Results 1 to 2 of 2
    Senior Member Two Rings krewbrew's Avatar
    Apr 26 2014
    2013 Touareg V6
    Westchester County NY
    S100 Nav RDS display
    I listen to a decent amount of FM radio and have noticed that the RDS text identifying the radio station, song, and artist is garbled. Sometimes it is correct, other times the text is mismatched or overlapping. This is made worse with the new Kotix skins I downloaded since the text is larger. Anyone else have this problem? Any solutions? Is there a way to make the Kotix font size on that screen smaller? By the way, everything else about the Kotix skins is fabulous.
    Kevin
    2015 A7
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Dont know the answer to your problem but mine did that too.
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
