in case), but suspension module is locked out in error mode. And that module does not (appear) to reset on its own, or fuse out.
    05 Golf TDI
    Apr 29 2009
    Quadzilla
    Longmont, CO
    thats a weird one.
    what are the error codes?
    Rockin' the Rockies
    Sep 11 2009
    NE
    Probably CRC memory error, that locks the module for good. I had something similar on my car before I removed the whole thing altogether and went with coil overs. He might need new module since the old one is simply electrically failing inside.
    Feb 20 2010
    Brighton, MI
    made the trip down.
    Suspension all the way down.
    3 codes.
    Erased codes, compressor not kicking in.
    Ran output test, compressor not kicking.
    Wanted to check fuse to compressor, but forgot what fuse it is (not in drive side dash fuse panel; I think one of the big ones under kick panel? Need to check notes from work on other Allroads).
    Put 12V directly on motor: compressor works.
    Note: car apparently at one point received a different compressor. Original connector replaced with male/female insulated spade. Connectors looked corroded.
    Cleaned connectors. Quick test: running.
    Further cleaning, contact cleaner and di-electric grease.
    Still erratic compressor running.
    Decided to end this. cut connectors out, soldered directly.
    Run output test.
    All working well know.
    Ordered Full VAGcom (with Can Bus, since friend also has newer Passat) for friend.
    05 Golf TDI
