Results 1 to 19 of 19
Thread: ECS order..
    Senior Member Two Rings Wreckm's Avatar
    Oct 30 2013
    San Gabriel California
    ECS order..
    Fedex just dropped of my ecs drilled and slotted rotor and pad kit.
    After taking everything apart and opening the box.
    It says L and R but both rotors are R passenger side.
    Vents are backwards driver side.
    Has anyone received a KIT order from them and got 2 of the same sides??
    I had to install just going to drive like grandma.
    Emailed the customer service i am just wondering if its happened to anyone on here.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Nope mine came with one R and one L
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Oct 30 2013
    Yes the box said L and R but two identical rotors same vent direction
    Senior Member Two Rings Pawan2013's Avatar
    May 28 2013
    i dont think the vents the directional, just the slots. I had the same thing when i got my stoptech rotors, i thought the vents would be directional but only the slots were
    B8 S4, DSG, Sport Diff, B&O + Nav
    Many Mods
    Oct 30 2013
    Was just looking at some pics off google about directional vanes if i knew how to post pic https://www.zeckhausen.com/catalog/i...Path=6446_6515 so now i am getting confused on the direction. Guessing its set on manufacture.
    Active Member Two Rings Oblivia's Avatar
    May 06 2013
    Expedition, F150, M35X
    Tacoma, Washington
    I think even OEM rotors are uni-directional, so I wouldn't worry too much.
    How fast is fast?
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    ECS order..
    Quote Originally Posted by Wreckm View Post
    Yea the article says not to worry about what angle the slots on the face of the rotor look like.
    Just go by the internal cooling slots(highlited in red below) and what direction they're leaning in.
    Edit: From the link you posted:
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    A lot of people are confused by directional slotted/drilled/dimpled rotors...the internal veins are what make a rotor either directional or non directional. Easiest way to know if they are directional is to put a screwdriver in the vein and see which way it sits. If it's straight up and down coming out of the rotor it's not directional. If it's tilted forward twords the front of the car it's directional, but installed on the wrong side of then car. If it's tipped twords the rear of the car it's directional and installed in the correct side.
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Jan 04 2013
    Phoenix, az
    I know I made sure to put mine on based on the box label. I went out and looked and the direction of the slots, on the face of the rotor, match the pictures on the ECS website.
    This thread made me go double check. LOL
    Oct 30 2013
    I am talking about the internal vane.
    One is facing up shown on example above and the other side is facing forward.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    If both rotors have R on them then they probably packaged one box wrong. It happens.
    Simply return it for the correct one. If you installed it already then you will most likely be SOL and will have to buy the L again. Call them and see what they can do for you.
    And yes - they are directional.
    Veteran Member Three Rings bayonet14's Avatar
    Aug 07 2013
    BMW 335i
    Pinelands NC
    ^thats how mine came - sounds like you have 2 rotors for the R due to packing on the ECS end....
    can you post a pic?
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    the vanes in your rotor directional or straight are really not to going to be causing you a large performance difference. Maybe, under an intense track day you may see one side fade a bit more, but really in day to day driving, even spirited driving you are not going to see a difference.
    here are your options from easiest to hardest
    1) keep it and install it as is
    2) same as #1 but contact ECS and see if you can get some $$ off
    3) return the rotor, ever ship a rotor before? not impossible, but good luck, ensure it's packaged well, they are heavy and have a way of just destroying boxes.
    personally, i would just install as is.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Oct 02 2006
    Wadsworth,OH
    OEM S4 rotors are not directionally internally vaned. So you'll have one that goes one direction and one that goes the other. Just follow the labeling on the rotor so your slots are oriented properly.
    Jason
    Jul 08 2010
    tucson
    danbury
    Jason
    it think OP says he got two rotors that are both labeled right tho, also, i am confused, did you meant they ARE directionally vaned?
    [CENTER]Scott
    2011 S4
    Apr 14 2016
    2014 Cayman S, 2004 A4, 2005 4Runner
    Eastern PA
    Quote Originally Posted by mr shickadance View Post
    Just put a set on my car a few weeks ago. The internal vanes are directional.
    Oct 02 2006
    Wadsworth,OH
    I should have been a little more clear. The S4 rotors are directionally vaned. But it they are only directional on one side. Meaning you'll have one side that's oriented properly and the other that is backwards. See the pics below. Every OEM style S4 rotor we carry looks the same.
    Zimmerman
    Genuine Audi
    Meyle
    OP Parts
    ECS GEOMET
    Jason
    Mar 05 2014
    2020 SQ5
    PDX
    No wonder brake dust is always highest on the right side.
    2020 SQ5 Quantum
    Oct 30 2013
    yea that blows my mind. OEM ones are the same.
    thank you jason
