Page 1 of 6 123 ... LastLast
Results 1 to 40 of 204
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    S4 B8 OE coolant pump 100% duty cycle
    I did this mod today,very easy if you dont want it switched as it only requires the cutting of 1 wire.
    The wire is Yellow/blue on my 2010 & according to the below it is the same on a 14 (thanks to @beans912 for the diagram )
    The wire is located in the wiring shown being held in the below pic
    The pump runs at 100% constantly once the the engine is running ,but slows to a much slower rate when the engine is off & ignition is on.
    The pump stops completely about 20 seconds after removing the key from the ignition
    I did some logs today & the temps didn't go over 63c & that was @ 6300rpm in 5th gear
    The outside temp was 23.5c
    Log is here https://www.dropbox.com/s/gbronxl9kw..._%266.CSV?dl=0
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Jun 28 2016
    US
    What were the temps before, while taking outside temp into consideration? Did you do logs of it stock and then cut and then log again, preferably around the same time on the same day? BTW, it probably would have been better (so you could put it back to stock) if you had unplugged the harness plug off the pump and then just pulled the wire pin out of the plug and electrical taping it to the harness out of the way and sealed from the environment. Just a thought for those thinking of doing this mod.
    Feb 20 2006
    NC
    good stuff!
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    Feb 05 2016
    UK
    I have logs from a different day,
    Pre pump mod
    outside temps were 20c https://www.dropbox.com/s/jjkyiscbz3...-4191.CSV?dl=0
    3rd gear 2000rpm to 6900 rpm
    start temp 37.5c finish temp 48.75c
    Post pump mod
    Today,outside 23.5c
    3rd gear 2000rpm to 6900rpm
    start temp 38.25c finish temp 37.5c
    into 4th gear 4500rpm to 6900rpm
    start temp 38.25c finish temp 43.5c
    I should add that I have put connector on the cut wire in case I wish to put it back
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Quote Originally Posted by xpoweruk View Post
    Pre pump mod
    Post pump mod
    Today,outside 23.5c
    Good stuff. However, this would shorten the pumps lifespan. It's costs of modding
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Very interesting. I would want to add a switch so that it only runs full time when I want it to
    2021 Audi S4, P34 Intake
    Feb 05 2016
    UK
    I dont mind shortening the pumps lifespan,good excuse to upgrade then
    May 11 2014
    United States
    I guess I dont understand your first post. You said when the engine is on its at 100%, and when the engine AND ignition are on it slows? Please explain this a little bit to me because when the engine is on isnt the ignition on? Im a little confused. Does it run when the engine is off and accessory mode on? And what did you do with that wire exaclty, just cut it and add connectors? Did this cause a code of any kind. Let me know ASAP. Looking to hit the track today and would really like to do this, temps outside are a non favorable 90.
    Current: 2018 Audi Exclusive Nogaro Blue RS3 w/Unitronic Stage 1+ E85 ECU and Stage 2 TCU, Water/Meth Injection, Black optics, Tech, Dynamic, Drivers Assistance, RS Design Packages, Carbon Inlays, Carbon Mirror
    Past: 2014 Black S4 DSG/1999 Eclipse GSX
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by hckymstr19 View Post
    Not sure on the first question but to the second:
    If you cut the wire or short it to positive it will run the pump in "emergency mode" which is 100%.
    He just added the connectors so he could restore normal functionality later.
    If you are going to the track I would absolutely cut it
    xpoweruk is not the first to do this mod.
    Geoff
    May 11 2014
    United States
    Quote Originally Posted by whiped View Post
    Does it throw a code just cutting the wire?
    Apr 05 2016
    Portland, OR
    I'm not sure... I know it does if you unplug the pump completely
    Feb 05 2016
    UK
    It should of read
    It does throw a code,but it's a soft code so no MIL is thrown
    1 Fault Found:
    7814 - Coolant Pump for Intercooler
    P190C 00 [039] - No Signal
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 90823 km
    Date: 2016.08.05
    Time: 15:31:53
    May 11 2014
    United States
    It should of read
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 90823 km
    Date: 2016.08.05
    Time: 15:31:53
    Perfect! that is exactly what I wanted to know, and it does run with the engine off and ignition on. Awesome Thanks alot? Doing this as soon as I get out of work. And to make sure, all you did was cut that yellow/blue wire?
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Awesome. Proof of some of the discussion in my thread on the pump supposedly not working.
    Great job on being willing to try it. Like others have said may be a great way to address heat when at the track and waiting in staging lanes.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Feb 05 2016
    UK
    I unplugged the connector first as it gives you room to pull the wire up,but yes I just cut the Yellow/blue wire
    I have attached a connector to each wire in case I want to go back to OE
    May 11 2014
    United States
    Quote Originally Posted by cspcrx View Post
    That is my thought exactly, with that added heat exchanger and the two 9" fans I have behind them wired to a switch, if i can have the engine off in the staging lanes and the fans on and coolant pumping through there, that sounds like the best scenario to combat heat at the track!
    Apr 05 2016
    Portland, OR
    Be sure to post your times man! Haven't seen much coming out of the EPL camp.
    Geoff
    Sep 20 2006
    MD
    Nothing wrong with that.
    Apr 07 2004
    Auburn, AL
    Be forewarned, a new OEM pump retails for $556, and there are not many aftermarket pumps that outflow it. It is PWM controlled from the engine computer so it does not have to run at 100% all the time, and was not designed to do so...
    APR, LLC
    (800)680-7921
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Tom/APR View Post
    Thanks for the info Tom.
    Just for documentation here are some other pump options:
    Quote Originally Posted by infinkc View Post
    switch out to an aftermarket one and wire it as above but the green wire to 12v of the aftermarket pump.
    Pump APR uses: Jabsco
    https://www.amazon.com/Jabsco-50840-...=1&*entries*=0
    Pump AMS uses: Varimax
    https://www.summitracing.com/parts/l...x4AaApnz8P8HAQ
    Pump AWE uses: Meziere'
    http://www.jegs.com/i/Meziere/680/WP...rentProductId=
    I believe the Varimax (AMS one) flows the best.
    Geoff
    Jan 04 2013
    Phoenix, az
    I think if you just use it as a track option it makes sense. You can separate the wires at the track and get the advantage of the extra cooling. Before you leave plug it back in and functions as normal. Makes sense to me.
    Veteran Member Three Rings Jflow23's Avatar
    Apr 10 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    Any codes?
    Jan 04 2013
    Phoenix, az
    I believe he showed he was. This is what I was told by the dealer as well.
    Mar 21 2015
    Quote Originally Posted by Jflow23 View Post
    Any codes?
    9 posts up
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Has anyone done this with the AMS system installed? I am considering this mod with a switch in my dash.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Basically, the pump is now running on emergency mode ..
    Is there anyway to disconnect it rather than cutting it?
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by DGVR6 View Post
    here:
    he is saying you can put quick disconnect connectors on the wires. heres a few:
    https://www.waytekwire.com/products/...k-Disconnects/
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Aug 03 2014
    Queens
    Quote Originally Posted by jlaudio View Post
    here:
    Ahh ok I see.. That's pretty neat.
    Sounds like a good option to disconnect while at the track and reconnecting once you're done.
    Previous
    Senior Member Two Rings Pawan2013's Avatar
    May 28 2013
    Is there a separate pump for the supercharger and the rest of the engine or is it all one loop with one pump?
    B8 S4, DSG, Sport Diff, B&O + Nav
    Many Mods
    Feb 05 2016
    UK
    Just for info,I believe the OE pump is rated at 50 l/m or 3000 l/hr
    Senior Member Three Rings RyanJon's Avatar
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    It would be good to solder a toggle switch into the circuit and hide it out of the way to engage it as and when required
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Thanks for doing this for everyone!
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Nov 28 2015
    Montreal, QC
    oh lord.. so many choice haha!! have you done any research regarding these pumps as the one that is the quieter/flow more/durability/warranty/reputation of brand etc. ? I will need to have some read on the different system, seems like the awe/ams is pretty popular.
    S4 B8.5 no track, just enjoying spirited driving.
    Jan 04 2013
    Phoenix, az
    Quote Originally Posted by Pawan2013 View Post
    Supercharger loop has its own electrical pump. Main cooling system uses the primary water pump to circulate the coolant
    Established Member Two Rings Moloki's Avatar
    May 25 2014
    mass
    Yellow/blue wire right? Lol just making sure I didn't cut the wrong wire, as these do go right with the ignition coils.
    Sent from my XT1254 using Tapatalk
    2012 S4 | Moonlight Blue | sports Diff | interior under glow | DSG | APR TCU flash | Rs4 Grille | ECS Valved Exhaust | APR stage 2 DP | ECS luft-technik intake silicone version | 034 Motorsports transmission mounts and Diff mounts | P3 multi gauge | Michelin PILOT SPORT A/S | A4 weather mats
    2003 A4 | loudest sound system possible | :( sold
    Mar 21 2015
    ^ Those two connectors don't go together.
    Feb 05 2016
    UK
    That's the one on my 2010 & the same on the 2014 diagram
    Easy enough to check.
    Turn the steering on full lock to the right & undo the 2 screws that hold the left arch liner at the bottom & top to the bumper.Fold the liner out of the way & the pump is exposed :)
    Jun 28 2016
    US
    lol. I thought I was the only one who thought that, but then I saw blue wire loom and green duct tape, so I was like . hahaha
    Feb 05 2016
    UK
    Deffo wrong connector for :)
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    So do we know which one is on when, and is there a way to log these in VCDS? I assume the s/c one runs 100% all of the time?
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
