Results 1 to 2 of 2
    Nov 23 2006
    "I'LL SHOW YE GARAGE!"
    Soooouuullllll Cal!
    Unhappy Just replaced the (G28) crankshaft position sensor. Another problem rises!
    Well it's been a long time since I posted here. But here goes...
    Need help!
    I replaced the Crankshaft Position Sensor after it gave me a PO322. The car will run fine but 20 mins into it, the car will start bogging when accelerating.
    Plus it give this wierd noise when its on idle: https://youtu.be/MT6FaT_D6f4
    Nov 24 2014
    DMV
    Not sure what the ticking noise is but have you checked your vacuum/PCV system? It sounds to me like there's some hissing, it maybe bogging down because there's a leak somewhere. Good luck man!
    02 B6 A4 3.0 6MT Sport Package | Kenwood DDX9702S Double Din | Tint | B7 S4 Front Calipers & 345mm Brembo Rotors + Pads | Blauparts "U-Slot" Slotted Rear Rotors + Pads | ECS SS Brake Lines | APR Snub Mount | ECS Short Shifter | BFI Shift Knob | 034 Front Swaybar Endlinks | Lemforder RS4 Outer Tie Rods | SPC Adjustable Front Control Arms | Meyle HD Lower Control Arms
