Hi guys,
I've got a bit of what I think is a rather unusual problem with this 2001 S4 I recently picked up cheap as a project car. 196,000km on the car, 6MT.
Under heavy acceleration in 2nd or 3rd gear the car will pull normally for 2-3 seconds, and then start lugging as if its either not getting fuel or ignition is totally cutting out - seems to be making boost the whole time. If you stay on it at WOT and let it do this 'bucking' for 5-10 seconds - it seems to clear whatever problem its having and will run totally normally until you shut the car off. It'll pull 0-100mph runs all day until you shutdown and restart, then it starts all over until you let it "buck through the issue".
I've been able to duplicate this behavior consistently. I have no idea what's going on as it doesn't throw consistent codes for this, though occasionally maybe 1 in 3 times it will throw a 17964 - negative pressure deviation. It really doesn't seem like a boost leak since once it initially "works through" the hesitation it will run flawlessly until you shut the ignition off and restart, then it all starts over. It seems electrical or fuel delivery, but the fact that it all of a sudden snaps out of it and just works fine is really confusing me.
Known issues at present that I will be resolving (parts on order)
* Leaking inner valve covers (oil soaked spark plug)
* B1 S1 O2 Sensor code 17521
Hopefully one of you have seen this - any help is much appreciated.
