Results 1 to 8 of 8
    Jul 05 2016
    PNW
    Seized Tranny Mount Bolt
    The allroad is currently on jack stands as I'm replacing my original transmission mounts with the 034 mounts. Got the two bottom bolts out fine , but the top 17mm bolt WILL NOT budge! I've got the tires off on the front for better access and view. Any ideas? Please help!
    Thanks in advance
    Sep 11 2009
    NE
    Tried PB Blaster? That's just about the only penetrating oil that truly works. If that doesn't work, drill through the bolt.
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    try jacking up the transmission slightly to take the weight off the mount. I just did mine this past weekend. I used a low profile ratchet/socket with a cheater bar for an extension to break the top bolts loose.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Aug 06 2016
    colorado
    heat it up and get a longer bar
    Jul 05 2016
    PNW
    Thanks for the replies. I ended up using 'bolt outs' and it came right out. I'm not sure if everyone does it, but taking off the wheels and going in that way is so much easier.
    More importantly.... I can FINALLY get smooth shifts with no dreaded clunk. The difference in the drive is night and day. Thanks 034 for the quality mounts!
    Sep 11 2009
    NE
    Cool stuff! Tranny mounts are just about the easiest thing to do on this car lol.
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Sounds tempting, this time I'd stay away from Corteco mounts
    Quote Originally Posted by julex View Post
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    May 20 2010
    Tried Kroil? That's just about the only penetrating oil that truly works. If that doesn't work, drill through the bolt.
    FTFY
