Pretty much what the title says. There's this rattle or clank that happens as you hit bumps and as long as the brakes are applied. No brake, no rattle or clank. If I had to describe it, it almost sounds like brake hard lines hitting right under driver side floor by the door edge kinda like where your left foot is resting maybe. It's really weird and it's not rhythmic or anything. Doesn't happen if you're just applying brakes, so it's not the brakes. If anything, it would be whatever's under load while braking and hitting bumps, but even light brake application does it, so it's not like a weight shift issue. WTF? I'm gonna get under it tomorrow, but figured if ask to see if anyone's had the same issue. It's mind bottling.
