Results 1 to 3 of 3
    Aug 05 2016
    Kingsville, On, Canada
    Piston replacement details?
    Hi all,
    Wondering if there is a link to the procedure that the dealer goes through with this?
    Mine goes on Monday and I'm curious as to what they do exactly. Drop the whole engine/trans/suspension?
    I'm so nervous that I'll have further issues and have to keep taking it back to the only dealer that is an hour away.
    The other problem is the fact that I'm so picky and hope they don't scratch/ damage anything. Most Tech's really don't give a crap.
    I usually work on my own stuff but obviously not this time.
    Mike
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    There was a video of a tech doing the whole job in time lapse posted a few months ago. I had the job done on my 2009 A4.....I can appreciate your concern....but don't sweat it. When I got mine back I could hardly tell it had been in the shop for three weeks....plus all the misfire issues and CELs and adding oil every week will be cleared up....most haven't had issues.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Veteran Member Three Rings Audiforumuser's Avatar
    Mar 01 2010
    2010 A4 Avant S-line
    Saskatchewan
    My Avant will be going in soon for this as well. I think you should concern yourself more with other things you want them to change while the engine is out. I've purchased new motor mounts and the updated timing chain tensioner and having those installed. Should run like new when they're done with it.
    09 A5 S-line Monza Silver / Incurve IC-S10 20x10.5 / KW H.A.S.
