Results 1 to 3 of 3
    Junior Member Two Rings
    Jul 21 2014
    2017 Q7
    Metuchen, NJ
    Help! Driver Side Window Controls Question
    my driver side window control came loose. Buttons seem to all work, but its loose and falls in when I press the button. My question is if I go ahead and buy a window control, will I need to reprogram anything when I swap it out? Has anyone done this and if so has a DIY they can point me to? Any help will be appreciated.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    David at audienthusiasts.com has several tutorials for projects involving removing the door panels, which illustrate how the arm rest holding the window switches and door locks is removed. It should not require removing the door panels to perform the repair you are seeking to do. Here's one project that he wrote for installing ambient lighting in the door pockets. It shows the steps for getting as far as you should need to go to get to this point:
    Others here who may have replaced switches on their driver's side arm rest can chime in with any helpful tips. I don't believe you should have to reprogram anything when you replace the switch. Keep us posted on your progress!
    UPDATE! I just found this site that shows a picture of the switch, and it's actually a switch assembly that controls all 4 of the window. I assume the A4 and S4 switches are the same. According to the site, it can be replaced in 5 minutes. It does look like the switch assembly is connectorized so that it's an easy replacement.
    It looks like ECS Tuning carries this switch at this link. They say it fits up to 2012 S4s. Hope this helps.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Jul 21 2014
    2017 Q7
    Metuchen, NJ
    Thanks for all your help LYKUNO. It is that easy. Below the arm rest towards the outside part there is a hole. Put a screwdriver through the hole and pull towards you. Done and done, actual 5 minute job that some mechanic wanted to charge me $100 and can't even imagine what the dealership would have charged. Nevertheless, I did notice that one of the four clips that holds the switch is broken. The actual switch does work, but might as well just change it. I will order from one of the sites you posted. Thanks again!
