Results 1 to 17 of 17
Thread: No heat
    Senior Member Two Rings MassS4B5's Avatar
    Jun 01 2007
    Stage 3 B5 S4
    east coast
    No heat
    What would cause a S4 to no longer have heat? I have no ac compresser delete but I doubt that has anything to do with it.
    May 16 2008
    WA
    Plugged heater core is one possibility.
    Have you introduced air into the cooling system by replacing other parts in the cooling loop recently? Ait bubbles in the system from an incomplete bleed process can cause little to no heat.
    Is the temp gauge registering normal operating temperatures?
    Jun 01 2007
    Stage 3 B5 S4
    east coast
    Temps were normal
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Clogged heater core. Whole dash has to come out.....
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    These threads usually don't start until the first frost hits lol.
    Yes, you have a plugged heater core.
    You can try to find a shop in your area that has the special Gates power clean flush gun and give that a whirl
    Or you can just replace the heater core
    Senior Member Two Rings joeSfour's Avatar
    Nov 09 2011
    South Bay, CA
    I've tried CLR and a pond pump for several hours, and many different times. I can usually get my heat to come back for a couple days, but I definitely need to get mine changed.
    Current - 2001 B5 S4 Imola Avant
    2009 VW GTI
    Past - 2002 B5 S4 - 034 STK 5858 PT fully built 3.0L
    Aug 17 2015
    Holland
    Quote Originally Posted by MassS4B5 View Post
    Temp sensor in coolant line. Should OPEN on hot and CLOSE when cold.
    When it opens, it distributes the hot water across your radiator and / or heater core. When damaged, its stuck closed, and your engine is not running as it should
    2001, RS4 B5.
    Nov 05 2009
    Denver
    Quote Originally Posted by Jism View Post
    LOL Wut?
    Aug 17 2015
    Holland
    I think i was looking for the word 'thermostat' lol.
    2001, RS4 B5.
    May 16 2008
    WA
    the heater core would still have heat and the engine would overheat if the thermostat was stuck closed. The heater core is part of the engine coolant loop, regardless of thermostat position:
    Nov 05 2009
    Denver
    Haha, I figured as much but couldn't let it slide :P
    Jun 01 2007
    Stage 3 B5 S4
    east coast
    I parked my Tial 770 car four years ago because of this never got around to fixing it. Now I sold my daily and want to get back into my S4.
    Will try the thermo first and hope for the best as I know rhe heater core sucks to get at.
    Nov 05 2009
    Denver
    If your engine gets up to temp and stays there it's not a thermostat. Don't even waste your time fixing that. Put those man hours into ripping the dash out. It's reall not that bad.
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    I don't advise trying to flush the B5 cores. They have plastic endtanks and usually leak without anyone's help. Dash isn't bad, just don't try to cheat the job. Follow all the steps. The plastic HVAC box is fragile.
    2005 A4 Avant 1.8t QTM
    Apr 07 2011
    Home of the mighty beaver
    gravity flushing it after giving it some CLR overnight should be safe no?
    Deactivated Four Rings derek2079's Avatar
    Aug 02 2004
    UT
    I am having the exact same problem and the car's heat has to work to pass inspection. What can I do to get it working in order to pass, anything?
