Results 1 to 4 of 4
    Established Member Two Rings Cygnets's Avatar
    Jun 28 2016
    07 Audi S4, VW Jetta 1.9 TDI
    Hershey
    Need info on putting a automatic engine into a manual B7 S4
    So I've found a used 07 S4 engine with 54k miles on it for a decent but reasonable price, but my only issue I ran into was it's coming from an automatic S4, and I'd be putting the engine in my 6 speed S4.
    What kind of issues will I run into? Will I even be able to do it? How hard, or what modifications will I need to do? Will it basically be just bolt in and go, or how much more of a pain in the ass will it be?
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    remove the spacer on the end of the crankshaft, done
    I think that's it ?
    Active Member Two Rings on1salsero's Avatar
    Sep 26 2006
    Vegas
    I just replaced my engine (6MT) with an auto tranny engine. In my case all I had to do was remove the auto tranny flywheel (red arrow in pic) and reinstall my flywheel/clutch and tranny. Be sure to reinstall the spacer that goes in between the transfer case and engine. Hope this helps....
    [IMG][/IMG]
    Jun 28 2016
    Hershey
    Awesome guys, thank you!
