Results 1 to 17 of 17
    May 28 2013
    2002 Audi S4
    Shreveport, LA
    Pinch bolt help...but not removing it.
    So I'm putting in coilovers on my 02 S4, removed and installed shock assembly and coil on passenger side in 30 minutes. Bear in mind this is my first dealing with coilovers. I didn't even remove the pinch bolt on this side and everything went great. Well drivers side gave me heaps of trouble getting the bolt and shock assembly out so I went ahead and took out the pinch bolt and popped out the links, now I'm trying to put it all back together and have literally everything done on the front except the damn pinch bolt. It came out like butter but the links refuse to go back in. Am I missing something here? I did the axle on this side maybe 1-2 months prior and removed the pinch bolt then also but it went in fairly easy then. This time I can not get the links back in to insert the pinch bolt. Any suggestions? Thanks in advance.
    Mar 02 2009
    State of Confusion
    I found it easier to use a bottle jack under the shock and raise the assembly up. Then I was able to push the upper control arms in with my hand.
    May 28 2013
    2002 Audi S4
    Shreveport, LA
    Hmm. I'll give this a shot, I've been jacking on the upward facing lower ball joint. Could be my mistake. Thank you!
    May 22 2016
    2006 electric blue evo 9, 2jz e46, rwd b5 a4, b7 a4 sline titanium airlift 3p
    Roseville
    Put a flat head in the openings and push them right in. Easy
    Sent from my SM-N910V using Tapatalk
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Are you using lube?
    May 28 2013
    2002 Audi S4
    Shreveport, LA
    Quote Originally Posted by Zba View Post
    Are you using lube?
    No I'm not lol
    May 28 2013
    2002 Audi S4
    Shreveport, LA
    Quote Originally Posted by lebrondog6 View Post
    Where do you lift the hub up from? I used the suggested shock body location and got closer than I've been to getting it to fit. Flat hasn't worked for me yet. Bigger screwdriver I suppose?
    Aug 08 2014
    New Zealand
    How u going boss sorted
    Jul 04 2012
    Woodbridge, VA
    You should coat the non threaded area with antiseize. That how I ensure I'll never have pinch bolt issues. P
    May 22 2016
    Roseville
    Quote Originally Posted by indiankid95 View Post
    Jack it up from the lower control arm to the knuckle. Get it close to the top not a struggle or anything or unsafe. Use a flat head and pry them open and they slide in
    May 28 2013
    2002 Audi S4
    Shreveport, LA
    I have done that also but it seems my angle is off? The ends of the links that do go in are just a tiny bit off angle. I'll take a picture when I get back to the car. I guess I'm not jacking enough.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    If you look at the end of the joints
    they are not %100 cylindrical where
    they slide into the steering knuckle.
    The portion of recessed metal on the
    ball joint has to be lined up with the
    hole where the pinch bolt rides. If they
    are not lined up properly then the hole
    is no longer round inside and the bolt will not
    slide through as some of the joint is protruding
    into the hole. You have to jack up the whole hub
    and play with the arms until everythings aligned.
    I hope this helps.
    Aug 08 2014
    New Zealand
    Reem out the hole n add some loob itl fit hahaha.
    When I did mine and others iv never had issues its sad to see people on youtube ect using oxysetileen grinders ect wow hay.
    Hav you tryed to use a flat head and open up the bit that has the slot bug flat head few taps hear n there then yep use your m8 jack and it should b ok. Must b rusty as, fo you have alloy or steel uprights?
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    Quote Originally Posted by landfill View Post
    I hope this helps.
    what he said. first time i went at it this got me for a few minutes.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    May 28 2013
    2002 Audi S4
    Shreveport, LA
    Actually just needed a second hand and a jack on the lower ball joint. Got it in with a buddies help but now I have a bad shake at about 60+mph. Gets worse with speed. The whole car vibrates.
    Nov 14 2013
    Double check to see if everythings tight.
    You goofed somewhere. Also make sure
    the springs are seated correctly.
    Nov 14 2013
    Also people that let the steering knuckle
    hang with the axle still in the hub tend
    to pull apart the inner CV joint and not
    know. Therefore putting the car back
    together with the joint separated. Then
    subsequently road test it like that and
    destroy the CV. Check that as well.
