Results 1 to 6 of 6
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    weird issue with trip computer resetting itself
    Okay so I just got my car a couple weeks ago and I dont know whether this issue was present before I had to pull the instrument panel to fix the blinker clicker but what's been happening is when I shut the car off for loner than a few hours the number one trip computer will reset the miles and the hours but nothing else, is this normal behavior?(I'm assuming not) when I shut the car off and turn it immediately back on it doesn't do it either so I'm alittle stumped by this, and the second trip computer is unaffected in any way
    This is the dis info screen, car is 2005.5 and has 40k on it
    Any ideas would be awesome!
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    I think this normal. I never use them so I can't be 100% sure.
    The trip computer under the total miles doesn't reset right? In the right hand corner.
    Jul 25 2016
    new hampshire
    Quote Originally Posted by adam044 View Post
    Nope that one is fine, its the driver information display, so the one that is in between the Speedo and tach that is controlled using the wiper stalk. I'm going to see overnight whether its me just being fckin crazy and resetting it and not remember but its everytime I get in in the morning and after work it does it
    Must be the other personality lol
    Eric
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    Quote Originally Posted by pezgoon View Post
    You're probably on the menu setting for trip/hours (if you have the menu selection on the wiper stalk). If so then it's resetting because it only records for that "trip" of when the car is turned on and then off.
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Trip Computer Mode 1 will reset all it's values back to 0 after the car has been turned off for more than 2 hrs. If you restart the car within that 2 hr period, the "old" values will remain unless you manually reset using the wiper stalk Reset button.
    Audi's assumption is that all restarts within 2 hrs are the same trip; kinda similar reasoning I guess to why the trip computer will flash after you have driven for 2 hrs elapsed time without a 10 minute break.
    Trip Computer Mode 2 is only reset when you want it to, using the same wiper stalk Reset button.
    Info is on Pg 43 of my A4 Sedan manual.
    Jul 25 2016
    new hampshire
    Ohhhhhhhh okay. I was wondering if it might automatically reset itself, it has definitely been driving me mad as I've been thinking I was resetting it when I wasn't etc. And I had confirmation today as I went to a bar, four hours later came out and the sucker was at zero so I knew it was not me this time! Thanks for the info/help sorry for sounding like teh noobz :(
    Thanks all
    Eric
