Results 1 to 7 of 7
    Dec 16 2014
    First Gear Rattle Around 2,600 rpm (auto trans)
    So this is annoying... I'm driving the other day and start to hear a fairly consistent rattle right around the time the car shifts into second gear. It is very intermittent, and does not occur if I'm accelerating aggressively. This only occurs when accelerating moderately and it only happens in first gear.
    Trying to replicate the noise is pretty difficult, but I figured out if I put my trans into Sport mode and hold her steady in first gear holding around 1,200 RPM then moderately accelerate the noise occurs between 2,200 and 2,800 RPMs. Once I hear it, I let off before shifting into second, bring the RPMs back down and can accelerate moderately to hear the noise again. I do not hear it outside of first gear and I mostly hear it after accepting from stop lights.
    If I get on it aggressively, I hear no noise.
    Its worth mentioning, the tranny is shifting great, car runs and idles great as well. I did just have a new snub mount put in about 1,000 miles ago and did not replace the worn motor mounts.
    I'm stumped....
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    why worry if you have to try .
    - - - Updated - - -
    your trying to cause a problem . just drive it
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Apr 17 2016
    kc
    Time for a six speed manual swap👍
    Established Member Two Rings Northern_B6's Avatar
    Feb 20 2013
    CANADA
    2003 1.8T Auto
    I get a distinct rattle around 2200 RPM.. I've replaced and checked a lot of parts and cannot seem to track down what's causing the rattle.
    This thread has a solid discussion within it and it should get your hunt started in the right direction:
    http://www.audizine.com/forum/showth...attle+2000+rpm
    Good luck!
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    I have the same rattle on my auto 1.8T. Im going to check the dp/cat area a little better and check for any loose bolts.
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Dec 16 2014
    Quote Originally Posted by GTRchop88 View Post
    Let me know what you find. Going to get under there and see if I can find a bolt or something loose.
    Just weird, it happens in 1st/2nd around 2k. I feel like if it was the cat it would happen more often.
    Dec 16 2014
    No solutions. Sound now comes and goes.
