So to put everything in perspective I currently have 3 1999.5 b5 a4s. 1 silver sedan 1.8t 5spd stage 1, 1 brilliant black 1.8t 5spd ko4 pc16 supporting mods. and recently purchased volcano black avant 2.8l auto.
I original was on the hunt for some rims and tires for the sedans, I had one good set between the two and was getting ready to downsize my b5 collection. While on craigslist I found the Avant, tires only had 500 miles, car was dirty in the pics but body was straight and appeared black. I assumed it was the same as my black sedan but soon found out this was not the case. the black sedan needed a fender and door, window regulator clips and other odds and ends. supposedly the car needed cam tensioner but had some maintenance items done such as timing belt and sensors. The seller wanted 400 so I figured I could not get hurt at the price and went and checked it out.
At first site I realized the car was not black almost looked dark gray. tires and rims checked out, interior trashed, and the owner not really sure what was wrong with the car. I almost backed out, but I drove an hour with a truck and trailer figured I needed tires and still could use the body panels even though they were a different color. so I loaded it up.
The exterior of the car cleaned up better than I expected and I slowly started falling for the Avant. I have always wanted one. I had hoped to fix the engine and drive it, but this was shot down quickly. I found one of the piston had a hole in it. so an engine replacement is in order.
This brings me to my crossroad. Purchase a 2.8 replacement and drive the avant selling my sedans. Most people say that the 2.8l and automatic is miserable to drive. Can anyone give any incite on this? The other option I’ve been contemplating is swapping the drivetrain from the k04 car into the Avant. Does anyone have any info on this swap? From my research it looks like it’s not the bad being that I have a donor car. What would I swap engine, engine harness, transmission, rear diff, ecu, clutch pedal and slave cylinder parts. If it wasn’t an avant I would just pull the parts I needed and part the rest out, but I don’t want to do it to a avant.
Will the swap be worth it or are the gains only marginable? The car will mainly be used as a commuter; I want to be able to enjoy my commute the k04 currently does this. Will the 2.8 auto leave me disappointed. The hopes would be to sell the silver car and either sell or part out the black car depending on the route I take.
Sorry for the long read. Hopefully someone can help me with my madness.
Below are some bad pictures of the avant.
