Results 1 to 40 of 62
    Jun 29 2015
    Danbury, CT
    6+ Hours to replace Engine Mounts?
    So I took my car to shop today to replace my Stern Engine Mount with the 034 Track Density after the right Stern mount seems to have broken. The shop let me know it will be about a 6 hour job due to the way they have to install. Is this for real?
    Thank you
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    With a lift, shouldnt take longer than 2 hours. Maybe 3 if they suck.
    Jun 29 2015
    Danbury, CT
    Quote Originally Posted by a4kamila6 View Post
    God damnit, they're a premier Porsche shop that also specializes in Audis. The owner himself has a B5 S4 Avant
    Sep 30 2015
    I remember when I did the motor mounts on my car a year ago in November, it was cold as hell so maybe that motivated me, but with just the car lifted off the ground on jack stands, i dropped the whole subframe with motor and supported it with piece of plywood and floor jack. Took me like 4 hours in that crappy position so I imagine with a proper shop lift and not freezing your balls off you could get it done in 3.
    Aug 17 2015
    Holland
    Do you see any garage in the world working on the streets, putting the car on jack stands and wrench their way through? A shop might take longer but certainly puts some quality work in that stuff.
    2001, RS4 B5.
    May 30 2015
    canada
    taking you to the cleaners
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Took me 4 hours total including researching the best way to do it, about 2 hours of actual labor.
    (p.s. don't drop your subframe to do this.. use the simmply method..)
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Jun 29 2015
    Danbury, CT
    Hopefully, he was just trying to set expectations, but if I get charged 6 hours labor I'll be pissed. Maybe he was thinking of something different, but he said he would have to remove the oil cooler, etc. which doesn't seem like anyone else did.
    Dec 30 2009
    Quote Originally Posted by amusante View Post
    no need to remove the oil cooler.. wow.. would not let shop touch car who said they needed to remove the oil cooler.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Flat rate time does not equal real time.
    Doesn't matter how fast anybody here can do their mounts. With flat rate, if you actually charge a 1:1 paid vs real time, you aren't making money.
    Gotta pay to play.
    For example, Ford Explorers pay 5 hours for ball joints, and I would have them done in an hour. I was very good at doing them, and hustled so that I could get onto the next job. The fact that I am good at my job and faster than the other guy doesn't mean I should make less money.
    Sorry, it just bugs me when people try to say a shop is overcharging for X because "I can do X in half that time.". That's not how this works.
    Jun 29 2015
    Danbury, CT
    Quote Originally Posted by DieselElectric View Post
    Gotta pay to play.
    I get what you are saying, but when people by themselves can do it in 4, I would definitely say I'm getting overcharged if a professional shop with expertise, and the right tools and equipment is saying it's a 6 hour job, that's a little ridiculous.
    Sep 30 2015
    Gotta pay to play.
    Makes sense. Shops have to make money
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    Gotta pay to play.
    I have to stand behind this explanation right here, Flat rate and actual are 2 separate things, your right too, if your flagging only what your charging, your not going to make it. the truth is, if your going to take it to a shop, you should already be expecting to pay, how do they pay for their overhead??? .....get what you pay for. If it is so easy to do and complain about the estimate, then do it yourself. Don't complain. simple as that.
    you don't go to vegas and expect to win do you???
    2008 Ibis RS4....GETing tuned
    Jun 29 2015
    Danbury, CT
    Quote Originally Posted by axnjaksn View Post
    I definitely wasn't complaining. Again, just wanted to make sure 6 hours was reasonable.
    and if your second guessing yourself to do the job, your already starting off on a bad note. Go into it with confidence knowing whatever happens youll get it done. I know this is something gained by experience, but some people just have it with anything that comes at them in life.
    6 hours is a deal to me...id probably charge more than that if I had never done a set and the car was modified......I didn't do my mounts until I pulled my engine for turbo sway...just my opinion.
    just out of curiosity...whats the labor rate??
    $100/hr. This is my daily driver, so I don't want to strand myself through dumb mistakes. I take my car to this shop for everything, but I've had mounts done in the past and didn't remember it being this costly, but I may be mistaken.
    Veteran Member Three Rings 0396's Avatar
    Feb 10 2005
    L A
    Gotta pay to play.
    Funny as I've encountered this with my good high school friend that is a Master Porsche tech. When I asked if he would like to work on my S/4 during his work hours at the Porsche dealer, he decline and would suggest that I use one of his Audi buddies. He mentioned that they know more than him about my S4 , thus he can focus on his expertise, the Porsche's...he knows short cuts that most people don't know ..especially since he's been wrenching them for years and years.
    Since I try to wrench my S4 "little " items, and since I have other cars to drive..I can take my time.
    I replaced the TDS for the timing on the top back between the firewall and engine.
    I read up on the procedure, sounds easy...it took me four days working about 1 to 2 hours an attempt before I gave up. Some things sound easy but if its your first time..its going to be a B...h. Looking back, I should have just paid an Audi tech and be done with it in one day / visit.
    These techs get paid to be efficient than they can move on to another "customer pay " job. He mentioned that factory warranty sucks and pay 1/2 of the time to actually get it done...efficiency rewards
    0396
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Should have done it yourself. It's not that hard just takes patience. Lots of info out there on this on the internet. And the special tool that will save you is called the stubby wrench. When doing motor mounts on the B5 S4. 6 hours is highway robbery. But, that's what people get when they bring it to a shop.
    Nov 02 2014
    Winchester, VA
    If he quoted you 6 hours, and you still let them start the job, then you have no room to bitch.
    Sometimes it's a job that they just don't feel like doing, so they quote high to make it worth their while.
    If a shop is up front with their cost, you have every right to go somewhere else with your money.
    Nov 02 2014
    Winchester, VA
    Again, I don't give a shit what people can do it by themselves in. The shop spent money on those tools, and time to get the experience to do it in half the time your average back yard mechanic can do it in.
    By your logic, investing time and money should net less profit. Right.
    Jun 29 2015
    Danbury, CT
    Investing time and money should net more efficient work, quicker turnover, thus allowing more customers. Profit should not come through deceitful business practices. That's like saying a tow yard can keep your car for 5 days while charging you, even though you could have picked it up that day, because they invested in a tow truck.
    I get certain jobs have specific allotted times. What I'm saying is, the 6 hour allotted time does not seem accurate. If they had said 4 and I see everyone here saying, yep 4 hours is about right, then fine.
    Nov 02 2014
    Winchester, VA
    It's not deceit.
    You will not find a single shop, anywhere, that charges exactly the time a job takes.
    That's not how flat rate works.
    You are quoted a time to do the job, that's what it costs. The fact that it can be done by someone who knows what they are doing in half the time is why flat rate exists.
    Technicians are generally paid a lower hourly rate than other fields, because they have the ability to "turn" more hours in a day than they work.
    I got out of the industry for the same reason. Some days I would turn 20 hours, others I would get 3.
    If you don't like it, then do your own work. Don't talk shit when you don't understand how things work.
    Jun 29 2015
    Danbury, CT
    It's not deceit.
    Please point out where I was talking shit. I very easily understood how things worked, just don't necessarily agree with it. Just wanted to verify the quote, as it seemed a little outrageous to me. Thanks for your help bruh
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    This statement is talking shit to all mechanics "Profit should not come through deceitful business practices." let me know when you go to get the top nut off and the whole mount is torn in half and your trying to get a pair of channel locks in there to hold the mount because the nut is damn near seized . 6 hours isnt crazy time at all .
    dealerships and shops charge 1.5 book time straight from all data
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Jun 29 2015
    Danbury, CT
    Quote Originally Posted by AudiTechS4 View Post
    I wasn't saying mechanics are all shady. If you're purposely adding hours to a job, why is that not deceitful? I'm not saying things shouldn't be charged by how long things are supposed to take even if they can finish sooner. I'm just saying it doesn't seem like it's supposed to take 6 hours.
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Fucking hilarious.
    I didn't invest 60k in tools and equipment, along with the thousands of hours of personal time on training, education, and experience so that my time would be worth less.
    You're also asking for an R&R on aftermarket parts, on a modified car. Book time goes out the window in that scenario. They're covering their ass, plain and simple. Or maybe they just don't like you.
    Take it somewhere that will charge for 4 hours and I promise they'll make up the difference with the other shit they break in the process.
    You're not just paying someone for nut and bolt work. You're paying them because you trust them to do the job correctly and not screw anything else up.
    Check yourself.
    That's the worst. I always remove the bottom mount brackets and remove from underneath for that reason.
    Yep, identifix shows 4 hours for it too.
    alldata is quoting 19-20 hours to do the job . to do the job properly by torquing the top nut you need to pull the engine.
    Technically, you can torque it using the adapter with the offset crow's foot. Similar to the ones you use with high pressure fuel lines. Not the point though.
    2005 A4 Avant 1.8t QTM
    Dec 10 2013
    Borden, Ontario, Canada
    I did mine at a shop with a hoist, proper tools, and engine brace and expert help. The job took 10hrs because I was also doing downpipes. I'll never do motor mounts without removing the front end again. What a bitch that was.
    Quote Originally Posted by themadscientist View Post
    Fucking hilarious.
    Check yourself.
    I agree, wholeheartedly.
    Everything graciously mispelled by Android
    2003 Allroad 6-spd, 4.2 BBD S6 Swap
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    I think most people completely understand where DieselElectric is coming from. OP just wants a ballpark figure on time to gauge whether he might consider doing it himself, or whether it is worth the labor and "flat rate" charge at that shop. If OP knows he/she is going to spend 4hrs laying on the ground under his car versus the 6hrs the shop is charging, that makes the judgement call easier.
    I understand the premise behind charging flat rate, however even as DieselElectric points out in their example for Explorer ball joints, I don't agree with the flat rate charge for labor being 5x the actual time it takes to do the job. In the case of OP's shop, that is not what is happening.
    Jun 29 2015
    Danbury, CT
    Quote Originally Posted by MacFady View Post
    Exactly, I think you nailed why I was even asking to begin with, as well as my concerns.
    Nov 05 2009
    Denver
    So if you take it to a shop who has never done ball joints on an Explorer, and it takes them eight hours, should you pay for eight hours of labor? Flat rate ensures that the labor hours being charged are similar across shops. And as mentioned earlier, if a tech or a shop is booking 1:1, you are not making a living. Turning wrenches is like being a waiter.
    Veteran Member Four Rings rockcandy's Avatar
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    I don't think you get it. There is a massive spectrum of times that it takes people to do jobs. If you think it's not okay to charge 5x the actual time it takes, yet you think it's okay to charge 4 hours to do motor mounts, you're lost. I can do 8 sets in 4 hours AND take a decent lunch break halfway through. So why aren't these people charging 4 hrs crooks?
    You know what though? There are jobs I completely hate and would happily let someone else do them. Usually, everyone has their thing. The things they like and the things they despise. Just remember that Audi paid their techs for many many years 13+ hours to do this. If they thought they could pay less, they would have. Don't hate.
    B8 S4 owner who's lost his mind building his car. Come join me!
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by rockcandy View Post
    I bent a wrench exactly how you have it and it's easier.
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Jun 29 2015
    Danbury, CT
    Yikes, alright. Thanks for the info. He did mention they sometimes have to pull the engine.
    Jul 07 2009
    Alberta, Canada
    Lol. Torque the mounts.
    No one is pulling the motor on a 15yr old car to do motor mounts.
    Veteran Member Three Rings insomniacxp1's Avatar
    May 10 2010
    01.5 B5 S4
    Rochester, NY
    I pulled the radiator, pushed condensor to the side, pulled core support, y pipe, lobster claws, hard intake line running over valve covers, and pulled the intake to the turbo's just to gain a little extra room.
    Top nut torqued to spec as well as everything else down the line. Took maybe ~4 hours cruisin. I don't know the exact time it was a little while ago
    Shout out to themadscientiest ^ knows whats up
    01.5 Imola S4. Stage 3 F21's/To much to list
    Jun 29 2015
    Danbury, CT
    welp fuck me guys. Didn't realize I would cause a shit storm. Just wanted to make sure I wasn't getting ripped off. Thanks to all for the input.
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    I did the motor mounts and a timing belt/water pump in 3 hours lol.
    Active Member Two Rings Burrito951's Avatar
    Mar 16 2015
    2001.5 S4, 1986 951, 2002 R50
    Milwaukee, WI
    Nov 02 2014
    Winchester, VA
    If they are as good a shop as you say, then you can be confident in their work.
    That should be worth a little more cash than the next guy.
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    Warranty paid 13.6hrs if I remember correctly. Ah the good old days.
    Mar 07 2013
    wooooow, that is good old days... benz used to pay much better warranty times too....sigh
